Volumio X86/ Debian Buster debugging party (BETA)
my stuff:
Alfawise X5 - also a Mini-PC, but with Z8350 CPU from 2017
Hello everyone :smiley:
I was so happy when I discovered the thread.
I took one of my Mini-PCs out of the box:
Alfawise X5 - a Mini-PC, with a x5-Z8350 CPU.
The Alfawise itself is a very annoying PC:
preinstalled were an Android and Windows10 on a 32gb-emmc
A USB stick with the image "volumiobuster-0.007-2020-02-27-x86
finished and tested…
If someone also has the Alfawise X5 Mini-PC: F7 leads to
Selection in the boot menu.
If you do not press the F7 key, there is a flashed(UEFI?) graphical menu
with ā€œANDROID iconā€ / ā€œWindows iconā€
and you just can’t get to the USB stick… so: press F7.
With the Alfawise I can finally pass on the sound via HDMI.
But also my ā€œaune USB DACā€ which I just bought for other reasons
also gives me the sound.
My new Hisense TV shows me the GUI at my whim.
On some days I don’t see anything /
on other days parts of the gui
on the next days perhaps the full gui
but because I only want to hear :smiley: , I’m not going to clear the error.
Afterwards I tried to transfer the USB stick to the built-in emmc
to install.
But this UEFI stuff won’t let me start, so what do I do?
So I just put a LinuxMint installation on the fourth free partition.
When it was installed, the grub-install of linux plus customizations of grub.cfg
let me now without TV, but just pressing the F7 key
the volumio starting.
Plugins do not seem to be selectable at the moment, I guess
But overall a big step forward :slight_smile:
thank you very much,
jo01
PS: sorry about my english :wink:
Hello, I am having some odd issues when it comes to my library. First, my internal HDD is showing up as a USB drive, secondly USB drives will not scan and show up correctly at all. This will happen while using different USB drives formatted in NTFS or EXFAT. Finally, update and or recreate function will not always work, when this happens no drives will show up at all and when I try to look in my library it will show up blank. Attached below are the suggested debug lines and please let me know if any other commands will be helpful.
inxi -vFzxxx
System:
Host: volumio Kernel: 4.19.106+ i686 bits: 32 compiler: gcc v: 8.3.0
Console: tty 0 dm: N/A Distro: Debian GNU/Linux 10 (buster)
Machine:
Type: Laptop System: Dell product: Latitude E5470 v: N/A serial:
Chassis: type: 9 serial:
Mobo: Dell model: 0VHKV0 v: A00 serial: UEFI: Dell v: 1.21.6
date: 10/02/2019
Battery:
ID-1: BAT0 charge: 59.2 Wh condition: 59.2/62.0 Wh (95%) volts: 8.3/7.6
model: Samsung SDI DELL TXF9M6A type: Li-poly serial:
status: Full
CPU:
Topology: Single Core model: Intel Core i5-6300U bits: 64 type: MCP
arch: Skylake rev: 3 L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 4992
Speed: 2400 MHz min/max: 400/2400 MHz Core speed (MHz): 1: 2400
Graphics:
Device-1: Intel HD Graphics 520 vendor: Dell Skylake GT2 driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:1916
Display: tty server: X.org 1.20.4 driver: modesetting unloaded: fbdev,vesa
tty: 80x24
Message: Unable to show advanced data. Required tool glxinfo missing.
Audio:
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell
driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:9d70
Device-2: N/A type: USB driver: snd-usb-audio bus ID: 1-4:3
chip ID: 30be:1000
Sound Server: ALSA v: k4.19.106+
Network:
Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: 3.2.6-k
port: f040 bus ID: 00:1f.6 chip ID: 8086:156f
IF: eth0 state: up speed: 1000 Mbps duplex: full mac:
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel port: f040
bus ID: 01:00.0 chip ID: 8086:24f3
IF: wlan0 state: down mac:
Drives:
Local Storage: total: 655.81 GiB used: 282.61 GiB (43.1%)
ID-1: /dev/sda vendor: SanDisk model: SD8SN8U128G1001 size: 119.24 GiB
speed: 6.0 Gb/s serial: rev: 3001 scheme: GPT
ID-2: /dev/sdb type: USB vendor: JMicron model: Tech size: 476.94 GiB
serial: rev: 0204 scheme: MBR
ID-3: /dev/sdc type: USB vendor: Lexar model: USB Flash Drive
size: 59.62 GiB serial: rev: 1100 scheme: GPT
Partition:
ID-1: / size: 54.69 GiB used: 35.2 MiB (0.1%) fs: overlay source: ERR-102
ID-2: /boot size: 486.0 MiB used: 42.1 MiB (8.7%) fs: vfat dev: /dev/sdc1
Sensors:
Missing: Required tool sensors not installed. Check --recommends
Info:
Processes: 137 Uptime: 2h 27m Memory: 2.41 GiB used: 544.0 MiB (22.0%)
Init: systemd v: 241 runlevel: 5 default: 2 Compilers: gcc: N/A
Shell: bash v: 5.0.3 running in: tty 0 (SSH) inxi: 3.0.32
aplay -l
card 0: PCH [HDA Intel PCH], device 0: ALC3235 Analog [ALC3235 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 5: USB [Schiit Bifrost 2 Unison USB], device 0: USB Audio [USB Audio]
Subdevices: 1/1
aplay -L
default
Playback/recording through the PulseAudio sound server
null
Discard all samples (playback) or generate zero samples (capture)
jack
JACK Audio Connection Kit
pulse
PulseAudio Sound Server
sysdefault:CARD=PCH
HDA Intel PCH, ALC3235 Analog
Default Audio Device
front:CARD=PCH,DEV=0
Front speakers
surround21:CARD=PCH,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=PCH,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=PCH,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=PCH,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=PCH,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=PCH,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
hdmi:CARD=PCH,DEV=0
HDA Intel PCH, HDMI 0
HDMI Audio Output
hdmi:CARD=PCH,DEV=1
HDA Intel PCH, HDMI 1
HDMI Audio Output
hdmi:CARD=PCH,DEV=2
HDA Intel PCH, HDMI 2
HDMI Audio Output
hdmi:CARD=PCH,DEV=3
HDA Intel PCH, HDMI 3
HDMI Audio Output
hdmi:CARD=PCH,DEV=4
HDA Intel PCH, HDMI 4
HDMI Audio Output
dmix:CARD=PCH,DEV=0
Direct sample mixing device
dmix:CARD=PCH,DEV=3
dmix:CARD=PCH,DEV=7
dmix:CARD=PCH,DEV=8
dmix:CARD=PCH,DEV=9
dmix:CARD=PCH,DEV=10
dsnoop:CARD=PCH,DEV=0
Direct sample snooping device
dsnoop:CARD=PCH,DEV=3
dsnoop:CARD=PCH,DEV=7
dsnoop:CARD=PCH,DEV=8
dsnoop:CARD=PCH,DEV=9
dsnoop:CARD=PCH,DEV=10
hw:CARD=PCH,DEV=0
Direct hardware device without any conversions
hw:CARD=PCH,DEV=3
hw:CARD=PCH,DEV=7
hw:CARD=PCH,DEV=8
hw:CARD=PCH,DEV=9
hw:CARD=PCH,DEV=10
plughw:CARD=PCH,DEV=0
Hardware device with all software conversions
plughw:CARD=PCH,DEV=3
plughw:CARD=PCH,DEV=7
plughw:CARD=PCH,DEV=8
plughw:CARD=PCH,DEV=9
plughw:CARD=PCH,DEV=10
usbstream:CARD=PCH
HDA Intel PCH
USB Stream Output
sysdefault:CARD=USB
Schiit Bifrost 2 Unison USB, USB Audio
front:CARD=USB,DEV=0
Front speakers
surround21:CARD=USB,DEV=0
surround40:CARD=USB,DEV=0
surround41:CARD=USB,DEV=0
surround50:CARD=USB,DEV=0
surround51:CARD=USB,DEV=0
surround71:CARD=USB,DEV=0
iec958:CARD=USB,DEV=0
IEC958 (S/PDIF) Digital Audio Output
dmix:CARD=USB,DEV=0
dsnoop:CARD=USB,DEV=0
hw:CARD=USB,DEV=0
plughw:CARD=USB,DEV=0
usbstream:CARD=USB
USB Stream Output
yes, it was to be expected not all hardware will work, although we made a big step forward with kernel version and firmware.
