Hello all,
I use Volumio since version 2
At the last update to 2.185
It do not play Webradio
I have an Raspberry Pi 2 and the sounds go out over the chinc to a Box.
In the past its works very good , but since the update it will start but nothing is coming out.
I also get the new Image and make a clean installation.
Nothing helps
thanks for your support
regard Makro
Sorry this means nothing to me.
Can you describe exactly what happens when you try to play a webradio? Are there any error messages? Is it the same problem for a number of streams?
ok
Sorry
my englisch is not the best
but pictures re better then words
me too
I have many webradio on “My web radios”, like Radioswisspop (radioswisspop.ch/live/aacp.m3u)
When I try to play Radioswisspop i can see
after few seconds I can see
Also, if I try to retry Shoucast radio list, nothing happens
Andy
Thanks, please keep on giving informations like this so we can solve the issue
I think Iḿ missing the hole file where to put my be loved radiostations.
@makro do you still have problems playing web radio with 2.193? Because that fixed my webradio problems that I had for few days.
Regards
Sent from my iPhone using Tapatalk
