web interface
I have a problem : I cannot access to my PI volumio from my web page (IP address is correct)
I can access with ssh, but not with graphical web interface
How can I restart it ?
Thank you
in case you can use ssh: do ‘killall node’
But perhaps you could try ‘http:///dev’ and submit a log. I would need the url it returns.
it doesn’t work : the web interface “says” 192.168.0.24 doesn’t allow the connection
I had reboot the PI ; I think the web server of volumio is not launched
Is there a way to apply a “factory reset” from the terminal with ssh ?
touch /boot/factory_reset sync reboot
hi,
super it works !
it was the solution !
youpi !!!
I can close this post