Thanks for the information, it may help locating issues. But can’t give a promise, giving it our best.
see previous post, trying to locate and fix it when possible
Update: I got things to work properly once I rebooted, tried to again remake my library and once I got the message that it started I just needed to let it sit for a hour or so.
Please see my testing threads above for the history on this post. My target usage of Volumio is to have it running as a VM in my NAS server with the music it will be playing. This same rack has the preamp that needs to process and route the audio, so, a digital stream out of Volumio is the best option to preserve quality and stay efficient.
My server had a spare PCI slot, so I procured some older NVidia cards which I hoped would share the HDMI ports with me. This never worked right. It was due to the lack of the Nvidia Drivers in Volumio. They would not install properly and a patch was required.
I’ve been using my GT1030 for 3 days now, it works perfectly, it doesn’t go to sleep with my monitor off and it only uses 19W of power. If I want to watch the kiosk GUI, it displays on my main 85" TV :slight_smile:
I’ll be selling the GTX750 (I don’t need another fan in that case) PM if interested. I’ll also try to find time to test the GT710 so we all can learn something, and then I’ll likely sell that one too.
VM Particulars
Machine type - i440fx-4.2
BIOS - OVMF
Note the manual ā€œmultifunctionā€ addition to the GPU passthrough:
<?xml version='1.0' encoding='UTF-8'?> <domain type='kvm' id='1'> <name>Gt10301440</name> <uuid>1bfb38e3-e6d0-e2c3-30c0-6f3ed331a658</uuid> <metadata> <vmtemplate xmlns="unraid" name="Debian" icon="debian.png" os="debian"/> </metadata> <memory unit='KiB'>8388608</memory> <currentMemory unit='KiB'>8388608</currentMemory> <memoryBacking> <nosharepages/> </memoryBacking> <vcpu placement='static'>2</vcpu> <cputune> <vcpupin vcpu='0' cpuset='2'/> <vcpupin vcpu='1' cpuset='10'/> </cputune> <resource> <partition>/machine</partition> </resource> <os> <type arch='x86_64' machine='pc-i440fx-4.2'>hvm</type> <loader readonly='yes' type='pflash'>/usr/share/qemu/ovmf-x64/OVMF_CODE-pure-efi.fd</loader> <nvram>/etc/libvirt/qemu/nvram/1bfb38e3-e6d0-e2c3-30c0-6f3ed331a658_VARS-pure-efi.fd</nvram> </os> <features> <acpi/> <apic/> </features> <cpu mode='host-passthrough' check='none'> <topology sockets='1' cores='1' threads='2'/> <cache mode='passthrough'/> </cpu> <clock offset='utc'> <timer name='rtc' tickpolicy='catchup'/> <timer name='pit' tickpolicy='delay'/> <timer name='hpet' present='no'/> </clock> <on_poweroff>destroy</on_poweroff> <on_reboot>restart</on_reboot> <on_crash>restart</on_crash> <devices> <emulator>/usr/local/sbin/qemu</emulator> <disk type='file' device='disk'> <driver name='qemu' type='raw' cache='writeback'/> <source file='/mnt/disks/nongamingvm/gt1030440/volumiobuster-0.007-2020-02-27-x86.img' index='1'/> <backingStore/> <target dev='hdc' bus='sata'/> <boot order='1'/> <alias name='sata0-0-2'/> <address type='drive' controller='0' bus='0' target='0' unit='2'/> </disk> <controller type='usb' index='0' model='ich9-ehci1'> <alias name='usb'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x7'/> </controller> <controller type='usb' index='0' model='ich9-uhci1'> <alias name='usb'/> <master startport='0'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x0' multifunction='on'/> </controller> <controller type='usb' index='0' model='ich9-uhci2'> <alias name='usb'/> <master startport='2'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x1'/> </controller> <controller type='usb' index='0' model='ich9-uhci3'> <alias name='usb'/> <master startport='4'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x2'/> </controller> <controller type='pci' index='0' model='pci-root'> <alias name='pci.0'/> </controller> <controller type='sata' index='0'> <alias name='sata0'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x0'/> </controller> <controller type='virtio-serial' index='0'> <alias name='virtio-serial0'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x04' function='0x0'/> </controller> <interface type='bridge'> <mac address='52:54:00:d6:20:6e'/> <source bridge='br0'/> <target dev='vnet0'/> <model type='e1000-82545em'/> <alias name='net0'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x0'/> </interface> <serial type='pty'> <source path='/dev/pts/0'/> <target type='isa-serial' port='0'> <model name='isa-serial'/> </target> <alias name='serial0'/> </serial> <console type='pty' tty='/dev/pts/0'> <source path='/dev/pts/0'/> <target type='serial' port='0'/> <alias name='serial0'/> </console> <channel type='unix'> <source mode='bind' path='/var/lib/libvirt/qemu/channel/target/domain-1-Gt10301440/org.qemu.guest_agent.0'/> <target type='virtio' name='org.qemu.guest_agent.0' state='disconnected'/> <alias name='channel0'/> <address type='virtio-serial' controller='0' bus='0' port='1'/> </channel> <input type='mouse' bus='ps2'> <alias name='input0'/> </input> <input type='keyboard' bus='ps2'> <alias name='input1'/> </input> <hostdev mode='subsystem' type='pci' managed='yes'> <driver name='vfio'/> <source> <address domain='0x0000' bus='0x02' slot='0x00' function='0x0'/> </source> <alias name='hostdev0'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x05' function='0x0' multifunction='on'/> </hostdev> <hostdev mode='subsystem' type='pci' managed='yes'> <driver name='vfio'/> <source> <address domain='0x0000' bus='0x02' slot='0x00' function='0x1'/> </source> <alias name='hostdev1'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x05' function='0x1'/> </hostdev> <memballoon model='none'/> </devices> <seclabel type='dynamic' model='dac' relabel='yes'> <label>+0:+100</label> <imagelabel>+0:+100</imagelabel> </seclabel> </domain>
