Hey all!
After upgrading to 1.5, I’m not getting “client: Max connections reached” from the MPD service after some time. Once this happens, I can’t browse the library or anything. Thoughts?
Thanks!
Hey all!
Thanks!
The maximum number of connection defines how many connection can occur at the same time. By default this is set at 20. I haven’t had the problem you have. To me it sounds like that the connections are not being terminated.
Some more information about your setup would be welcome. For instance browser, os, other clients.
Sorry… meant to say “I am getting 'client: Max connections reached”.
I didn’t know the max was 20 but I did figure it was from connections not being terminated.
I’m running the default Volumio 1.5 image on a RaspberryPi and just using either IE or Chrome depending if I’m on my PC or phone. I’m hitting the Web UI though and not going to MPD directly so I’m wondering if the teardown or disconnect from the PHP instance to MPD isn’t happening.
Could you, next time you have this issue, do
sudo netstat -a --programs | grep 6600
If connections remain open they should show up here.
Otherwise you can check /var/log/mpd/mpd.log
cat /var/log/mpd/mpd.log
This gives you a (way to) long list of connection that have been opened and closed.
For me this only shows 127.0.0.1 with increasing portnumbers.
Nov 22 20:42 : client: [293] opened from 127.0.0.1:40050
Nov 22 20:42 : client: [293] closed
Nov 22 20:42 : client: [294] opened from 127.0.0.1:40051
Nov 22 20:42 : client: [294] closed
Nov 22 20:43 : client: [295] opened from 127.0.0.1:40052
Nov 22 20:43 : client: [295] closed
IF you scan trough the lines you’ll probably spot lines that “jump out”. those are most interesting
For instance like this
Nov 22 19:57 : client: [2] opened from 127.0.0.1:39649
Nov 22 19:57 : client: [3] opened from 127.0.0.1:39650
Nov 22 19:57 : client: [3] closed
In this example, took it from my own log, client [2] opens, but doesn’t immediately close.
Thanks for the help MobeyDuck!
I hit another “Max connection” issue. Here’s what the netstat shows:
root@volumio:~# sudo netstat -a --programs | grep 6600
tcp 0 0 localhost:6600 *:* LISTEN 2186/mpd
tcp 0 0 localhost:6600 localhost:43057 ESTABLISHED 2186/mpd
tcp 0 0 localhost:59756 localhost:6600 ESTABLISHED 2309/php-fpm: pool
tcp 0 0 localhost:6600 localhost:44426 TIME_WAIT -
tcp 0 0 localhost:6600 localhost:44430 TIME_WAIT -
tcp 0 0 localhost:57114 localhost:6600 ESTABLISHED 2637/upmpdcli
tcp 0 0 localhost:6600 localhost:45947 ESTABLISHED 2186/mpd
tcp 0 0 localhost:6600 localhost:34402 ESTABLISHED 2186/mpd
tcp 0 0 localhost:6600 localhost:37273 ESTABLISHED 2186/mpd
tcp 0 0 localhost:45947 localhost:6600 ESTABLISHED 7558/php-fpm: pool
tcp 0 0 localhost:6600 localhost:44434 TIME_WAIT -
tcp 0 0 localhost:37273 localhost:6600 ESTABLISHED 5225/php-fpm: pool
tcp 0 0 localhost:6600 localhost:57509 ESTABLISHED 2186/mpd
tcp 0 0 localhost:6600 localhost:59756 ESTABLISHED 2186/mpd
tcp 0 0 localhost:6600 localhost:44428 TIME_WAIT -
tcp 0 0 localhost:57509 localhost:6600 ESTABLISHED 2310/php-fpm: pool
tcp 0 0 localhost:6600 localhost:48840 ESTABLISHED 2186/mpd
tcp 0 0 localhost:57108 localhost:6600 ESTABLISHED 2311/php-fpm: pool
tcp 0 0 localhost:6600 localhost:44432 TIME_WAIT -
tcp 0 0 localhost:6600 localhost:57108 ESTABLISHED 2186/mpd
tcp 0 0 localhost:48840 localhost:6600 ESTABLISHED 8734/php-fpm: pool
tcp 0 0 localhost:6600 localhost:40166 ESTABLISHED 2186/mpd
tcp 0 0 localhost:40166 localhost:6600 ESTABLISHED 4193/php-fpm: pool
tcp 0 0 localhost:6600 localhost:57114 ESTABLISHED 2186/mpd
tcp 0 0 localhost:43057 localhost:6600 ESTABLISHED 6533/php-fpm: pool
tcp 0 0 localhost:34402 localhost:6600 ESTABLISHED 3183/php-fpm: pool
Here’s the MPD log right before I started getting a full shutdown from max connections:
Nov 22 19:24 : client: [7022] opened from 127.0.0.1:47714
Nov 22 19:24 : client: [7022] closed
Nov 22 19:24 : client: [7023] opened from 127.0.0.1:47716
Nov 22 19:24 : client: [7023] closed
Nov 22 19:24 : client: [7024] opened from 127.0.0.1:47720
Nov 22 19:24 : client: [7024] closed
Nov 22 19:24 : client: [7025] opened from 127.0.0.1:47722
Nov 22 19:24 : client: [7025] closed
Nov 22 19:24 : client: [7026] opened from 127.0.0.1:47724
Nov 22 19:24 : client: [7026] closed
Nov 22 19:24 : client: [7027] opened from 127.0.0.1:47728
Nov 22 19:24 : client: [7027] closed
Nov 22 19:24 : client: [7028] opened from 127.0.0.1:47730
Nov 22 19:24 : client: [7028] closed
Nov 22 19:24 : client: [7029] opened from 127.0.0.1:47732
Nov 22 19:24 : client: [7029] closed
Nov 22 19:24 : client: [7030] opened from 127.0.0.1:47736
Nov 22 19:24 : client: [7030] closed
Nov 22 19:24 : client: [7031] opened from 127.0.0.1:47738
Nov 22 19:24 : client: [7031] closed
Nov 22 19:24 : client: [7032] opened from 127.0.0.1:47740
Nov 22 19:24 : client: [7032] closed
Nov 22 19:24 : client: [7033] opened from 127.0.0.1:47744
Nov 22 19:24 : client: [7033] closed
Nov 22 19:24 : client: [7034] opened from 127.0.0.1:47746
Nov 22 19:24 : client: [7034] closed
Nov 22 19:24 : client: [7035] opened from 127.0.0.1:47748
Nov 22 19:24 : client: [7035] closed
Nov 22 19:24 : client: [7036] opened from 127.0.0.1:47752
Nov 22 19:24 : client: [7036] closed
Nov 22 19:24 : client: [7037] opened from 127.0.0.1:47754
Nov 22 19:24 : client: [7037] closed
Nov 22 19:24 : client: [7038] opened from 127.0.0.1:47756
Nov 22 19:24 : client: [7038] closed
Nov 22 19:25 : client: [7039] opened from 127.0.0.1:47760
