The same as in former versions:
If Volumio started with USB -Memory it very fast makes an index.
If You restart without the USB-Memory Volumio doesn´t notice the missing
USB device and does not delete the index, means You are able to choose a
file from USB but then it´s a hanging tree and not from Peter Hollens.