NVidia GT1030 Install Steps
Step 1 - Expand Image to make room
qemu-img resize -f raw [imagelocation]/volumiobuster-0.007-2020-02-27-x86.img +2G
Step 2 - Install Headers
copy headers to
cd /usr/kernel/
sudo dpkg -i linux-headers-4.19.106+_4.19.106+-1_i386.deb
Step 3 - Update Sources
Update Sources
sudo nano /etc/apt/sources.list
deb http://deb.debian.org/debian buster main contrib non-free
deb-src http://deb.debian.org/debian buster main contrib non-free
deb http://security.debian.org/debian-security buster/updates main contrib
deb-src http://security.debian.org/debian-security buster/updates main contrib
# buster-backports
deb http://deb.debian.org/debian buster-backports main contrib non-free
Step 4 - Update Installers
1 - apt-get update
2 - apt-get install aptitude
3 - sudo aptitude update
4 - sudo aptitude upgrade
Step 5 - Apply Kernel Fix per https://forum.loverpi.com/discussion/555/how-to-fix-dkms-error-bin-sh-1-scripts-basic-fixdep-exec-format-error
There are 4 steps needed to do this:
1) Change to the Linux header directory: cd /usr/src/linux-headers-`uname -r`
1) Install the necessary dependencies: sudo apt-get install -y build-essential bc bison flex libssl-dev
2) Apply the byteshift patch to the headers: wget https://raw.githubusercontent.com/armbian/build/master/patch/misc/headers-debian-byteshift.patch -O - | sudo patch -p1
3) Compile the scripts: sudo make scripts
Now DKMS should work like normal.
Step 6 - Install Nvidia Driver (Note Volumio is 32bit and so we must use legacy drivers "nvidia-legacy-390xx-driver")
1 - sudo aptitude install nvidia-legacy-390xx-driver
2 - There should be no errors, reboot when completed.
Step 7 - Correct mpd.conf in Volumio
1 - sudo nano /etc/mpd.conf
2 - Edit to set the correct HDMI output port for audio.  Save and reboot.  This GT 1030 is "hw0,3".
Step 8 - Test
This is fully functional.  Settings persist.  Cold start and reboot area all OK with no loss of function.  Turning off all audio hardware and letting it sit overnight does not result in errors or sleep mode.  This appears fully stable.
I am able to control this via my cell phone while on my home network.
lspci -k
00:05.0 VGA compatible controller: NVIDIA Corporation GP108 (rev a1)
        Subsystem: eVga.com. Corp. GP108 [GeForce GT 1030]
        Kernel driver in use: nvidia
        Kernel modules: nvidia
00:05.1 Audio device: NVIDIA Corporation GP108 High Definition Audio Controller (rev a1)
        Subsystem: eVga.com. Corp. GP108 High Definition Audio Controller
        Kernel driver in use: snd_hda_intel
        Kernel modules: snd_hda_intel
volumio@guildnoise666:~$ aplay -l
card 0: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
  Subdevices: 1/1
volumio@guildnoise666:~$ aplay -L
default
null
jack
pulse
hdmi:CARD=NVidia,DEV=0
    HDA NVidia, HDMI 0
    HDMI Audio Output
hdmi:CARD=NVidia,DEV=1
    HDA NVidia, HDMI 1
    HDMI Audio Output
dmix:CARD=NVidia,DEV=3
    HDA NVidia, HDMI 0
dmix:CARD=NVidia,DEV=7
    HDA NVidia, HDMI 1
dsnoop:CARD=NVidia,DEV=3
    HDA NVidia, HDMI 0
dsnoop:CARD=NVidia,DEV=7
    HDA NVidia, HDMI 1
hw:CARD=NVidia,DEV=3
    HDA NVidia, HDMI 0
hw:CARD=NVidia,DEV=7
    HDA NVidia, HDMI 1
plughw:CARD=NVidia,DEV=3
    HDA NVidia, HDMI 0
plughw:CARD=NVidia,DEV=7
    HDA NVidia, HDMI 1
usbstream:CARD=NVidia
    HDA NVidia
    USB Stream Output
Are there any tests I should run or other CLI checks to make to ensure it is running bitperfect and following the intended Volumio data flow?
GT710 Reserved Test Spot
Hi gkkpch Moderator, I am making a note as per your request in my post need-help-onboard-spdif-sound-output-x86-t14257.html
gkkpch wrote:
There is no soundcard profile for the ATI card yet.
Of course we are willing to make one but that can take a little time before the next release.
Could you make a note in the Volumio Development/ Development talk/ Volumio X86/buster thread so it does not get lost?
After this is done, it will work with the next ā€œlegacyā€ X86 version as well.
root@volumio:/home/volumio# aplay -l
card 0: SB [HDA ATI SB], device 0: ALC662 rev1 Analog [ALC662 rev1 Analog]
Subdevices: 0/1
card 0: SB [HDA ATI SB], device 1: ALC662 rev1 Digital [ALC662 rev1 Digital]
Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
To take a detail look of the x86 PC, Is dmesg command printout required here?
Noted!
Read the OP (first post), it explains what we like to receive as info.
Hello there, I can not seem to get resampling to work. I set it up, and checked local dev and this was the output. Note I tried to set bitrate to 24 and sampling to 192 with the highest quality option. I also tried different combinations nothing was working.
