now my touch work, but don’t is correct… not mach touch-buttons
This is the 95-touch_display-plugin.conf
This file is managed by the Touch Display plugin: Do not alter!
It will be deleted when the Touch Display plugin gets uninstalled.
Section “InputClass”
Identifier “Touch rotation”
MatchIsTouchscreen “on”
MatchDevicePath “/dev/input/event*”
MatchDriver “libinput|evdev”
EndSection
95-touch_display-plugin.conf (END)
Execute
sudo apt-get install xserver-xorg-input-evdev
After installation has finished:
sudo cp -rf /usr/share/X11/xorg.conf.d/10-evdev.conf /etc/X11/xorg.conf.d/45-evdev.conf
BTW: What Volumio version are you running?
I run the latest stable version… 2.8x
Sorry, I overlooked this.
Please create a file “99-calibration.conf” in “/etc/X11/xorg.conf.d”:
sudo nano /etc/X11/xorg.conf.d/99-calibration.conf
with the following content:
Section "InputClass"
Identifier "calibration"
MatchProduct "ADS7846 Touchscreen"
Option "Calibration" "3945 233 3939 183"
Option "SwapAxes" "1"
EndSection
To save the file and close nano hit Ctrl+x, y and Enter.
Good morning from Italy … thanks for the great guide!
Now my touch works! : slight_smile:
How can I change the bad display resolution? it’s hard to read what’s written !!
This display only has a resolution of 480x320. Do you think the shown resolution is actually lower than that? Could you possibly post a picture of the display?
if i set the 800x600 px now i see very well but the menu is little andit’s difficult to use whit touch!
I guess that’s what to expect if the physical resolution is just 480x300.
Hm, I don’t have a 3.5 inch display with a resolution of 480x320 to compare but in the pictures everything looks normal to me. Maybe try out the classical UI theme.
Do you have a picture that shows the difference you are referring to?
i’m sorry … no! but if i want enlarge the font text into css where i can go?
I have no clue. I don’t tinker with the .css files, but you probably can get help in the thread Contemporary optimizations plugin for local connected displays where you already have posted.
Thenk you for help!
Yes, doesn’t look nice. With your other 3.5 inch display it was looking better (when resolution was also set to 480x320)?
i think of yes… but other display has not HDMI and i installed this script.
install_3.5_screen-270.sh
What is the content of that script? Do you have a link?