Nov 22 19:25 : client: [7039] closed
Nov 22 19:25 : client: [7040] opened from 127.0.0.1:47762
Nov 22 19:25 : client: [7040] closed
Nov 22 19:25 : client: [7041] opened from 127.0.0.1:47764
Nov 22 19:25 : client: [7041] closed
Nov 22 19:25 : client: [7042] opened from 127.0.0.1:47768
Nov 22 19:25 : client: [7042] closed
Nov 22 19:25 : client: [7043] opened from 127.0.0.1:47770
Nov 22 19:25 : client: [7043] closed
Nov 22 19:25 : client: [7044] opened from 127.0.0.1:47772
Nov 22 19:25 : client: [7044] closed
Nov 22 19:25 : client: [7045] opened from 127.0.0.1:47776
Nov 22 19:25 : client: [7045] closed
Nov 22 19:25 : client: [7046] opened from 127.0.0.1:47778
Nov 22 19:25 : client: [7046] closed
Nov 22 19:25 : client: [7047] opened from 127.0.0.1:47780
Nov 22 19:25 : client: [7047] closed
Nov 22 19:25 : client: [7048] opened from 127.0.0.1:47784
Nov 22 19:25 : client: [7048] closed
Nov 22 19:25 : client: [7049] opened from 127.0.0.1:47786
Nov 22 19:25 : client: [7049] closed
Nov 22 19:25 : client: [7050] opened from 127.0.0.1:47788
Nov 22 19:25 : client: [7050] closed
Nov 22 19:25 : client: [7051] opened from 127.0.0.1:47792
Nov 22 19:25 : client: [7051] closed
Nov 22 19:25 : client: [7052] opened from 127.0.0.1:47794
Nov 22 19:25 : client: [7052] closed
Nov 22 19:25 : client: [7053] opened from 127.0.0.1:47796
Nov 22 19:25 : client: [7053] closed
Nov 22 19:25 : client: [7054] opened from 127.0.0.1:47800
Nov 22 19:25 : client: [7054] closed
Nov 22 19:25 : client: [7055] opened from 127.0.0.1:47802
Nov 22 19:25 : client: [7055] closed
Nov 22 19:25 : client: [7056] opened from 127.0.0.1:47804
Nov 22 19:25 : client: [7056] closed
Nov 22 19:26 : client: [7057] opened from 127.0.0.1:47808
Nov 22 19:26 : client: [7057] closed
Nov 22 19:26 : client: [7058] opened from 127.0.0.1:47810
Nov 22 19:26 : client: [7058] closed
Nov 22 19:26 : client: [7059] opened from 127.0.0.1:47812
Nov 22 19:26 : client: [7059] closed
Nov 22 19:26 : client: [7060] opened from 127.0.0.1:47816
Nov 22 19:26 : client: [7060] closed
Nov 22 19:26 : client: [7061] opened from 127.0.0.1:47818
Nov 22 19:26 : client: [7061] closed
Nov 22 19:26 : client: [7062] opened from 127.0.0.1:47820
Nov 22 19:26 : client: [7062] closed
Nov 22 19:26 : client: [7063] opened from 127.0.0.1:47824
Nov 22 19:26 : client: [7063] closed
Nov 22 19:26 : client: [7064] opened from 127.0.0.1:47826
Nov 22 19:26 : client: [7064] closed
Nov 22 19:26 : client: [7065] opened from 127.0.0.1:47828
Nov 22 19:26 : client: [7065] closed
Nov 22 19:26 : client: [7066] opened from 127.0.0.1:47832
Nov 22 19:26 : client: [7066] closed
Nov 22 19:26 : client: [7067] opened from 127.0.0.1:47834
Nov 22 19:26 : client: [7067] closed
Nov 22 19:26 : client: [7068] opened from 127.0.0.1:47836
Nov 22 19:26 : client: [7068] closed
Nov 22 19:26 : client: [7069] opened from 127.0.0.1:47840
Nov 22 19:26 : client: [7069] closed
Nov 22 19:26 : client: [7070] opened from 127.0.0.1:47842
Nov 22 19:26 : client: [7070] closed
Nov 22 19:26 : client: [7071] opened from 127.0.0.1:47844
Nov 22 19:26 : client: [7071] closed
Nov 22 19:26 : client: [7072] opened from 127.0.0.1:47848
Nov 22 19:26 : client: [7072] closed
Nov 22 19:26 : client: [7073] opened from 127.0.0.1:47850
Nov 22 19:26 : client: [7073] closed
Nov 22 19:26 : client: [7074] opened from 127.0.0.1:47852
Nov 22 19:26 : client: [7074] closed
Nov 22 19:27 : client: [7075] opened from 127.0.0.1:47856
Nov 22 19:27 : client: [7075] closed
Nov 22 19:27 : client: [7076] opened from 127.0.0.1:47858
Nov 22 19:27 : client: [7076] closed
Nov 22 19:27 : client: [7077] opened from 127.0.0.1:47861
Nov 22 19:27 : client: [7077] closed
Nov 22 19:27 : client: [7078] opened from 127.0.0.1:47864
Nov 22 19:27 : client: [7078] closed
Nov 22 19:27 : client: [7079] opened from 127.0.0.1:47866
Nov 22 19:27 : client: [7079] closed
Nov 22 19:27 : client: [7080] opened from 127.0.0.1:47869
Nov 22 19:27 : client: [7080] closed
Nov 22 19:27 : client: [7081] opened from 127.0.0.1:47872
Nov 22 19:27 : client: [7081] closed
Nov 22 19:27 : client: [7082] opened from 127.0.0.1:47874
Nov 22 19:27 : client: [7082] closed
Nov 22 19:27 : client: [7083] opened from 127.0.0.1:47877
Nov 22 19:27 : client: [7083] closed
Nov 22 19:27 : client: [7084] opened from 127.0.0.1:47880
Nov 22 19:27 : client: [7084] closed
Nov 22 19:27 : client: [7085] opened from 127.0.0.1:47882
Nov 22 19:27 : client: [7085] closed
Nov 22 19:27 : client: [7086] opened from 127.0.0.1:47885
Nov 22 19:27 : client: [7086] closed
Nov 22 19:27 : client: [7087] opened from 127.0.0.1:47888
Nov 22 19:27 : client: [7087] closed
Nov 22 19:27 : client: [7088] opened from 127.0.0.1:47890
Nov 22 19:27 : client: [7088] closed
Nov 22 19:27 : client: [7089] opened from 127.0.0.1:47893
Nov 22 19:27 : client: [7089] closed
Nov 22 19:27 : client: [7090] opened from 127.0.0.1:47895
Nov 22 19:27 : client: [7090] closed
Nov 22 19:27 : client: [7091] opened from 127.0.0.1:47897
Nov 22 19:27 : client: [7091] closed
Nov 22 19:27 : client: [7092] opened from 127.0.0.1:47901
Nov 22 19:27 : client: [7092] closed
Nov 22 19:28 : client: [7093] opened from 127.0.0.1:47903
Nov 22 19:28 : client: [7093] closed
Nov 22 19:28 : client: [7094] opened from 127.0.0.1:47905
Nov 22 19:28 : client: [7094] closed
Nov 22 19:28 : client: [7095] opened from 127.0.0.1:47909
Nov 22 19:28 : client: [7095] closed
Nov 22 19:28 : client: [7096] opened from 127.0.0.1:47911
Nov 22 19:28 : client: Max connections reached
Nov 22 19:28 : client: [7096] closed