Update: This is my local music and i reverted back to the most current non-beta release and im seeing the same issue. is this an issue with the resampler or is this an issue with status now showing its upsampling? More playing around i tried to set resampling above what my Dac can handle and the music will play fine, this i belive shows the resampling is not working on beta or stable.
{ā€œstatusā€:ā€œplayā€,ā€œpositionā€:2,ā€œtitleā€:ā€œSpeed of Soundā€,ā€œartistā€:ā€œColdplayā€,ā€œalbumā€:ā€œX&Yā€,ā€œalbumartā€:"/albumart?cacheid=367&web=Coldplay/X%26Y/extralarge&path=%2FUSB%2FMusic%2FUncompressed%20FLAC%2FArchived%2FColdplay%2FX%26Y&metadata=false",ā€œuriā€:ā€œmnt/USB/Music/Uncompressed FLAC/Archived/Coldplay/X&Y/07 – Speed of Sound.flacā€,ā€œtrackTypeā€:ā€œflacā€,ā€œseekā€:103430,ā€œdurationā€:288,ā€œsamplerateā€:ā€œ44.1 kHzā€,ā€œbitdepthā€:ā€œ16 bitā€,ā€œchannelsā€:2,ā€œrandomā€:null,ā€œrepeatā€:null,ā€œrepeatSingleā€:false,ā€œconsumeā€:false,ā€œvolumeā€:100,ā€œdisableVolumeControlā€:false,ā€œmuteā€:false,ā€œstreamā€:ā€œflacā€,ā€œupdatedbā€:false,ā€œvolatileā€:false,ā€œserviceā€:ā€œmpdā€}
Hardware: Beelink BT3 Pro
Problem: OS doesn’t recognize the eMMC storage for local installation of the image
Image: volumiobuster-0.007-2020-02-27-x86.img
volumio@volumio:~$ inxi -vFzxxx System: Host: volumio Kernel: 4.19.106+ i686 bits: 32 compiler: gcc v: 8.3.0 Console: tty 0 dm: N/A Distro: Debian GNU/Linux 10 (buster) Machine: Message: No machine data: try newer kernel. Is dmidecode installed? Try -M --dmidecode. CPU: Topology: Single Core model: Intel Atom x5-Z8350 bits: 64 type: MCP arch: Airmont rev: 4 L2 cache: 1024 KiB flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 2880 Speed: 1456 MHz min/max: 480/1920 MHz Core speed (MHz): 1: 1456 Graphics: Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCI Configuration Registers driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:22b0 Display: tty server: X.org 1.20.4 driver: modesetting unloaded: fbdev,vesa tty: 164x53 Message: Unable to show advanced data. Required tool glxinfo missing. Audio: Device-1: Intel HDMI/DP LPE Audio driver: HdmiLpeAudio message: bus/chip ids unavailable Sound Server: ALSA v: k4.19.106+ Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169 v: kernel port: e000 bus ID: 01:00.0 chip ID: 10ec:8168 IF: eth0 state: up speed: 1000 Mbps duplex: full mac: <filter> Drives: Local Storage: total: 3.75 GiB used: 1.74 GiB (46.5%) ID-1: /dev/sda type: USB vendor: SanDisk model: Cruzer size: 3.75 GiB serial: <filter> rev: 6.01 scheme: GPT Partition: ID-1: / size: 467.5 MiB used: 53.1 MiB (11.4%) fs: overlay source: ERR-102 ID-2: /boot size: 486.0 MiB used: 42.1 MiB (8.7%) fs: vfat dev: /dev/sda1 Sensors: Missing: Required tool sensors not installed. Check --recommends Info: Processes: 118 Uptime: 3m Memory: 1.89 GiB used: 266.5 MiB (13.8%) Init: systemd v: 241 runlevel: 5 default: 2 Compilers: gcc: N/A Shell: bash v: 5.0.3 running in: tty 0 (SSH) inxi: 3.0.32 volumio@volumio:~$ aplay -l **** List of PLAYBACK Hardware Devices **** card 0: Audio [Intel HDMI/DP LPE Audio], device 0: HdmiLpeAudio [Intel HDMI/DP LPE Audi] Subdevices: 1/1 Subdevice #0: subdevice #0 card 0: Audio [Intel HDMI/DP LPE Audio], device 1: HdmiLpeAudio [Intel HDMI/DP LPE Audi] Subdevices: 1/1 Subdevice #0: subdevice #0 card 0: Audio [Intel HDMI/DP LPE Audio], device 2: HdmiLpeAudio [Intel HDMI/DP LPE Audi] Subdevices: 1/1 Subdevice #0: subdevice #0 volumio@volumio:~$ aplay -L default Playback/recording through the PulseAudio sound server null Discard all samples (playback) or generate zero samples (capture) jack JACK Audio Connection Kit pulse PulseAudio Sound Server sysdefault:CARD=Audio Intel HDMI/DP LPE Audio, Intel HDMI/DP LPE Audi Default Audio Device hdmi:CARD=Audio,DEV=0 Intel HDMI/DP LPE Audio, Intel HDMI/DP LPE Audi HDMI Audio Output hdmi:CARD=Audio,DEV=1 Intel HDMI/DP LPE Audio, Intel HDMI/DP LPE Audi HDMI Audio Output hdmi:CARD=Audio,DEV=2 Intel HDMI/DP LPE Audio, Intel HDMI/DP LPE Audi HDMI Audio Output dmix:CARD=Audio,DEV=0 Intel HDMI/DP LPE Audio, Intel HDMI/DP LPE Audi Direct sample mixing device dmix:CARD=Audio,DEV=1 Intel HDMI/DP LPE Audio, Intel HDMI/DP LPE Audi Direct sample mixing device dmix:CARD=Audio,DEV=2 Intel HDMI/DP LPE Audio, Intel HDMI/DP LPE Audi Direct sample mixing device dsnoop:CARD=Audio,DEV=0 Intel HDMI/DP LPE Audio, Intel HDMI/DP LPE Audi Direct sample snooping device dsnoop:CARD=Audio,DEV=1 