Thanks.
Plugins will not be available yet, but are coming.
See a few posts above
I find out one more thing. I can not migrate usb to SSD because in settings->system it is not available to install on SSD.
I do not get it to work with command line. Do not know what image name to put in.
Correct, but I have no idea why the function has been disabled.
Anyway, as the copy function had issues and was way too slow, it had to be re-factored sooner or later. It is on my to-do list.
The instructions for flashing it manually are on the forum.
I am stopping trying takes to much time, the instructions do not work for me. Maybe I buy a nuc or primo in the future. Not shure which is the best option.
What is the best option know running 3.036 from usb or 2.861 from ssd on my laptop?
… running now 2.861 on ssd the best option for me for now, it is stable , but only with wifi but that does not metters. When there is a new stable release I wil install it. Thx for youre support gkkpch.
graag gedaan
I have installed 3.037 on NUC8i3BEK using an USB no problem. It now recognizes the ethernet network interface !! Wireless interface as well after I disabled Hotstop. Strange…
Mounted my Synoloy NAS drive but no music files displayed even after multiple updates and rescans - even reboot.
There am I, stuck, but at least network interfaces are working now on my NUC8i3BEK.
After an hour or so, the music/audio files magically became visible in the volumio interface…
I am know listening through the built-in NUC analog audio interface with headphone. Not bad !!
Next test will be with with a Denon PM50 DAC amplifier.
Does 3.037 have the plugins now working? Can you post 3.037?
On version 3.036 my network is working Wired and Wireless. Thought my nu had no wifi but it works.
This is my config. Only plugins not working.
System:
Host: volumio Kernel: 5.10.9 x86_64 bits: 64 compiler: N/A Console: tty 0
dm: N/A Distro: Debian GNU/Linux 10 (buster)
Machine:
Type: Mini-pc System: Intel Client Systems product: NUC10i3FNH
v: K61343-302 serial: Chassis: Intel Corporation type: 35 v: 2.0
serial:
Mobo: Intel model: NUC10i3FNB v: K61362-302 serial: UEFI: Intel
v: FNCML357.0032.2019.1021.1624 date: 10/21/2019
CPU:
Topology: Dual Core model: Intel Core i3-10110U bits: 64 type: MT MCP
arch: Kaby Lake rev: C L2 cache: 4096 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 20799
Speed: 3794 MHz min/max: 400/4100 MHz Core speeds (MHz): 1: 3727 2: 3839
3: 1309 4: 3702
Graphics:
Device-1: Intel driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:9b41
Display: tty server: X.org 1.20.4 driver: modesetting unloaded: fbdev,vesa
tty: 80x24
Message: Unable to show advanced data. Required tool glxinfo missing.
Audio:
Device-1: Intel driver: snd_hda_intel v: kernel bus ID: 00:1f.3
chip ID: 8086:02c8
Sound Server: ALSA v: k5.10.9
Network:
Device-1: Intel driver: iwlwifi v: kernel port: 3000 bus ID: 00:14.3
chip ID: 8086:02f0
IF: wlan0 state: up mac:
Device-2: Intel driver: e1000e v: kernel port: efa0 bus ID: 00:1f.6
chip ID: 8086:0d4f
IF: eth0 state: up speed: 1000 Mbps duplex: full mac:
Drives:
Local Storage: total: 119.25 GiB used: 1.92 GiB (1.6%)
ID-1: /dev/sda vendor: Kingston model: SA400S37120G size: 111.79 GiB
speed: 6.0 Gb/s serial: rev: 0102 scheme: MBR
ID-2: /dev/sdb type: USB model: USB DISK 2.0 size: 7.46 GiB
serial: rev: PMAP scheme: GPT
Partition:
ID-1: / size: 4.38 GiB used: 36.5 MiB (0.8%) fs: overlay source: ERR-102
ID-2: /boot size: 170.8 MiB used: 57.4 MiB (33.6%) fs: vfat dev: /dev/sdb1
Sensors:
Missing: Required tool sensors not installed. Check --recommends
Info:
Processes: 180 Uptime: 2m Memory: 7.50 GiB used: 470.8 MiB (6.1%)
Init: systemd v: 241 runlevel: 5 default: 2 Compilers: gcc: N/A
Shell: bash v: 5.0.3 running in: tty 0 (SSH) inxi: 3.0.32
3.037 does not show any plugins on my NUC8*. No idea how to make them work.
i tried to intsall it with github. But than you can only install commands from command line. I am testing it and trying to figure it out how it works. I am stuck on this, how to solve this is above my powers
Installing Spop and libspotify
amd64
–2021-02-25 19:25:01-- http://repo.volumio.org/Packages/Spop/spop-amd64.tar.gz
Resolving repo.volumio.org (repo.volumio.org)… 136.144.176.248
Connecting to repo.volumio.org (repo.volumio.org)|136.144.176.248|:80… connect ed.
HTTP request sent, awaiting response… 301 Moved Permanently
Location: https://repo.volumio.org/Packages/Spop/spop-amd64.tar.gz [following]
–2021-02-25 19:25:02-- https://repo.volumio.org/Packages/Spop/spop-amd64.tar.g z
Connecting to repo.volumio.org (repo.volumio.org)|136.144.176.248|:443… connec ted.
HTTP request sent, awaiting response… 404 Not Found
2021-02-25 19:25:02 ERROR 404: Not Found.
tar: /tmp/spop-amd64.tar.gz: Cannot open: No such file or directory
tar: Error is not recoverable: exiting now
rm: cannot remove ‘/tmp/spop-amd64.tar.gz’: No such file or directory
chmod: cannot access ‘/etc/spopd.conf’: No such file or directory
Linking libsox if required
ln: failed to create symbolic link ‘/usr/local/lib/libsox.so.2’: Permission denied
plugininstallend
volumio@volumio:~/volumio-plugins/plugins/music_service/spotify$
FYI: I am closing this thread, anything version older than 3.0.40 will be obsolete and unsupported!
We are preparing an official beta with new images, the announcement will come within the next 2 days.
Please read the announcement carefully as we expect testers to stick to certain rules.
EDIT: Please note: this topic has now been closed.
pre-versions numbered “3.0nn” can be updated to official betas without reflashing.
For update instructions, set test mode and update.
Note: anything lower than 3.040 is a still a pre-version!