Nov 22 19:28 : client: [7097] opened from 127.0.0.1:47917
Nov 22 19:28 : client: [7097] closed
Nov 22 19:28 : client: [7098] opened from 127.0.0.1:47919
Nov 22 19:28 : client: [7098] closed
Nov 22 19:28 : client: [7099] opened from 127.0.0.1:47921
Nov 22 19:28 : client: [7099] closed
Nov 22 19:28 : client: [7100] opened from 127.0.0.1:47925
Nov 22 19:28 : client: [7100] closed
Nov 22 19:28 : client: [7101] opened from 127.0.0.1:47927
Nov 22 19:28 : client: [7101] closed
Nov 22 19:28 : client: [7102] opened from 127.0.0.1:47935
Nov 22 19:28 : client: [7102] closed
Nov 22 19:28 : client: [7103] opened from 127.0.0.1:47937
Nov 22 19:28 : client: [7103] closed
Nov 22 19:28 : client: [7104] opened from 127.0.0.1:47943
Nov 22 19:28 : client: [7104] closed
Nov 22 19:28 : client: [7105] opened from 127.0.0.1:47946
Nov 22 19:28 : client: [7105] closed
Nov 22 19:28 : client: [7106] opened from 127.0.0.1:47947
Nov 22 19:28 : client: [7106] closed
Nov 22 19:28 : client: [7107] opened from 127.0.0.1:47951
Nov 22 19:28 : client: [7107] closed
Nov 22 19:29 : client: [7108] opened from 127.0.0.1:47953
Nov 22 19:29 : client: [7108] closed
Nov 22 19:29 : client: [7109] opened from 127.0.0.1:47955
Nov 22 19:29 : client: [7109] closed
Nov 22 19:29 : client: [7110] opened from 127.0.0.1:47959
Nov 22 19:29 : client: [7110] closed
Nov 22 19:29 : client: [7111] opened from 127.0.0.1:47961
Nov 22 19:29 : client: [7111] closed
Nov 22 19:29 : client: [7112] opened from 127.0.0.1:47963
Nov 22 19:29 : client: [7112] closed
Nov 22 19:29 : client: [7113] opened from 127.0.0.1:47967
Nov 22 19:29 : client: [7113] closed
Nov 22 19:29 : client: [7114] opened from 127.0.0.1:47969
Nov 22 19:29 : client: [7114] closed
Nov 22 19:29 : client: [7115] opened from 127.0.0.1:47971
Nov 22 19:29 : client: [7115] closed
Nov 22 19:29 : client: [7116] opened from 127.0.0.1:47975
Nov 22 19:29 : client: [7116] closed
Nov 22 19:29 : client: [7117] opened from 127.0.0.1:47977
Nov 22 19:29 : client: [7117] closed
Nov 22 19:29 : client: [7118] opened from 127.0.0.1:47979
Nov 22 19:29 : client: [7118] closed
Nov 22 19:29 : client: [7119] opened from 127.0.0.1:47983
Nov 22 19:29 : client: [7119] closed
Nov 22 19:29 : client: [7120] opened from 127.0.0.1:47985
Nov 22 19:29 : client: [7120] closed
Nov 22 19:29 : client: [7121] opened from 127.0.0.1:47987
Nov 22 19:29 : client: [7121] closed
Nov 22 19:29 : client: [7122] opened from 127.0.0.1:47991
Nov 22 19:29 : client: [7122] closed
Nov 22 19:29 : client: [7123] opened from 127.0.0.1:47993
Nov 22 19:29 : client: [7123] closed
Nov 22 19:29 : client: [7124] opened from 127.0.0.1:47995
Nov 22 19:29 : client: [7124] closed
Nov 22 19:29 : client: [7125] opened from 127.0.0.1:47999
Nov 22 19:29 : client: [7125] closed
Nov 22 19:30 : client: [7126] opened from 127.0.0.1:48001
Nov 22 19:30 : client: [7126] closed
Nov 22 19:30 : client: [7127] opened from 127.0.0.1:48003
Nov 22 19:30 : client: [7127] closed
Nov 22 19:30 : client: [7128] opened from 127.0.0.1:48007
Nov 22 19:30 : client: [7128] closed
Nov 22 19:30 : client: [7129] opened from 127.0.0.1:48009
Nov 22 19:30 : client: [7129] closed
Nov 22 19:30 : client: [7130] opened from 127.0.0.1:48011
Nov 22 19:30 : client: [7130] closed
Nov 22 19:30 : client: [7131] opened from 127.0.0.1:48015
Nov 22 19:30 : client: [7131] closed
Nov 22 19:30 : client: [7132] opened from 127.0.0.1:48017
Nov 22 19:30 : client: [7132] closed
Nov 22 19:30 : client: [7133] opened from 127.0.0.1:48019
Nov 22 19:30 : client: [7133] closed
Nov 22 19:30 : client: [7134] opened from 127.0.0.1:48023
Nov 22 19:30 : client: [7134] closed
Nov 22 19:30 : client: [7135] opened from 127.0.0.1:48025
Nov 22 19:30 : client: [7135] closed
Nov 22 19:30 : client: [7136] opened from 127.0.0.1:48027
Nov 22 19:30 : client: [7136] closed
Nov 22 19:30 : client: [7137] opened from 127.0.0.1:48031
Nov 22 19:30 : client: [7137] closed
Nov 22 19:30 : client: [7138] opened from 127.0.0.1:48033
Nov 22 19:30 : client: [7138] closed
Nov 22 19:30 : client: [7139] opened from 127.0.0.1:48035
Nov 22 19:30 : client: [7139] closed
Nov 22 19:30 : client: [7140] opened from 127.0.0.1:48039
Nov 22 19:30 : client: [7140] closed
Nov 22 19:30 : client: [7141] opened from 127.0.0.1:48041
Nov 22 19:30 : client: [7141] closed
Nov 22 19:30 : client: [7142] opened from 127.0.0.1:48043
Nov 22 19:30 : client: [7142] closed
Nov 22 19:30 : client: [7143] opened from 127.0.0.1:48047
Nov 22 19:30 : client: [7143] closed
Nov 22 19:31 : client: [7144] opened from 127.0.0.1:48049
Nov 22 19:31 : client: [7144] closed
Nov 22 19:31 : client: [7145] opened from 127.0.0.1:48051
Nov 22 19:31 : client: [7145] closed
Nov 22 19:31 : client: [7146] opened from 127.0.0.1:48055
Nov 22 19:31 : client: [7146] closed
Nov 22 19:31 : client: [7147] opened from 127.0.0.1:48057
Nov 22 19:31 : client: [7147] closed
Nov 22 19:31 : client: [7148] opened from 127.0.0.1:48059
Nov 22 19:31 : client: [7148] closed
Nov 22 19:31 : client: [7149] opened from 127.0.0.1:48063
Nov 22 19:31 : client: [7149] closed
Nov 22 19:31 : client: [7150] opened from 127.0.0.1:48065
Nov 22 19:31 : client: [7150] closed
Nov 22 19:31 : client: [7151] opened from 127.0.0.1:48067
Nov 22 19:31 : client: [7151] closed
Nov 22 19:31 : client: [7152] opened from 127.0.0.1:48071
Nov 22 19:31 : client: [7152] closed
Nov 22 19:31 : client: [7153] opened from 127.0.0.1:48073
Nov 22 19:31 : client: [7153] closed
Nov 22 19:31 : client: [7154] opened from 127.0.0.1:48075
Nov 22 19:31 : client: [7154] closed
