Volumio X86/ Debian Buster debugging party (BETA)
to help with the wifi issue, i would need the output from dmesg, could you attach that as a file please?
finaly, I was can solve the wifi problem: attaching USB wifi adaptor Tplink wn823N , in the first boot hotspot(192.168.211.1) dissapear and show complete list of wifi avaible, in the next boot without attach usb, simply all was right and I’can to reach mi wifi normaly.
Thank you .
dmesg.txt (62.6 KB) Hi, now have a problem wit an Samsung netbook NC210. problem is that the Web interface don’t show at boot . display an terminal, only , but I can acces to the web ui from smartphone or from another pc via web (ethernet). volumio respond very well recongnize the Dac (d50s) perfectly and play dsd files in direct mode too…
here are the outup to inxi -vFzxxx:
System:    Host: volumio Kernel: 4.19.126 i686 bits: 32 compiler: gcc v: 8.3.0 Console: tty 0 dm: N/A
           Distro: Debian GNU/Linux 10 (buster)
Machine:   Type: Laptop System: SAMSUNG product: NC210/NC110 v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
           Mobo: SAMSUNG model: NC210/NC110 serial: <filter> BIOS: Phoenix v: 00VG.M000.20110105.RHU date: 01/05/2011
Battery:   ID-1: BAT1 charge: 37.0 Wh condition: 37.7/48.8 Wh (77%) volts: 8.2/7.4 model: SAMSUNG Electronics type: Li-ion
           serial: N/A status: Unknown
CPU:       Topology: Single Core model: Intel Atom N455 bits: 64 type: MT arch: Bonnell rev: A L2 cache: 512 KiB
           flags: lm nx pae sse sse2 sse3 ssse3 bogomips: 6649
           Speed: 1085 MHz min/max: 1000/1667 MHz Core speeds (MHz): 1: 1370 2: 1123
Graphics:  Device-1: Intel Atom Processor D4xx/D5xx/N4xx/N5xx Integrated Graphics vendor: Samsung Co driver: i915 v: kernel
           bus ID: 00:02.0 chip ID: 8086:a011
           Display: tty server: X.org 1.20.4 driver: modesetting unloaded: fbdev,vesa alternate: intel tty: 177x52
           Message: Unable to show advanced data. Required tool glxinfo missing.
Audio:     Device-1: Intel NM10/ICH7 Family High Definition Audio vendor: Samsung Co driver: snd_hda_intel v: kernel
           bus ID: 00:1b.0 chip ID: 8086:27d8
           Device-2: Thesycon System & Consulting type: USB driver: snd-usb-audio bus ID: 1-1:2 chip ID: 152a:8750
           Sound Server: ALSA v: k4.19.126
Network:   Device-1: Broadcom Limited BCM4313 802.11bgn Wireless Network Adapter vendor: Wistron NeWeb driver: bcma-pci-bridge
           v: N/A port: 18a0 bus ID: 05:00.0 chip ID: 14e4:4727
           Device-2: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet vendor: Samsung Co RTL810xE driver: r8169
           v: kernel port: 2000 bus ID: 09:00.0 chip ID: 10ec:8136
           IF: eth0 state: up speed: 100 Mbps duplex: full mac: <filter>
           IF-ID-1: wlan0 state: up mac: <filter>
Drives:    Local Storage: total: 494.58 GiB used: 4.73 GiB (1.0%)
           ID-1: /dev/sda vendor: Western Digital model: WD5000LPCX-22VHAT0 size: 465.76 GiB speed: 3.0 Gb/s
           rotation: 5400 rpm serial: <filter> rev: 1A01 scheme: GPT
           ID-2: /dev/sdb type: USB vendor: Kingston model: DataTraveler 3.0 size: 28.82 GiB serial: <filter> scheme: GPT
Partition: ID-1: / size: 24.79 GiB used: 952.6 MiB (3.8%) fs: overlay source: ERR-102
           ID-2: /boot size: 486.0 MiB used: 46.0 MiB (9.5%) fs: vfat dev: /dev/sdb1
Sensors:   Missing: Required tool sensors not installed. Check --recommends
Info:      Processes: 123 Uptime: 25m Memory: 1.95 GiB used: 226.3 MiB (11.3%) Init: systemd v: 241 runlevel: 5 default: 2
