Using 3.785. The radio is on a lot, sometimes for the whole day. After playing it for a longtime, it stops working, webradio can not be controlled, will only respond after reboot. At the same time music from streaming works. Is it a memory leak issue? Is there anyway to clear the catch? May it be something else?
Thank you
Is there any reason for the webradio service inconsistency? It simple does not play any station. Do i miss something?
Thank you
Even after reboot, it doesnot connect. Changed/updated some URL, no success. Is the service not supported really anymore?
please post a log when this happens, maybe it will reveal something.
http://logs.volumio.org/volumio/CpfJSUb.html
Is this the correct way to do it?
Looks like your network is interrupting:
Jan 20 07:12:13 volumiolivingroom volumio[822]: error: MyVolumio got a network error: A network error (such as timeout, interrupted connection or unreachable host) has occurred.
Jan 20 07:12:13 volumiolivingroom volumio[822]: info: Retrying Login Due to Network Error
Jan 20 07:13:20 volumiolivingroom volumio[822]: error: MPD error: Error: This socket has been ended by the other party
Jan 20 07:13:20 volumiolivingroom volumio[822]: error: This socket has been ended by the other party {"code":"EPIPE"}
Do you have infinity play on? If yes please disable and test again.
thanks for the fast reply. What is infinity play?
Ok i found it. It is off, i dont have premium
Any suggestion?
After the second reboot, now it works.
Please sent a log now it’s working and one when it fails again, So i can compare them.