Nov 22 19:31 : client: [7155] opened from 127.0.0.1:48079
Nov 22 19:31 : client: [7155] closed
Nov 22 19:31 : client: [7156] opened from 127.0.0.1:48081
Nov 22 19:31 : client: [7156] closed
Nov 22 19:31 : client: [7157] opened from 127.0.0.1:48083
Nov 22 19:31 : client: [7157] closed
Nov 22 19:31 : client: [7158] opened from 127.0.0.1:48087
Nov 22 19:31 : client: [7158] closed
Nov 22 19:31 : client: [7159] opened from 127.0.0.1:48089
Nov 22 19:31 : client: [7159] closed
Nov 22 19:31 : client: [7160] opened from 127.0.0.1:48092
Nov 22 19:31 : client: [7160] closed
Nov 22 19:32 : client: [7161] opened from 127.0.0.1:48096
Nov 22 19:32 : client: [7161] closed
Nov 22 19:32 : client: [7162] opened from 127.0.0.1:48098
Nov 22 19:32 : client: [7162] closed
Nov 22 19:32 : client: [7163] opened from 127.0.0.1:48100
Nov 22 19:32 : client: [7163] closed
Nov 22 19:32 : client: [7164] opened from 127.0.0.1:48104
Nov 22 19:32 : client: [7164] closed
Nov 22 19:32 : client: [7165] opened from 127.0.0.1:48106
Nov 22 19:32 : client: [7165] closed
Nov 22 19:32 : client: [7166] opened from 127.0.0.1:48108
Nov 22 19:32 : client: [7166] closed
Nov 22 19:32 : client: [7167] opened from 127.0.0.1:48112
Nov 22 19:32 : client: [7167] closed
Nov 22 19:32 : client: [7168] opened from 127.0.0.1:48114
Nov 22 19:32 : client: [7168] closed
Nov 22 19:32 : client: [7169] opened from 127.0.0.1:48116
Nov 22 19:32 : client: [7169] closed
Nov 22 19:32 : client: [7170] opened from 127.0.0.1:48120
Nov 22 19:32 : client: [7170] closed
Nov 22 19:32 : client: [7171] opened from 127.0.0.1:48122
Nov 22 19:32 : client: [7171] closed
Nov 22 19:32 : client: [7172] opened from 127.0.0.1:48124
Nov 22 19:32 : client: [7172] closed
Nov 22 19:32 : client: [7173] opened from 127.0.0.1:48128
Nov 22 19:32 : client: [7173] closed
Nov 22 19:32 : client: [7174] opened from 127.0.0.1:48130
Nov 22 19:32 : client: [7174] closed
Nov 22 19:32 : client: [7175] opened from 127.0.0.1:48132
Nov 22 19:32 : client: [7175] closed
Nov 22 19:32 : client: [7176] opened from 127.0.0.1:48136
Nov 22 19:32 : client: [7176] closed
Nov 22 19:32 : client: [7177] opened from 127.0.0.1:48138
Nov 22 19:32 : client: [7177] closed
Nov 22 19:32 : client: [7178] opened from 127.0.0.1:48140
Nov 22 19:32 : client: [7178] closed
Nov 22 19:33 : client: [7179] opened from 127.0.0.1:48144
Nov 22 19:33 : client: [7179] closed
Nov 22 19:33 : client: [7180] opened from 127.0.0.1:48146
Nov 22 19:33 : client: [7180] closed
Nov 22 19:33 : client: [7181] opened from 127.0.0.1:48148
Nov 22 19:33 : client: [7181] closed
Nov 22 19:33 : client: [7182] opened from 127.0.0.1:48152
Nov 22 19:33 : client: [7182] closed
Nov 22 19:33 : client: [7183] opened from 127.0.0.1:48154
Nov 22 19:33 : client: [7183] closed
Nov 22 19:33 : client: [7184] opened from 127.0.0.1:48156
Nov 22 19:33 : client: [7184] closed
Nov 22 19:33 : client: [7185] opened from 127.0.0.1:48160
Nov 22 19:33 : client: [7185] closed
Nov 22 19:33 : client: [7186] opened from 127.0.0.1:48162
Nov 22 19:33 : client: [7186] closed
Nov 22 19:33 : client: [7187] opened from 127.0.0.1:48164
Nov 22 19:33 : client: [7187] closed
Nov 22 19:33 : client: [7188] opened from 127.0.0.1:48168
Nov 22 19:33 : client: [7188] closed
Nov 22 19:33 : client: [7189] opened from 127.0.0.1:48170
Nov 22 19:33 : client: [7189] closed
Nov 22 19:33 : client: [7190] opened from 127.0.0.1:48172
Nov 22 19:33 : client: [7190] closed
Nov 22 19:33 : client: [7191] opened from 127.0.0.1:48176
Nov 22 19:33 : client: [7191] closed
Nov 22 19:33 : client: [7192] opened from 127.0.0.1:48178
Nov 22 19:33 : client: [7192] closed
Nov 22 19:33 : client: [7193] opened from 127.0.0.1:48180
Nov 22 19:33 : client: [7193] closed
Nov 22 19:33 : client: [7194] opened from 127.0.0.1:48184
Nov 22 19:33 : client: [7194] closed
Nov 22 19:33 : client: [7195] opened from 127.0.0.1:48186
Nov 22 19:33 : client: [7195] closed
Nov 22 19:33 : client: [7196] opened from 127.0.0.1:48188
Nov 22 19:33 : client: [7196] closed
Nov 22 19:34 : client: [7197] opened from 127.0.0.1:48192
Nov 22 19:34 : client: [7197] closed
Nov 22 19:34 : client: [7198] opened from 127.0.0.1:48194
Nov 22 19:34 : client: [7198] closed
Nov 22 19:34 : client: [7199] opened from 127.0.0.1:48196
Nov 22 19:34 : client: [7199] closed
Nov 22 19:34 : client: [7200] opened from 127.0.0.1:48200
Nov 22 19:34 : client: [7200] closed
Nov 22 19:34 : client: [7201] opened from 127.0.0.1:48202
Nov 22 19:34 : client: [7201] closed
Nov 22 19:34 : client: [7202] opened from 127.0.0.1:48204
Nov 22 19:34 : client: [7202] closed
Nov 22 19:34 : client: [7203] opened from 127.0.0.1:48208
Nov 22 19:34 : client: [7203] closed
Nov 22 19:34 : client: [7204] opened from 127.0.0.1:48210
Nov 22 19:34 : client: [7204] closed
Nov 22 19:34 : client: [7205] opened from 127.0.0.1:48212
Nov 22 19:34 : client: [7205] closed
Nov 22 19:34 : client: [7206] opened from 127.0.0.1:48216
Nov 22 19:34 : client: [7206] closed
Nov 22 19:34 : client: [7207] opened from 127.0.0.1:48218
Nov 22 19:34 : client: [7207] closed
Nov 22 19:34 : client: [7208] opened from 127.0.0.1:48220
Nov 22 19:34 : client: [7208] closed
Nov 22 19:34 : client: [7209] opened from 127.0.0.1:48224
Nov 22 19:34 : client: [7209] closed
Nov 22 19:34 : client: [7210] opened from 127.0.0.1:48226
Nov 22 19:34 : client: [7210] closed
Nov 22 19:34 : client: [7211] opened from 127.0.0.1:48228
Nov 22 19:34 : client: [7211] closed
Nov 22 19:34 : client: [7212] opened from 127.0.0.1:48232