Intel HDMI/DP LPE Audio, Intel HDMI/DP LPE Audi Direct sample snooping device dsnoop:CARD=Audio,DEV=2 Intel HDMI/DP LPE Audio, Intel HDMI/DP LPE Audi Direct sample snooping device hw:CARD=Audio,DEV=0 Intel HDMI/DP LPE Audio, Intel HDMI/DP LPE Audi Direct hardware device without any conversions hw:CARD=Audio,DEV=1 Intel HDMI/DP LPE Audio, Intel HDMI/DP LPE Audi Direct hardware device without any conversions hw:CARD=Audio,DEV=2 Intel HDMI/DP LPE Audio, Intel HDMI/DP LPE Audi Direct hardware device without any conversions plughw:CARD=Audio,DEV=0 Intel HDMI/DP LPE Audio, Intel HDMI/DP LPE Audi Hardware device with all software conversions plughw:CARD=Audio,DEV=1 Intel HDMI/DP LPE Audio, Intel HDMI/DP LPE Audi Hardware device with all software conversions plughw:CARD=Audio,DEV=2 Intel HDMI/DP LPE Audio, Intel HDMI/DP LPE Audi Hardware device with all software conversions usbstream:CARD=Audio Intel HDMI/DP LPE Audio USB Stream Output
Could you, if possible, do a
ls -l /dev
Or, if possible
dmesg
Or perhaps a full volumio log through the UI (which should always work)
like explaned here
Volumio logs:
logs.volumio.org/volumiobuster/1FHsCiM.html
volumio@volumio:~$ ls -l /dev total 0 crw-r--r-- 1 root root 10, 235 Feb 14 2019 autofs drwxr-xr-x 2 root root 280 Feb 14 2019 block drwxr-xr-x 2 root root 60 Jan 1 2015 bsg crw------- 1 root root 10, 234 Feb 14 2019 btrfs-control drwxr-xr-x 3 root root 60 Jan 1 2015 bus drwxr-xr-x 2 root root 2800 Feb 14 2019 char crw------- 1 root root 5, 1 Apr 17 17:06 console lrwxrwxrwx 1 root root 11 Feb 14 2019 core -> /proc/kcore drwxr-xr-x 2 root root 60 Jan 1 2015 cpu crw------- 1 root root 10, 62 Feb 14 2019 cpu_dma_latency crw------- 1 root root 10, 203 Feb 14 2019 cuse drwxr-xr-x 8 root root 160 Feb 14 2019 disk drwxr-xr-x 3 root root 100 Feb 14 2019 dri crw-rw---- 1 root video 29, 0 Feb 14 2019 fb0 lrwxrwxrwx 1 root root 13 Feb 14 2019 fd -> /proc/self/fd crw-rw-rw- 1 root root 1, 7 Feb 14 2019 full crw-rw-rw- 1 root root 10, 229 Feb 14 2019 fuse crw------- 1 root root 248, 0 Feb 14 2019 hidraw0 crw------- 1 root root 248, 1 Feb 14 2019 hidraw1 drwxr-xr-x 2 root root 0 Feb 14 2019 hugepages lrwxrwxrwx 1 root root 12 Feb 14 2019 initctl -> /run/initctl drwxr-xr-x 4 root root 200 Feb 14 2019 input crw-r--r-- 1 root root 1, 11 Feb 14 2019 kmsg crw-rw---- 1 root kvm 10, 232 Feb 14 2019 kvm lrwxrwxrwx 1 root root 28 Feb 14 2019 log -> /run/systemd/journal/dev-log crw-rw---- 1 root disk 10, 237 Feb 14 2019 loop-control brw-rw---- 1 root disk 7, 0 Feb 14 2019 loop0 brw-rw---- 1 root disk 7, 1 Feb 14 2019 loop1 brw-rw---- 1 root disk 7, 2 Feb 14 2019 loop2 brw-rw---- 1 root disk 7, 3 Feb 14 2019 loop3 brw-rw---- 1 root disk 7, 4 Feb 14 2019 loop4 brw-rw---- 1 root disk 7, 5 Feb 14 2019 loop5 brw-rw---- 1 root disk 7, 6 Feb 14 2019 loop6 brw-rw---- 1 root disk 7, 7 Feb 14 2019 loop7 drwxr-xr-x 2 root root 60 Feb 14 2019 mapper crw-r----- 1 root kmem 1, 1 Feb 14 2019 mem crw------- 1 root root 10, 59 Feb 14 2019 memory_bandwidth drwxrwxrwt 2 root root 40 Jan 1 2015 mqueue drwxr-xr-x 2 root root 60 Feb 14 2019 net crw------- 1 root root 10, 61 Feb 14 2019 network_latency crw------- 1 root root 10, 60 Feb 14 2019 network_throughput crw-rw-rw- 1 root root 1, 3 Feb 14 2019 null crw-r----- 1 root kmem 1, 4 Feb 14 2019 port crw------- 1 root root 108, 0 Feb 14 2019 ppp crw------- 1 root root 10, 1 Feb 14 2019 psaux crw-rw-rw- 1 root tty 5, 2 Apr 17 17:12 ptmx drwxr-xr-x 2 root root 0 Feb 14 2019 pts crw-rw-rw- 1 root root 1, 8 Feb 14 2019 random crw-rw-r-- 1 root netdev 10, 242 Feb 14 2019 rfkill lrwxrwxrwx 1 root root 4 Feb 14 2019 rtc -> rtc0 crw------- 1 root root 253, 0 Feb 14 2019 rtc0 brw-rw---- 1 root disk 8, 0 Feb 14 2019 sda brw-rw---- 1 root disk 8, 1 Feb 14 2019 sda1 brw-rw---- 1 root disk 8, 2 Feb 14 2019 sda2 brw-rw---- 1 root disk 8, 3 Feb 14 2019 sda3 crw-rw---- 1 root disk 21, 0 Feb 14 2019 sg0 drwxrwxrwt 2 root root 40 Feb 14 2019 shm crw------- 1 root root 10, 231 Feb 14 2019 snapshot drwxr-xr-x 3 root root 180 Feb 14 2019 snd lrwxrwxrwx 1 root root 15 Feb 14 2019 stderr -> /proc/self/fd/2 lrwxrwxrwx 1 root root 15 Feb 14 2019 stdin -> /proc/self/fd/0 lrwxrwxrwx 1 root root 15 Feb 14 2019 stdout -> /proc/self/fd/1 crw-rw-rw- 1 root tty 5, 0 Feb 14 2019 tty crw--w---- 1 volumio tty 4, 0 Feb 14 2019 tty0 crw--w---- 1 root tty 4, 1 Feb 14 2019 tty1 crw--w---- 1 root tty 4, 10 Feb 14 2019 tty10 crw--w---- 1 root tty 4, 11 