Websockets playPlaylist Python Script input
Hi everyone,
I am currently building a childproof musicbox for my little son. It is supposed to play given playlists by RFID input (emulated keyboard; the USB-RFID reader returns HEX-code and presses ENTER). I would like to integrate this functionality by running a Python script next to volumio, communicating via the websocket API. The python script prompts for an input from the connected RFID-reader and then hands the playlist name (corresponding to the HEX-code from an RFID-card) to volumio via the API using socketIO and the playPlaylist command.
I began writing some code and was wondering if something like the following could work:
while True : inp = input("Waiting for card...") socketIO.emit('playPlaylist' {"name":"inp"})
I am but a simple hobby programmer and quite new to APIs. Feel free to point out my potentially stupid mistakes. I shall be thankful!
Figured it out, the following works just fine:
while True : inp = input("Waiting for card...") socketIO.emit('playPlaylist' {"name":inp})
I am just trying to to the same. Have the RFID card reader working fine with another distribution but I would like to do the same with Volumio. I managed to send play, volume up etc using an python script and websocket API but no luck with spotify playlist or web radios. Do you know how to do that?
websocket-home-automation-t4622-10.html