Nov 22 19:34 : client: [7212] closed
Nov 22 19:34 : client: [7213] opened from 127.0.0.1:48234
Nov 22 19:34 : client: [7213] closed
Nov 22 19:34 : client: [7214] opened from 127.0.0.1:48236
Nov 22 19:34 : client: [7214] closed
Nov 22 19:35 : client: [7215] opened from 127.0.0.1:48240
Nov 22 19:35 : client: [7215] closed
Nov 22 19:35 : client: [7216] opened from 127.0.0.1:48242
Nov 22 19:35 : client: [7216] closed
Nov 22 19:35 : client: [7217] opened from 127.0.0.1:48244
Nov 22 19:35 : client: [7217] closed
Nov 22 19:35 : client: [7218] opened from 127.0.0.1:48254
Nov 22 19:35 : client: [7218] closed
Nov 22 19:35 : client: [7219] opened from 127.0.0.1:48256
Nov 22 19:35 : client: [7219] closed
Nov 22 19:35 : client: [7220] opened from 127.0.0.1:48258
Nov 22 19:35 : client: [7220] closed
Nov 22 19:35 : client: [7221] opened from 127.0.0.1:48262
Nov 22 19:35 : client: [7221] closed
Nov 22 19:35 : client: [7222] opened from 127.0.0.1:48264
Nov 22 19:35 : client: [7222] closed
Nov 22 19:35 : client: [7223] opened from 127.0.0.1:48266
Nov 22 19:35 : client: [7223] closed
Nov 22 19:35 : client: [7224] opened from 127.0.0.1:48270
Nov 22 19:35 : client: [7224] closed
Nov 22 19:35 : client: [7225] opened from 127.0.0.1:48272
Nov 22 19:35 : client: [7225] closed
Nov 22 19:35 : client: [7226] opened from 127.0.0.1:48274
Nov 22 19:35 : client: [7226] closed
Nov 22 19:35 : client: [7227] opened from 127.0.0.1:48278
Nov 22 19:35 : client: [7227] closed
Nov 22 19:35 : client: [7228] opened from 127.0.0.1:48280
Nov 22 19:35 : client: [7228] closed
Nov 22 19:35 : client: [7229] opened from 127.0.0.1:48282
Nov 22 19:35 : client: [7229] closed
Nov 22 19:35 : client: [7230] opened from 127.0.0.1:48286
Nov 22 19:35 : client: [7230] closed
Nov 22 19:35 : client: [7231] opened from 127.0.0.1:48288
Nov 22 19:35 : client: [7231] closed
Nov 22 19:35 : client: [7232] opened from 127.0.0.1:48290
Nov 22 19:35 : client: [7232] closed
Nov 22 19:36 : client: [7233] opened from 127.0.0.1:48294
Nov 22 19:36 : client: [7233] closed
Nov 22 19:36 : client: [7234] opened from 127.0.0.1:48296
Nov 22 19:36 : client: [7234] closed
Nov 22 19:36 : client: [7235] opened from 127.0.0.1:48298
Nov 22 19:36 : client: [7235] closed
Nov 22 19:36 : client: [7236] opened from 127.0.0.1:48302
Nov 22 19:36 : client: [7236] closed
Nov 22 19:36 : client: [7237] opened from 127.0.0.1:48304
Nov 22 19:36 : client: [7237] closed
Nov 22 19:36 : client: [7238] opened from 127.0.0.1:48306
Nov 22 19:36 : client: [7238] closed
Nov 22 19:36 : client: [7239] opened from 127.0.0.1:48310
Nov 22 19:36 : client: [7239] closed
Nov 22 19:36 : client: [7240] opened from 127.0.0.1:48312
Nov 22 19:36 : client: [7240] closed
Nov 22 19:36 : client: [7241] opened from 127.0.0.1:48314
Nov 22 19:36 : client: [7241] closed
Nov 22 19:36 : client: [7242] opened from 127.0.0.1:48318
Nov 22 19:36 : client: [7242] closed
Nov 22 19:36 : client: [7243] opened from 127.0.0.1:48320
Nov 22 19:36 : client: [7243] closed
Nov 22 19:36 : client: [7244] opened from 127.0.0.1:48322
Nov 22 19:36 : client: [7244] closed
Nov 22 19:36 : client: [7245] opened from 127.0.0.1:48326
Nov 22 19:36 : client: [7245] closed
Nov 22 19:36 : client: [7246] opened from 127.0.0.1:48328
Nov 22 19:36 : client: [7246] closed
Nov 22 19:36 : client: [7247] opened from 127.0.0.1:48330
Nov 22 19:36 : client: [7247] closed
Nov 22 19:36 : client: [7248] opened from 127.0.0.1:48334
Nov 22 19:36 : client: [7248] closed
Nov 22 19:36 : client: [7249] opened from 127.0.0.1:48336
Nov 22 19:36 : client: [7249] closed
Nov 22 19:36 : client: [7250] opened from 127.0.0.1:48338
Nov 22 19:36 : client: [7250] closed
Nov 22 19:37 : client: [7251] opened from 127.0.0.1:48342
Nov 22 19:37 : client: [7251] closed
Nov 22 19:37 : client: [7252] opened from 127.0.0.1:48344
Nov 22 19:37 : client: [7252] closed
Nov 22 19:37 : client: [7253] opened from 127.0.0.1:48346
Nov 22 19:37 : client: [7253] closed
Nov 22 19:37 : client: [7254] opened from 127.0.0.1:48350
Nov 22 19:37 : client: [7254] closed
Nov 22 19:37 : client: [7255] opened from 127.0.0.1:48352
Nov 22 19:37 : client: [7255] closed
Nov 22 19:37 : client: [7256] opened from 127.0.0.1:48354
Nov 22 19:37 : client: [7256] closed
Nov 22 19:37 : client: [7257] opened from 127.0.0.1:48358
Nov 22 19:37 : client: [7257] closed
Nov 22 19:37 : client: [7258] opened from 127.0.0.1:48360
Nov 22 19:37 : client: [7258] closed
Nov 22 19:37 : client: [7259] opened from 127.0.0.1:48362
Nov 22 19:37 : client: [7259] closed
Nov 22 19:37 : client: [7260] opened from 127.0.0.1:48366
Nov 22 19:37 : client: [7260] closed
Nov 22 19:37 : client: [7261] opened from 127.0.0.1:48368
Nov 22 19:37 : client: [7261] closed
Nov 22 19:37 : client: [7262] opened from 127.0.0.1:48370
Nov 22 19:37 : client: [7262] closed
Nov 22 19:37 : client: [7263] opened from 127.0.0.1:48374
Nov 22 19:37 : client: [7263] closed
Nov 22 19:37 : client: [7264] opened from 127.0.0.1:48376
Nov 22 19:37 : client: [7264] closed
Nov 22 19:37 : client: [7265] opened from 127.0.0.1:48378
Nov 22 19:37 : client: [7265] closed
Nov 22 19:37 : client: [7266] opened from 127.0.0.1:48382
Nov 22 19:37 : client: [7266] closed
Nov 22 19:37 : client: [7267] opened from 127.0.0.1:48384
Nov 22 19:37 : client: [7267] closed
Nov 22 19:37 : client: [7268] opened from 127.0.0.1:48386
Nov 22 19:37 : client: [7268] closed
Nov 22 19:38 : client: [7269] opened from 127.0.0.1:48390
Nov 22 19:38 : client: [7269] closed
Nov 22 19:38 : client: [7270] opened from 127.0.0.1:48392
