@DED, I’d like to know what you mean by “tested and working”. I assume that it means that it is able perform the basic function of reading and playing audio CDs.
How about other issues that have been brought up – delays caused by the drive spinning up and down, long pauses between tracks, and lack of gapless playback? Do your tested drives run without these issues? Personally I believe that these are software issues that can’t be fixed by switching to a different drive, but I’d love to be proven wrong and I will purchase the drive if it isn’t the case!
Hi guys can you take a look/respond at this. As some drives are really trying to lift off.
To reduce the spin i can use: eject -x 4 /dev/cdrom
But I have to run it after every eject => CD loading.
Hi is there someone who has successfully tested or used a CD Drive with Front-Load / Slot In system like
TEAC DV-W28SS
LG GS40N
and connected those drives via a SATA3 to USB Converter on the Raspberry Pi.
I think about installing it into a housing and the slot in drives looks much cleaner.
Cheers
Korniman