Feb 14 2019 tty11 crw--w---- 1 root tty 4, 12 Feb 14 2019 tty12 crw--w---- 1 root tty 4, 13 Feb 14 2019 tty13 crw--w---- 1 root tty 4, 14 Feb 14 2019 tty14 crw--w---- 1 root tty 4, 15 Feb 14 2019 tty15 crw--w---- 1 root tty 4, 16 Feb 14 2019 tty16 crw--w---- 1 root tty 4, 17 Feb 14 2019 tty17 crw--w---- 1 root tty 4, 18 Feb 14 2019 tty18 crw--w---- 1 root tty 4, 19 Feb 14 2019 tty19 crw--w---- 1 root tty 4, 2 Feb 14 2019 tty2 crw--w---- 1 root tty 4, 20 Feb 14 2019 tty20 crw--w---- 1 root tty 4, 21 Feb 14 2019 tty21 crw--w---- 1 root tty 4, 22 Feb 14 2019 tty22 crw--w---- 1 root tty 4, 23 Feb 14 2019 tty23 crw--w---- 1 root tty 4, 24 Feb 14 2019 tty24 crw--w---- 1 root tty 4, 25 Feb 14 2019 tty25 crw--w---- 1 root tty 4, 26 Feb 14 2019 tty26 crw--w---- 1 root tty 4, 27 Feb 14 2019 tty27 crw--w---- 1 root tty 4, 28 Feb 14 2019 tty28 crw--w---- 1 root tty 4, 29 Feb 14 2019 tty29 crw--w---- 1 root tty 4, 3 Feb 14 2019 tty3 crw--w---- 1 root tty 4, 30 Feb 14 2019 tty30 crw--w---- 1 root tty 4, 31 Feb 14 2019 tty31 crw--w---- 1 root tty 4, 32 Feb 14 2019 tty32 crw--w---- 1 root tty 4, 33 Feb 14 2019 tty33 crw--w---- 1 root tty 4, 34 Feb 14 2019 tty34 crw--w---- 1 root tty 4, 35 Feb 14 2019 tty35 crw--w---- 1 root tty 4, 36 Feb 14 2019 tty36 crw--w---- 1 root tty 4, 37 Feb 14 2019 tty37 crw--w---- 1 root tty 4, 38 Feb 14 2019 tty38 crw--w---- 1 root tty 4, 39 Feb 14 2019 tty39 crw--w---- 1 root tty 4, 4 Feb 14 2019 tty4 crw--w---- 1 root tty 4, 40 Feb 14 2019 tty40 crw--w---- 1 root tty 4, 41 Feb 14 2019 tty41 crw--w---- 1 root tty 4, 42 Feb 14 2019 tty42 crw--w---- 1 root tty 4, 43 Feb 14 2019 tty43 crw--w---- 1 root tty 4, 44 Feb 14 2019 tty44 crw--w---- 1 root tty 4, 45 Feb 14 2019 tty45 crw--w---- 1 root tty 4, 46 Feb 14 2019 tty46 crw--w---- 1 root tty 4, 47 Feb 14 2019 tty47 crw--w---- 1 root tty 4, 48 Feb 14 2019 tty48 crw--w---- 1 root tty 4, 49 Feb 14 2019 tty49 crw--w---- 1 root tty 4, 5 Feb 14 2019 tty5 crw--w---- 1 root tty 4, 50 Feb 14 2019 tty50 crw--w---- 1 root tty 4, 51 Feb 14 2019 tty51 crw--w---- 1 root tty 4, 52 Feb 14 2019 tty52 crw--w---- 1 root tty 4, 53 Feb 14 2019 tty53 crw--w---- 1 root tty 4, 54 Feb 14 2019 tty54 crw--w---- 1 root tty 4, 55 Feb 14 2019 tty55 crw--w---- 1 root tty 4, 56 Feb 14 2019 tty56 crw--w---- 1 root tty 4, 57 Feb 14 2019 tty57 crw--w---- 1 root tty 4, 58 Feb 14 2019 tty58 crw--w---- 1 root tty 4, 59 Feb 14 2019 tty59 crw--w---- 1 root tty 4, 6 Feb 14 2019 tty6 crw--w---- 1 root tty 4, 60 Feb 14 2019 tty60 crw--w---- 1 root tty 4, 61 Feb 14 2019 tty61 crw--w---- 1 root tty 4, 62 Feb 14 2019 tty62 crw--w---- 1 root tty 4, 63 Feb 14 2019 tty63 crw--w---- 1 root tty 4, 7 Feb 14 2019 tty7 crw--w---- 1 root tty 4, 8 Feb 14 2019 tty8 crw--w---- 1 root tty 4, 9 Feb 14 2019 tty9 crw-rw---- 1 root dialout 4, 64 Feb 14 2019 ttyS0 crw-rw---- 1 root dialout 4, 65 Feb 14 2019 ttyS1 crw-rw---- 1 root dialout 4, 66 Feb 14 2019 ttyS2 crw-rw---- 1 root dialout 4, 67 Feb 14 2019 ttyS3 crw------- 1 root root 10, 239 Feb 14 2019 uhid crw------- 1 root root 10, 223 Feb 14 2019 uinput crw-rw-rw- 1 root root 1, 9 Feb 14 2019 urandom crw-rw---- 1 root tty 7, 0 Feb 14 2019 vcs crw-rw---- 1 root tty 7, 1 Feb 14 2019 vcs1 crw-rw---- 1 root tty 7, 2 Feb 14 2019 vcs2 crw-rw---- 1 root tty 7, 3 Feb 14 2019 vcs3 crw-rw---- 1 root tty 7, 4 Feb 14 2019 vcs4 crw-rw---- 1 root tty 7, 5 Feb 14 2019 vcs5 crw-rw---- 1 root tty 7, 6 Feb 14 2019 vcs6 crw-rw---- 1 root tty 7, 128 Feb 14 2019 vcsa crw-rw---- 1 root tty 7, 129 Feb 14 2019 vcsa1 crw-rw---- 1 root tty 7, 130 Feb 14 2019 vcsa2 crw-rw---- 1 root tty 7, 131 Feb 14 2019 vcsa3 crw-rw---- 1 root tty 7, 132 Feb 14 2019 vcsa4 crw-rw---- 1 root tty 7, 133 Feb 14 2019 vcsa5 crw-rw---- 1 root tty 7, 134 Feb 14 2019 vcsa6 crw-rw---- 1 root tty 7, 64 Feb 14 2019 vcsu crw-rw---- 1 root tty 7, 65 Feb 14 2019 vcsu1 crw-rw---- 1 root tty 7, 66 Feb 14 2019 vcsu2 crw-rw---- 1 root tty 7, 67 Feb 14 2019 vcsu3 crw-rw---- 1 root tty 7, 68 Feb 14 2019 vcsu4 crw-rw---- 1 root tty 7, 69 Feb 14 2019 vcsu5 crw-rw---- 1 root tty 7, 70 Feb 14 2019 vcsu6 drwxr-xr-x 2 root root 60 Feb 14 2019 vfio crw------- 1 root root 10, 63 Feb 14 2019 vga_arbiter crw------- 1 root root 10, 137 Feb 14 2019 vhci crw------- 1 root root 10, 238 Feb 14 2019 vhost-net crw------- 1 root root 10, 130 Feb 14 2019 watchdog crw------- 1 root root 252, 0 Feb 14 2019 watchdog0 crw-rw-rw- 1 root root 1, 5 Feb 14 2019 zero
are you sure eMMC is enabled?