Nov 22 19:38 : client: [7270] closed
Nov 22 19:38 : client: [7271] opened from 127.0.0.1:48394
Nov 22 19:38 : client: [7271] closed
Nov 22 19:38 : client: [7272] opened from 127.0.0.1:48398
Nov 22 19:38 : client: [7272] closed
Nov 22 19:38 : client: [7273] opened from 127.0.0.1:48400
Nov 22 19:38 : client: [7273] closed
Nov 22 19:38 : client: [7274] opened from 127.0.0.1:48402
Nov 22 19:38 : client: [7274] closed
Nov 22 19:38 : client: [7275] opened from 127.0.0.1:48406
Nov 22 19:38 : client: [7275] closed
Nov 22 19:38 : client: [7276] opened from 127.0.0.1:48408
Nov 22 19:38 : client: [7276] closed
Nov 22 19:38 : client: [7277] opened from 127.0.0.1:48410
Nov 22 19:38 : client: [7277] closed
Nov 22 19:38 : client: [7278] opened from 127.0.0.1:48414
Nov 22 19:38 : client: [7278] closed
Nov 22 19:38 : client: [7279] opened from 127.0.0.1:48416
Nov 22 19:38 : client: [7279] closed
Nov 22 19:38 : client: [7280] opened from 127.0.0.1:48418
Nov 22 19:38 : client: [7280] closed
Nov 22 19:38 : client: [7281] opened from 127.0.0.1:48422
Nov 22 19:38 : client: [7281] closed
Nov 22 19:38 : client: [7282] opened from 127.0.0.1:48424
Nov 22 19:38 : client: [7282] closed
Nov 22 19:38 : client: [7283] opened from 127.0.0.1:48426
Nov 22 19:38 : client: [7283] closed
Nov 22 19:38 : client: [7284] opened from 127.0.0.1:48430
Nov 22 19:38 : client: [7284] closed
Nov 22 19:38 : client: [7285] opened from 127.0.0.1:48432
Nov 22 19:38 : client: [7285] closed
Nov 22 19:38 : client: [7286] opened from 127.0.0.1:48434
Nov 22 19:38 : client: [7286] closed
Nov 22 19:39 : client: [7287] opened from 127.0.0.1:48438
Nov 22 19:39 : client: [7287] closed
Nov 22 19:39 : client: [7288] opened from 127.0.0.1:48440
Nov 22 19:39 : client: [7288] closed
Nov 22 19:39 : client: [7289] opened from 127.0.0.1:48442
Nov 22 19:39 : client: [7289] closed
Nov 22 19:39 : client: [7290] opened from 127.0.0.1:48446
Nov 22 19:39 : client: [7290] closed
Nov 22 19:39 : client: [7291] opened from 127.0.0.1:48448
Nov 22 19:39 : client: [7291] closed
Nov 22 19:39 : client: [7292] opened from 127.0.0.1:48450
Nov 22 19:39 : client: [7292] closed
Nov 22 19:39 : client: [7293] opened from 127.0.0.1:48454
Nov 22 19:39 : client: [7293] closed
Nov 22 19:39 : client: [7294] opened from 127.0.0.1:48456
Nov 22 19:39 : client: [7294] closed
Nov 22 19:39 : client: [7295] opened from 127.0.0.1:48458
Nov 22 19:39 : client: [7295] closed
Nov 22 19:39 : client: [7296] opened from 127.0.0.1:48462
Nov 22 19:39 : client: [7296] closed
Nov 22 19:39 : client: [7297] opened from 127.0.0.1:48464
Nov 22 19:39 : client: [7297] closed
Nov 22 19:39 : client: [7298] opened from 127.0.0.1:48466
Nov 22 19:39 : client: [7298] closed
Nov 22 19:39 : client: [7299] opened from 127.0.0.1:48470
Nov 22 19:39 : client: [7299] closed
Nov 22 19:39 : client: [7300] opened from 127.0.0.1:48472
Nov 22 19:39 : client: [7300] closed
Nov 22 19:39 : client: [7301] opened from 127.0.0.1:48474
Nov 22 19:39 : client: [7301] closed
Nov 22 19:39 : client: [7302] opened from 127.0.0.1:48478
Nov 22 19:39 : client: [7302] closed
Nov 22 19:39 : client: [7303] opened from 127.0.0.1:48480
Nov 22 19:39 : client: [7303] closed
Nov 22 19:40 : client: [7304] opened from 127.0.0.1:48482
Nov 22 19:40 : client: [7304] closed
Nov 22 19:40 : client: [7305] opened from 127.0.0.1:48486
Nov 22 19:40 : client: [7305] closed
Nov 22 19:40 : client: [7306] opened from 127.0.0.1:48488
Nov 22 19:40 : client: [7306] closed
Nov 22 19:40 : client: [7307] opened from 127.0.0.1:48490
Nov 22 19:40 : client: [7307] closed
Nov 22 19:40 : client: [7308] opened from 127.0.0.1:48494
Nov 22 19:40 : client: [7308] closed
Nov 22 19:40 : client: [7309] opened from 127.0.0.1:48496
Nov 22 19:40 : client: [7309] closed
Nov 22 19:40 : client: [7310] opened from 127.0.0.1:48498
Nov 22 19:40 : client: [7310] closed
Nov 22 19:40 : client: [7311] opened from 127.0.0.1:48502
Nov 22 19:40 : client: [7311] closed
Nov 22 19:40 : client: [7312] opened from 127.0.0.1:48504
Nov 22 19:40 : client: [7312] closed
Nov 22 19:40 : client: [7313] opened from 127.0.0.1:48506
Nov 22 19:40 : client: [7313] closed
Nov 22 19:40 : client: [7314] opened from 127.0.0.1:48510
Nov 22 19:40 : client: [7314] closed
Nov 22 19:40 : client: [7315] opened from 127.0.0.1:48512
Nov 22 19:40 : client: [7315] closed
Nov 22 19:40 : client: [7316] opened from 127.0.0.1:48514
Nov 22 19:40 : client: [7316] closed
Nov 22 19:40 : client: [7317] opened from 127.0.0.1:48518
Nov 22 19:40 : client: [7317] closed
Nov 22 19:40 : client: [7318] opened from 127.0.0.1:48520
Nov 22 19:40 : client: [7318] closed
Nov 22 19:40 : client: [7319] opened from 127.0.0.1:48522
Nov 22 19:40 : client: [7319] closed
Nov 22 19:40 : client: [7320] opened from 127.0.0.1:48526
Nov 22 19:40 : client: [7320] closed
Nov 22 19:40 : client: [7321] opened from 127.0.0.1:48528
Nov 22 19:40 : client: [7321] closed
Nov 22 19:41 : client: [7322] opened from 127.0.0.1:48530
Nov 22 19:41 : client: [7322] closed
Nov 22 19:41 : client: [7323] opened from 127.0.0.1:48534
Nov 22 19:41 : client: [7323] closed
Nov 22 19:41 : client: [7324] opened from 127.0.0.1:48536
Nov 22 19:41 : client: [7324] closed
Nov 22 19:41 : client: [7325] opened from 127.0.0.1:48538
Nov 22 19:41 : client: [7325] closed
Nov 22 19:41 : client: [7326] opened from 127.0.0.1:48542
Nov 22 19:41 : client: [7326] closed
Nov 22 19:41 : client: [7327] opened from 127.0.0.1:48544
Nov 22 19:41 : client: [7327] closed
Nov 22 19:41 : client: [7328] opened from 127.0.0.1:48546
