Where do I find version 3.5.0 of the touchscreen
Looking for the 3.5.0 of the touchscreen plugin so I can get a virtual keyboard.
I’m not sure where this plugin is located. Can someone point me to it?
thanks
enable the test/beta channel for the plugins.
<ip-address>/dev
Super. Thank-you
I upgraded to 3.5.0 and it says successfull, but it is still at 3.4.0
I have tried several restarts and uninstall and install, but I can never get it to version 3.5.0
Maybe some pointer is still pointing to the 3.4.0 version?
I tired upgrading to 3.5.0 on a second system with the same result. I did an uninstall, a power restart, then an install of 3.5.0 . another power rstart and the plugin is still at 3.4.0
So back to my original question, where can i find version 3.5.0 of the touchscreen plugin?
you have to click on the version you want to install…
Says plug in already installed when i ask for version 3.5 yet it is at 3.4
Did you remove 3.4.0 and reboot Before clicking 3.5.0?
yes, is that the correct procedure? I got it in there this time, i just clicked on details then chose the 3.5 and this time it went.
Don’t know what I was doing wrong. I’m going to try my other system now.txs
Upgraded the other system and got the 3.50 in there. The keyboard functionality is Great!!! Thank-you!
@balbuze could you please promote 3.50 as stable?
Hello! @Darmur
Done! Touch_display 3.5.0 stable