The device list does not show any signs of eMMC, should be something like ā€œ/dev/mmcblkā€
The log does not show eMMC being initialised either
Yes it is, that’s the problem. If I boot Libreelec on the same machine it’s there.
LibreELEC (official): 9.2.2 (Generic.x86_64) LibreELEC:~ # ls -l /dev total 8 crw-r--r-- 1 root root 10, 235 Jan 1 2015 autofs drwxr-xr-x 2 root root 880 Jan 1 2015 block drwxr-xr-x 2 root root 60 Jan 1 2015 bsg crw-rw---- 1 root disk 10, 234 Jan 1 2015 btrfs-control drwxr-xr-x 3 root root 60 Jan 1 2015 bus drwxr-xr-x 2 root root 3520 Jan 1 2015 char crw------- 1 root root 5, 1 Jan 1 2015 console lrwxrwxrwx 1 root root 11 Apr 11 2019 core -> /proc/kcore drwxr-xr-x 6 root root 140 Jan 1 2015 cpu crw------- 1 root root 10, 62 Jan 1 2015 cpu_dma_latency drwxr-xr-x 8 root root 160 Jan 1 2015 disk drwxr-xr-x 3 root root 100 Apr 11 2019 dri crw------- 1 root root 248, 0 Apr 11 2019 drm_dp_aux0 crw------- 1 root root 248, 1 Apr 11 2019 drm_dp_aux1 crw-rw---- 1 root video 29, 0 Apr 11 2019 fb0 lrwxrwxrwx 1 root root 13 Apr 11 2019 fd -> /proc/self/fd -rw-r--r-- 1 root root 4932 Jan 1 2015 fsck.log crw-rw-rw- 1 root root 1, 7 Jan 1 2015 full crw-rw-rw- 1 root root 10, 229 Apr 11 2019 fuse crw------- 1 root root 254, 0 Apr 11 2019 gpiochip0 crw------- 1 root root 254, 1 Apr 11 2019 gpiochip1 crw------- 1 root root 254, 2 Apr 11 2019 gpiochip2 crw------- 1 root root 254, 3 Apr 11 2019 gpiochip3 crw------- 1 root root 242, 0 Apr 11 2019 hidraw0 crw------- 1 root root 242, 1 Apr 11 2019 hidraw1 crw------- 1 root root 89, 0 Apr 11 2019 i2c-0 crw------- 1 root root 89, 1 Apr 11 2019 i2c-1 crw------- 1 root root 89, 10 Apr 11 2019 i2c-10 crw------- 1 root root 89, 11 Apr 11 2019 i2c-11 crw------- 1 root root 89, 12 Apr 11 2019 i2c-12 crw------- 1 root root 89, 13 Apr 11 2019 i2c-13 crw------- 1 root root 89, 14 Apr 11 2019 i2c-14 crw------- 1 root root 89, 2 Apr 11 2019 i2c-2 crw------- 1 root root 89, 3 Apr 11 2019 i2c-3 crw------- 1 root root 89, 4 Apr 11 2019 i2c-4 crw------- 1 root root 89, 5 Apr 11 2019 i2c-5 crw------- 1 root root 89, 6 Apr 11 2019 i2c-6 crw------- 1 root root 89, 7 Apr 11 2019 i2c-7 crw------- 1 root root 89, 8 Apr 11 2019 i2c-8 crw------- 1 root root 89, 9 Apr 11 2019 i2c-9 lrwxrwxrwx 1 root root 12 Apr 11 2019 initctl -> /run/initctl drwxr-xr-x 4 root root 280 Jan 1 2015 input crw-rw-rw- 1 root root 247, 0 Jan 1 2015 kfd crw-r--r-- 1 root root 1, 11 Jan 1 2015 kmsg lrwxrwxrwx 1 root root 28 Apr 11 2019 log -> /run/systemd/journal/dev-log crw-rw---- 1 root disk 10, 237 Jan 1 2015 loop-control brw-rw---- 1 root disk 7, 0 Jan 1 2015 loop0 crw-r----- 1 root kmem 1, 1 Jan 1 2015 mem crw------- 1 root root 10, 59 Jan 1 2015 memory_bandwidth brw-rw---- 1 root disk 179, 0 Apr 11 2019 mmcblk0 brw-rw---- 1 root disk 179, 32 Jan 1 2015 mmcblk0boot0 brw-rw---- 1 root disk 179, 64 Jan 1 2015 mmcblk0boot1 brw-rw---- 1 root disk 179, 1 Jan 1 2015 mmcblk0p1 brw-rw---- 1 root disk 179, 2 Jan 1 2015 mmcblk0p2 crw------- 1 root root 243, 0 Apr 11 2019 mmcblk0rpmb drwxrwxrwt 2 root root 40 Jan 1 2015 mqueue brw-rw---- 1 root disk 43, 0 Apr 11 2019 nbd0 brw-rw---- 1 root disk 43, 32 Apr 11 2019 nbd1 brw-rw---- 1 root disk 43, 320 Apr 11 2019 nbd10 brw-rw---- 1 root disk 43, 352 Apr 11 2019 nbd11 brw-rw---- 1 root disk 43, 384 Apr 11 2019 nbd12 brw-rw---- 1 root disk 43, 416 Apr 11 2019 nbd13 brw-rw---- 1 root disk 43, 448 Apr 11 2019 nbd14 brw-rw---- 1 root disk 43, 480 Apr 11 2019 nbd15 brw-rw---- 1 root disk 43, 64 Apr 11 2019 nbd2 brw-rw---- 1 root disk 43, 96 Apr 11 2019 nbd3 brw-rw---- 1 root disk 43, 128 Apr 11 2019 nbd4 brw-rw---- 1 root disk 43, 160 Apr 11 2019 nbd5 brw-rw---- 1 root disk 43, 192 Apr 11 2019 nbd6 brw-rw---- 1 root disk 43, 224 Apr 11 2019 nbd7 brw-rw---- 1 root disk 43, 256 Apr 11 2019 nbd8 brw-rw---- 1 root disk 43, 288 Apr 11 2019 nbd9 drwxr-xr-x 2 root root 60 Jan 1 2015 net crw------- 1 root root 10, 61 Jan 1 2015 network_latency crw------- 1 root root 10, 60 Jan 1 2015 network_throughput crw-rw-rw- 1 root root 1, 3 Jan 1 2015 null crw-r----- 1 root kmem 1, 4 Jan 1 2015 port crw------- 1 root root 108, 0 Apr 11 2019 ppp crw-rw-rw- 1 root tty 5, 2 Apr 17 21:44 ptmx drwxr-xr-x 2 root root 0 Apr 11 2019 pts brw-rw---- 1 root disk 1, 0 Apr 11 2019 ram0 brw-rw---- 1 root disk 1, 1 Jan 1 2015 ram1 brw-rw---- 1 root disk 1, 10 Apr 11 2019 ram10 brw-rw---- 1 root disk 1, 11 Jan 1 2015 ram11 brw-rw---- 1 root disk 1, 12 Jan 1 2015 ram12 brw-rw---- 1 root disk 1, 13 Apr 11 2019 ram13 brw-rw---- 1 root disk 1, 14 Apr 11 2019 ram14 brw-rw---- 1 root disk 1, 15 Jan 1 2015 ram15 brw-rw---- 1 root disk 1, 2 Jan 1 2015 ram2 brw-rw---- 1 root disk 1, 3 Jan 1 2015 ram3 brw-rw---- 1 root disk 1, 4 Jan 1 2015 ram4 brw-rw---- 1 root disk 1, 5 