Nov 22 19:41 : client: [7328] closed
Nov 22 19:41 : client: [7329] opened from 127.0.0.1:48550
Nov 22 19:41 : client: [7329] closed
Nov 22 19:41 : client: [7330] opened from 127.0.0.1:48552
Nov 22 19:41 : client: [7330] closed
Nov 22 19:41 : client: [7331] opened from 127.0.0.1:48554
Nov 22 19:41 : client: [7331] closed
Nov 22 19:41 : client: [7332] opened from 127.0.0.1:48560
Nov 22 19:41 : client: [7332] closed
Nov 22 19:41 : client: [7333] opened from 127.0.0.1:48562
Nov 22 19:41 : client: [7333] closed
Nov 22 19:41 : client: [7334] opened from 127.0.0.1:48564
Nov 22 19:41 : client: [7334] closed
Nov 22 19:41 : client: [7335] opened from 127.0.0.1:48568
Nov 22 19:41 : client: [7335] closed
Nov 22 19:41 : client: [7336] opened from 127.0.0.1:48570
Nov 22 19:41 : client: [7336] closed
Nov 22 19:41 : client: [7337] opened from 127.0.0.1:48572
Nov 22 19:41 : client: [7337] closed
Nov 22 19:41 : client: [7338] opened from 127.0.0.1:48576
Nov 22 19:41 : client: [7338] closed
Nov 22 19:41 : client: [7339] opened from 127.0.0.1:48578
Nov 22 19:41 : client: [7339] closed
Nov 22 19:42 : client: [7340] opened from 127.0.0.1:48580
Nov 22 19:42 : client: [7340] closed
Nov 22 19:42 : client: [7341] opened from 127.0.0.1:48584
Nov 22 19:42 : client: [7341] closed
Nov 22 19:42 : client: [7342] opened from 127.0.0.1:48586
Nov 22 19:42 : client: [7342] closed
Nov 22 19:42 : client: [7343] opened from 127.0.0.1:48588
Nov 22 19:42 : client: [7343] closed
Nov 22 19:42 : client: [7344] opened from 127.0.0.1:48592
Nov 22 19:42 : client: [7344] closed
Nov 22 19:42 : client: [7345] opened from 127.0.0.1:48594
Nov 22 19:42 : client: [7345] closed
Nov 22 19:42 : client: [7346] opened from 127.0.0.1:48596
Nov 22 19:42 : client: [7346] closed
Nov 22 19:42 : client: [7347] opened from 127.0.0.1:48600
Nov 22 19:42 : client: [7347] closed
Nov 22 19:42 : client: [7348] opened from 127.0.0.1:48602
Nov 22 19:42 : client: [7348] closed
Nov 22 19:42 : client: [7349] opened from 127.0.0.1:48604
Nov 22 19:42 : client: [7349] closed
Nov 22 19:42 : client: [7350] opened from 127.0.0.1:48608
Nov 22 19:42 : client: [7350] closed
Nov 22 19:42 : client: [7351] opened from 127.0.0.1:48610
Nov 22 19:42 : client: [7351] closed
Nov 22 19:42 : client: [7352] opened from 127.0.0.1:48612
Nov 22 19:42 : client: [7352] closed
Nov 22 19:42 : client: [7353] opened from 127.0.0.1:48616
Nov 22 19:42 : client: [7353] closed
Nov 22 19:42 : client: [7354] opened from 127.0.0.1:48618
Nov 22 19:42 : client: [7354] closed
Nov 22 19:42 : client: [7355] opened from 127.0.0.1:48620
Nov 22 19:42 : client: [7355] closed
Nov 22 19:42 : client: [7356] opened from 127.0.0.1:48624
Nov 22 19:42 : client: [7356] closed
Nov 22 19:42 : client: [7357] opened from 127.0.0.1:48626
Nov 22 19:42 : client: [7357] closed
Nov 22 19:43 : client: [7358] opened from 127.0.0.1:48628
Nov 22 19:43 : client: [7358] closed
Nov 22 19:43 : client: [7359] opened from 127.0.0.1:48632
Nov 22 19:43 : client: [7359] closed
Nov 22 19:43 : client: [7360] opened from 127.0.0.1:48634
Nov 22 19:43 : client: [7360] closed
Nov 22 19:43 : client: [7361] opened from 127.0.0.1:48636
Nov 22 19:43 : client: [7361] closed
Nov 22 19:43 : client: [7362] opened from 127.0.0.1:48640
Nov 22 19:43 : client: [7362] closed
Nov 22 19:43 : client: [7363] opened from 127.0.0.1:48642
Nov 22 19:43 : client: [7363] closed
Nov 22 19:43 : client: [7364] opened from 127.0.0.1:48644
Nov 22 19:43 : client: [7364] closed
Nov 22 19:43 : client: [7365] opened from 127.0.0.1:48648
Nov 22 19:43 : client: [7365] closed
Nov 22 19:43 : client: [7366] opened from 127.0.0.1:48650
Nov 22 19:43 : client: [7366] closed
Nov 22 19:43 : client: [7367] opened from 127.0.0.1:48652
Nov 22 19:43 : client: [7367] closed
Nov 22 19:43 : client: [7368] opened from 127.0.0.1:48656
Nov 22 19:43 : client: [7368] closed
Nov 22 19:43 : client: [7369] opened from 127.0.0.1:48658
Nov 22 19:43 : client: [7369] closed
Nov 22 19:43 : client: [7370] opened from 127.0.0.1:48660
Nov 22 19:43 : client: [7370] closed
Nov 22 19:43 : client: [7371] opened from 127.0.0.1:48664
Nov 22 19:43 : client: [7371] closed
Nov 22 19:43 : client: [7372] opened from 127.0.0.1:48666
Nov 22 19:43 : client: [7372] closed
Nov 22 19:43 : client: [7373] opened from 127.0.0.1:48668
Nov 22 19:43 : client: [7373] closed
Nov 22 19:43 : client: [7374] opened from 127.0.0.1:48672
Nov 22 19:43 : client: [7374] closed
Nov 22 19:43 : client: [7375] opened from 127.0.0.1:48674
Nov 22 19:43 : client: [7375] closed
Nov 22 19:44 : client: [7376] opened from 127.0.0.1:48676
Nov 22 19:44 : client: [7376] closed
Nov 22 19:44 : client: [7377] opened from 127.0.0.1:48680
Nov 22 19:44 : client: [7377] closed
Nov 22 19:44 : client: [7378] opened from 127.0.0.1:48682
Nov 22 19:44 : client: [7378] closed
Nov 22 19:44 : client: [7379] opened from 127.0.0.1:48684
Nov 22 19:44 : client: [7379] closed
Nov 22 19:44 : client: [7380] opened from 127.0.0.1:48688
Nov 22 19:44 : client: [7380] closed
Nov 22 19:44 : client: [7381] opened from 127.0.0.1:48690
Nov 22 19:44 : client: [7381] closed
Nov 22 19:44 : client: [7382] opened from 127.0.0.1:48692
Nov 22 19:44 : client: [7382] closed
Nov 22 19:44 : client: [7383] opened from 127.0.0.1:48696
Nov 22 19:44 : client: [7383] closed
Nov 22 19:44 : client: [7384] opened from 127.0.0.1:48698
Nov 22 19:44 : client: [7384] closed
Nov 22 19:44 : client: [7385] opened from 127.0.0.1:48700
Nov 22 19:44 : client: [7385] closed
