Sorry, my poor explanation: yes I meant applying this dtoverlay. I know that screensaving is only blanking. Screen function was totally gone then. I will play with GPU memory and for checking with other Hdmi screen I have to disassemble my player partly. Thank you. I will follow up.
Hi, I have the very same screen.
Running the latest version of Volumio on RPi 4
For some strange reason I canât rotate the picture by 90 degrees ( screen displays vertically by a default )
display_rotate=1 makes display go black
display_rotate=2 and so on rotates the image by 180 degrees
@gvolt do have any idea what could cause that ?
Did you add those âdisplay_rotateâ options to â/boot/config.txtâ or â/boot/userconfig,txtâ manually? Asking because the Touch Display plugin (which I assume you have installed) does not use âdisplay_rotateâ⌠In case you added them manually I suggest to remove âdisplay_rotateâ and set the screen rotation from the pluginâs config page.
On the pluginâs config page you should also see an option called âGPU Memory Settingsâ. Try increasing the GPU memory to e.g. 64MB and reboot.
If that should not solve the problem please connect to Volumio via SSH and post the results of â/boot/config.txtâ and â/boot/userconfig,txtâ:
cat /boot/config.txt
cat /boot/userconfig,txt
hi,
thank you for a quick reply,
screen looks like this right now:
initramfs volumio.initrd
#GPU_MEM=32
max_usb_current=1
dtparam=audio=on
audio_pwm_mode=2
dtparam=i2c_arm=on
disable_splash=1
hdmi_force_hotplug=1
include userconfig.txt
Volumio i2s setting below: do not alter
dtoverlay=allo-digione
Touch Display gpu_mem setting below: do not alter
gpu_mem=64volumio@volumio:~$
cat /boot/userconfig.txt
max_framebuffer_height=1920
config_hdmi_boost=10
hdmi_group=2
hdmi_mode=87
hdmi_timings=1080 1 26 4 50 1920 1 8 2 6 0 0 0 60 0 135580000 3
display_lcd_rotate=1
display_hdmi_rotate=1volumio@volumio:~$
Maybe try commenting âhdmi_timingsâ in â/boot/userconfig.txtâ and adding
hdmi_cvt=1080 1920 60
No liability assumed
it turned out the hdmi cable I was using was faulty
thank you for your help @gvolt !!
Hi! I have a similar issu: RPi 4 and 5.5 Amoled touch display, but I canât get the screensaver working. The display always shows the Volumino screen - even if the âMonitor is Offâ (after I run the xset -display :0 q comand)âŚ
Any further hints?
Please add âhdmi_blanking=1â to /boot/userconfig.txt
Thanks! It works!
hi, what is the best way to rotate the touch on this screen ? Plugin rotates the picture but not the touch. Iâm on 3.175 version.
I think touch rotation should work. What rotation do you try to achieve?
After setting the rotation from the pluginâs config page please post the results of
and
cat /etc/X11/xorg.conf.d/95-touch_display-plugin.conf
hi @gvolt
thank you for a fast reply
90 degrees
#GPU_MEM=32
max_usb_current=1
dtparam=audio=on
audio_pwm_mode=2
dtparam=i2c_arm=on
disable_splash=1
force_eeprom_read=0
gpu_mem=64volumio@volumiomain:~$
hdmi_group=2
hdmi_mode=87
This file is managed by the Touch Display plugin: Do not alter!
It will be deleted when the Touch Display plugin gets uninstalled.
Section âInputClassâ
Identifier âTouch rotationâ
Option âTransformationMatrixâ â0 1 0 -1 0 1 0 0 1â
MatchIsTouchscreen âonâ
MatchDevicePath â/dev/input/event*â
MatchDriver âlibinput|evdevâ
EndSection
Looks ok so far. Did you install other display related software or plugins?
Please show the results of
ls -al /etc/X11/xorg.conf.d
and
ls -al /usr/share/X11/xorg.conf.d
no I didnât
total 16
drwxr-xr-x 2 root root 4096 Dec 22 19:21 .
drwxr-xr-x 1 root root 4096 Dec 7 18:04 âŚ
-rw-râr-- 1 root root 375 Dec 22 19:21 95-touch_display-plugin.conf
total 28
drwxr-xr-x 2 root root 4096 Dec 7 18:01 .
drwxr-xr-x 1 root root 4096 Dec 7 18:01 âŚ
-rw-râr-- 1 root root 92 Feb 7 2019 10-amdgpu.conf
-rw-râr-- 1 root root 1350 Apr 19 2021 10-quirks.conf
-rw-râr-- 1 root root 92 Apr 6 2019 10-radeon.conf
-rw-râr-- 1 root root 1429 Mar 31 2019 40-libinput.conf
-rw-râr-- 1 root root 2747 Jun 26 2017 70-wacom.conf
I assume â40-libinput.confâ has not been modified. If you set rotation to 180 deg. is touch rotated properly / wrongly / not at all?
hi,
180 rotates by 180, touch doesnât work at all, Iâll do a clean install over weekend
Just to clarify: Do you mean, not at 180 deg. or not at all?
Yes indeed, not at all
Ok, thatâs an important clarification. My understanding from post #30 was that touch works but does not rotate accordingly to the display.
Sorry for aksing the obvious, but do you have the display also connected by USB (connector 4 not 3 on this picture) to the Pi?
If so, does an input device show up?
ls -al /dev/input/event*