Jan 1 2015 ram5 brw-rw---- 1 root disk 1, 6 Jan 1 2015 ram6 brw-rw---- 1 root disk 1, 7 Jan 1 2015 ram7 brw-rw---- 1 root disk 1, 8 Jan 1 2015 ram8 brw-rw---- 1 root disk 1, 9 Jan 1 2015 ram9 crw-rw-rw- 1 root root 1, 8 Jan 1 2015 random crw-rw-r-- 1 root root 10, 58 Jan 1 2015 rfkill lrwxrwxrwx 1 root root 4 Apr 11 2019 rtc -> rtc0 crw------- 1 root root 253, 0 Apr 11 2019 rtc0 brw-rw---- 1 root disk 8, 0 Jan 1 2015 sda brw-rw---- 1 root disk 8, 1 Jan 1 2015 sda1 brw-rw---- 1 root disk 8, 2 Jan 1 2015 sda2 brw-rw---- 1 root disk 8, 3 Jan 1 2015 sda3 crw-rw---- 1 root disk 21, 0 Apr 11 2019 sg0 drwxrwxrwt 2 root root 40 Apr 11 2019 shm drwxr-xr-x 3 root root 240 Jan 1 2015 snd lrwxrwxrwx 1 root root 15 Apr 11 2019 stderr -> /proc/self/fd/2 lrwxrwxrwx 1 root root 15 Apr 11 2019 stdin -> /proc/self/fd/0 lrwxrwxrwx 1 root root 15 Apr 11 2019 stdout -> /proc/self/fd/1 crw-rw-rw- 1 root tty 5, 0 Jan 1 2015 tty crw--w---- 1 root tty 4, 0 Jan 1 2015 tty0 ... LibreELEC:~ # mount devtmpfs on /dev type devtmpfs (rw,relatime,size=1955972k,nr_inodes=488993,mode=755) proc on /proc type proc (rw,relatime) sysfs on /sys type sysfs (rw,relatime) /dev/mmcblk0p1 on /flash type vfat (ro,noatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro) /dev/loop0 on / type squashfs (ro,relatime) /dev/mmcblk0p2 on /storage type ext4 (rw,noatime) tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev) devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000) tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755) tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755) cgroup2 on /sys/fs/cgroup/unified type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate) cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,name=systemd) bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700) cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer) cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio) cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory) cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event) cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices) cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct) cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset) tmpfs on /var type tmpfs (rw,relatime) debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime) mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime) configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime) tmpfs on /tmp type tmpfs (rw,nosuid,nodev) /dev/sda1 on /var/media/volumioboot type vfat (rw,nosuid,nodev,noexec,noatime,fmask=0133,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro) /dev/sda2 on /var/media/volumioimg type ext4 (rw,nosuid,nodev,noexec,noatime,stripe=1024) /dev/sda3 on /var/media/volumio_data type ext4 (rw,nosuid,nodev,noexec,noatime,stripe=1024)
dmesg Output:
gist.github.com/unclejamal3000/ … 61032d1398
OK, let me double check.
Could you send me a download link for your libreelec version?
http://releases.libreelec.tv/LibreELEC-Generic.x86_64-9.2.2.img.gz
I am experiencing two possible bugs?
Possible Bug 1
Updating a library or library folder only seems to work once (the first time) per boot. Updating the second time doesn’t update anything. A reboot and update works fine.
Possible Bug 2
I’m having audio skipping issues. It appears buffer related, when changing buffer settings, and rebooting - the time in the track where the skip occurs changes.
192kHz/24bit FLAC = All files tested skip between approx 0:20 and 1:30 the skip repeats at another random interval later in the track. All files play fine via a different player over the network.
Testing
Version = OTA update of 007 to Volumio X86 2.775
All 44.1kHz/16bit files play OK on Volumio.
Duplicate audio file played locally on PC - OK
Same audio file played from server, via Wifi to PC - OK
Accurip check of album is OK.
Same audio file played in Volumio X86 2.775 - Skips.
I had buffer on default settings. After the skip I’ve changed my settings to:
RAM allocated to Volumio = 12Mb
Buffer Size in Volumio 8Mb
% buffer before playback = 40%
The same file tested = slightly different skip point each time.
Same errors when reverting to version 007.
What is the recommended fix or troubleshooting to help?
I’ll look into this, first time these problems were reported.
May take a few days, but issues noted.
Have you any updates on the Odroid H2? I am getting a blank screen and no action from boot.
I had an Odroid H2 for testing just after it was introduced, never got it to work because we run a 32bit OS on a 64bit system. H2 is one of the few which is not booting a 32bit bit kernel with the 64-bit UEFI loader we are using. The alternative 32bit bootloader won’t run on H2.
So, long story short: not supported, sorry.