Nov 22 19:44 : client: [7386] opened from 127.0.0.1:48704
Nov 22 19:44 : client: [7386] closed
Nov 22 19:44 : client: [7387] opened from 127.0.0.1:48706
Nov 22 19:44 : client: [7387] closed
Nov 22 19:44 : client: [7388] opened from 127.0.0.1:48708
Nov 22 19:44 : client: [7388] closed
Nov 22 19:44 : client: [7389] opened from 127.0.0.1:48712
Nov 22 19:44 : client: [7389] closed
Nov 22 19:44 : client: [7390] opened from 127.0.0.1:48714
Nov 22 19:44 : client: [7390] closed
Nov 22 19:44 : client: [7391] opened from 127.0.0.1:48716
Nov 22 19:44 : client: [7391] closed
Nov 22 19:44 : client: [7392] opened from 127.0.0.1:48720
Nov 22 19:44 : client: [7392] closed
Nov 22 19:45 : client: [7393] opened from 127.0.0.1:48722
Nov 22 19:45 : client: [7393] closed
Nov 22 19:45 : client: [7394] opened from 127.0.0.1:48724
Nov 22 19:45 : client: [7394] closed
Nov 22 19:45 : client: [7395] opened from 127.0.0.1:48728
Nov 22 19:45 : client: [7395] closed
Nov 22 19:45 : client: [7396] opened from 127.0.0.1:48730
Nov 22 19:45 : client: [7396] closed
Nov 22 19:45 : client: [7397] opened from 127.0.0.1:48732
Nov 22 19:45 : client: [7397] closed
Nov 22 19:45 : client: [7398] opened from 127.0.0.1:48736
Nov 22 19:45 : client: [7398] closed
Nov 22 19:45 : client: [7399] opened from 127.0.0.1:48738
Nov 22 19:45 : client: [7399] closed
Nov 22 19:45 : client: [7400] opened from 127.0.0.1:48740
Nov 22 19:45 : client: [7400] closed
Nov 22 19:45 : client: [7401] opened from 127.0.0.1:48744
Nov 22 19:45 : client: [7401] closed
Nov 22 19:45 : client: [7402] opened from 127.0.0.1:48746
Nov 22 19:45 : client: [7402] closed
Nov 22 19:45 : client: [7403] opened from 127.0.0.1:48748
Nov 22 19:45 : client: [7403] closed
Nov 22 19:45 : client: [7404] opened from 127.0.0.1:48752
Nov 22 19:45 : client: [7404] closed
Nov 22 19:45 : client: [7405] opened from 127.0.0.1:48754
Nov 22 19:45 : client: [7405] closed
Nov 22 19:45 : client: [7406] opened from 127.0.0.1:48756
Nov 22 19:45 : client: [7406] closed
Nov 22 19:45 : client: [7407] opened from 127.0.0.1:48760
Nov 22 19:45 : client: [7407] closed
Nov 22 19:45 : client: [7408] opened from 127.0.0.1:48762
Nov 22 19:45 : client: [7408] closed
Nov 22 19:45 : client: [7409] opened from 127.0.0.1:48764
Nov 22 19:45 : client: [7409] closed
Nov 22 19:45 : client: [7410] opened from 127.0.0.1:48768
Nov 22 19:45 : client: [7410] closed
Nov 22 19:46 : client: [7411] opened from 127.0.0.1:48770
Nov 22 19:46 : client: [7411] closed
Nov 22 19:46 : client: [7412] opened from 127.0.0.1:48772
Nov 22 19:46 : client: [7412] closed
Nov 22 19:46 : client: [7413] opened from 127.0.0.1:48776
Nov 22 19:46 : client: [7413] closed
Nov 22 19:46 : client: [7414] opened from 127.0.0.1:48778
Nov 22 19:46 : client: [7414] closed
Nov 22 19:46 : client: [7415] opened from 127.0.0.1:48780
Nov 22 19:46 : client: [7415] closed
Nov 22 19:46 : client: [7416] opened from 127.0.0.1:48784
Nov 22 19:46 : client: [7416] closed
Nov 22 19:46 : client: [7417] opened from 127.0.0.1:48786
Nov 22 19:46 : client: [7417] closed
Nov 22 19:46 : client: [7418] opened from 127.0.0.1:48788
Nov 22 19:46 : client: [7418] closed
Nov 22 19:46 : client: [7419] opened from 127.0.0.1:48792
Nov 22 19:46 : client: [7419] closed
Nov 22 19:46 : client: [7420] opened from 127.0.0.1:48794
Nov 22 19:46 : client: [7420] closed
Nov 22 19:46 : client: [7421] opened from 127.0.0.1:48796
Nov 22 19:46 : client: [7421] closed
Nov 22 19:46 : client: [7422] opened from 127.0.0.1:48800
Nov 22 19:46 : client: [7422] closed
Nov 22 19:46 : client: [7423] opened from 127.0.0.1:48802
Nov 22 19:46 : client: [7423] closed
Nov 22 19:46 : client: [7424] opened from 127.0.0.1:48804
Nov 22 19:46 : client: [7424] closed
Nov 22 19:46 : client: [7425] opened from 127.0.0.1:48808
Nov 22 19:46 : client: [7425] closed
Nov 22 19:46 : client: [7426] opened from 127.0.0.1:48810
Nov 22 19:46 : client: [7426] closed
Nov 22 19:46 : client: [7427] opened from 127.0.0.1:48812
Nov 22 19:46 : client: [7427] closed
Nov 22 19:46 : client: [7428] opened from 127.0.0.1:48816
Nov 22 19:46 : client: [7428] closed
Nov 22 19:47 : client: [7429] opened from 127.0.0.1:48818
Nov 22 19:47 : client: [7429] closed
Nov 22 19:47 : client: [7430] opened from 127.0.0.1:48820
Nov 22 19:47 : client: [7430] closed
Nov 22 19:47 : client: [7431] opened from 127.0.0.1:48824
Nov 22 19:47 : client: [7431] closed
Nov 22 19:47 : client: [7432] opened from 127.0.0.1:48826
Nov 22 19:47 : client: [7432] closed
Nov 22 19:47 : client: [7433] opened from 127.0.0.1:48828
Nov 22 19:47 : client: [7433] closed
Nov 22 19:47 : client: [7434] opened from 127.0.0.1:48832
Nov 22 19:47 : client: [7434] closed
Nov 22 19:47 : client: [7435] opened from 127.0.0.1:48834
Nov 22 19:47 : client: [7435] closed
Nov 22 19:47 : client: [7436] opened from 127.0.0.1:48836
Nov 22 19:47 : client: [7436] closed
Nov 22 19:47 : client: [7437] opened from 127.0.0.1:48840
Nov 22 19:47 : client: Max connections reached
I have a similar problem, is there a solution? I see tons of connections from a 127.0.0.1 (i.e. localhost) client. These are coming from the Volumio host itself. What process does so many constant connections? I do also see connection closes by the localhost client, but as was suggested above, the connections appear to be happening too quickly relative to the closes.
For now I upped the /etc/mpd.conf max_connections parameter to 500. But that feels like a kludge, I think the real solution is to fix the over-ambitious client.
FYI, running v1.5 on BeagleBone Black.
