Wifi Doesn't work when LXDE is installed
I install Volumio with LXDE for use with my touch screen…
Before installing LXDE, the WIFI from the Volumio GUI is working. However, after install LXDE, the wifi is not working anymore. turning on from Volumio GUI doesn’t respond and ended up with crash.
Any help on how to activate it?
Thanks and Regards,
Volumio is not intended to run with LXDE. It is often used headerless, with access to the UI from a browser on another device, but there is a ‘touch display’ plugin, which allows the UI to be shown on the display. Please have a read of the documentation below.
