I tried to update to 2.915 to fix failing webradio certs. Since then:
- couldn’t update (“detected modified files” - I didn’t modify any files).
- clean install: first-time wizard disappears instantly, even with disabled extensions, on desktop AND mobile, Safari and Edge. Only Private mode in Edge works. Wasn’t an issue at all in 2.909.
- connected via LAN. Connection to wifi is “successful” according to setup but UI doesn’t load, ever. I can ssh into it, and that’s it. UI only works on LAN
So here I am with useless setup. It all worked in 2.909, sans the radios that I sadly really want.
Here’s log. Any clues? Thanks.
EDIT: UI only worked on first launch. It just doesn’t work anymore, even on LAN. I can still ssh into it though. This is a second attempt (second full reinstall today).