           Compilers: gcc: N/A Shell: bash v: 5.0.3 running in: tty 0 (SSH) inxi: 3.0.32
volumio@volumio:~$ aplay -l
card 0: Intel [HDA Intel], device 0: ALC269VB Analog [ALC269VB Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 5: D50s [D50s], device 0: USB Audio [USB Audio]
  Subdevices: 1/1
volumio@volumio:~$ aplay -L
default
    Playback/recording through the PulseAudio sound server
null
    Discard all samples (playback) or generate zero samples (capture)
jack
    JACK Audio Connection Kit
pulse
    PulseAudio Sound Server
sysdefault:CARD=Intel
    HDA Intel, ALC269VB Analog
    Default Audio Device
front:CARD=Intel,DEV=0
    Front speakers
surround21:CARD=Intel,DEV=0
    2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Intel,DEV=0
    4.0 Surround output to Front and Rear speakers
surround41:CARD=Intel,DEV=0
    4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Intel,DEV=0
    5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Intel,DEV=0
    5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Intel,DEV=0
    7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
dmix:CARD=Intel,DEV=0
    Direct sample mixing device
dsnoop:CARD=Intel,DEV=0
    Direct sample snooping device
hw:CARD=Intel,DEV=0
    Direct hardware device without any conversions
plughw:CARD=Intel,DEV=0
    Hardware device with all software conversions
usbstream:CARD=Intel
    HDA Intel
    USB Stream Output
sysdefault:CARD=D50s
    D50s, USB Audio
front:CARD=D50s,DEV=0
    D50s, USB Audio
    Front speakers
surround21:CARD=D50s,DEV=0
    D50s, USB Audio
surround40:CARD=D50s,DEV=0
    D50s, USB Audio
surround41:CARD=D50s,DEV=0
    D50s, USB Audio
surround50:CARD=D50s,DEV=0
    D50s, USB Audio
surround51:CARD=D50s,DEV=0
    D50s, USB Audio
surround71:CARD=D50s,DEV=0
    D50s, USB Audio
iec958:CARD=D50s,DEV=0
    D50s, USB Audio
    IEC958 (S/PDIF) Digital Audio Output
dmix:CARD=D50s,DEV=0
    D50s, USB Audio
dsnoop:CARD=D50s,DEV=0
    D50s, USB Audio
hw:CARD=D50s,DEV=0
    D50s, USB Audio
plughw:CARD=D50s,DEV=0
    D50s, USB Audio
usbstream:CARD=D50s
    D50s
    USB Stream Output
Still no web UI in Samsung NC210…
volumio@volumio:~$ dmesg | grep i915
[   24.923827] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[   24.960771] [drm] Initialized i915 1.6.0 20180719 for 0000:00:02.0 on minor 0
[   25.824983] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
volumio@volumio:~$ lspci -vvnn
00:00.0 Host bridge [0600]: Intel Corporation Atom Processor D4xx/D5xx/N4xx/N5xx DMI Bridge [8086:a010]
        Subsystem: Samsung Electronics Co Ltd Atom Processor D4xx/D5xx/N4xx/N5xx DMI Bridge [144d:c0a8]
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ >SERR- <PERR- INTx-
        Latency: 0
        Capabilities: <access denied>
00:02.0 VGA compatible controller [0300]: Intel Corporation Atom Processor D4xx/D5xx/N4xx/N5xx Integrated Graphics Controller [8086:a011] (prog-if 00 [VGA controller])
        Subsystem: Samsung Electronics Co Ltd Atom Processor D4xx/D5xx/N4xx/N5xx Integrated Graphics Controller [144d:c0a8]
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0
        Interrupt: pin A routed to IRQ 16
        Region 0: Memory at f0200000 (32-bit, non-prefetchable) [size=512K]
        Region 1: I/O ports at 18d0 [size=8]
        Region 2: Memory at d0000000 (32-bit, prefetchable) [size=256M]
        Region 3: Memory at f0000000 (32-bit, non-prefetchable) [size=1M]
        [virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
        Kernel driver in use: i915
        Kernel modules: i915
00:02.1 Display controller [0380]: Intel Corporation Atom Processor D4xx/D5xx/N4xx/N5xx Integrated Graphics Controller [8086:a012]
        Latency: 0
        Region 0: Memory at f0280000 (32-bit, non-prefetchable) [size=512K]
00:1b.0 Audio device [0403]: Intel Corporation NM10/ICH7 Family High Definition Audio Controller [8086:27d8] (rev 02)
        Subsystem: Samsung Electronics Co Ltd NM10/ICH7 Family High Definition Audio Controller [144d:c0a8]
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx+
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0, Cache Line Size: 32 bytes
        Interrupt: pin A routed to IRQ 26
        Region 0: Memory at f0300000 (64-bit, non-prefetchable) [size=16K]
        Kernel driver in use: snd_hda_intel
        Kernel modules: snd_hda_intel
00:1c.0 PCI bridge [0604]: Intel Corporation NM10/ICH7 Family PCI Express Port 1 [8086:27d0] (rev 02) (prog-if 00 [Normal decode])
        Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
        I/O behind bridge: 00003000-00003fff
        Memory behind bridge: f0100000-f01fffff
        Prefetchable memory behind bridge: 0000000080000000-00000000801fffff
        Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
        BridgeCtl: Parity- SERR- NoISA+ VGA- MAbort- >Reset- FastB2B-
                PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
        Kernel driver in use: pcieport
00:1c.1 PCI bridge [0604]: Intel Corporation NM10/ICH7 Family PCI Express Port 2 [8086:27d2] (rev 02) (prog-if 00 [Normal decode])
        Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Interrupt: pin B routed to IRQ 17
        Bus: primary=00, secondary=07, subordinate=07, sec-latency=0
        I/O behind bridge: 00004000-00004fff
        Memory behind bridge: 80200000-803fffff
        Prefetchable memory behind bridge: 0000000080400000-00000000805fffff
        BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
00:1c.2 PCI bridge [0604]: Intel Corporation NM10/ICH7 Family PCI Express Port 3 [8086:27d4] (rev 02) (prog-if 00 [Normal decode])
        Interrupt: pin C routed to IRQ 18
        Bus: primary=00, secondary=09, subordinate=09, sec-latency=0
        I/O behind bridge: 00002000-00002fff
        Memory behind bridge: 80600000-809fffff
        Prefetchable memory behind bridge: 00000000f0500000-00000000f05fffff
00:1c.3 PCI bridge [0604]: Intel Corporation NM10/ICH7 Family PCI Express Port 4 [8086:27d6] (rev 02) (prog-if 00 [Normal decode])
        Interrupt: pin D routed to IRQ 19
        Bus: primary=00, secondary=0b, subordinate=0b, sec-latency=0
        I/O behind bridge: 00005000-00005fff
        Memory behind bridge: 80a00000-80bfffff
        Prefetchable memory behind bridge: 0000000080c00000-0000000080dfffff
00:1d.0 USB controller [0c03]: Intel Corporation NM10/ICH7 Family USB UHCI Controller #1 [8086:27c8] (rev 02) (prog-if 00 [UHCI])
        Subsystem: Samsung Electronics Co Ltd NM10/ICH7 Family USB UHCI Controller [144d:c0a8]
        Control: I/O+ Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0
        Interrupt: pin A routed to IRQ 23
        Region 4: I/O ports at 1820 [size=32]
        Kernel driver in use: uhci_hcd
        Kernel modules: uhci_hcd
00:1d.1 USB controller [0c03]: Intel Corporation NM10/ICH7 Family USB UHCI Controller #2 [8086:27c9] (rev 02) (prog-if 00 [UHCI])
        Latency: 0
        Interrupt: pin B routed to IRQ 19
        Region 4: I/O ports at 1840 [size=32]
00:1d.2 USB controller [0c03]: Intel Corporation NM10/ICH7 Family USB UHCI Controller #3 [8086:27ca] (rev 02) (prog-if 00 [UHCI])
        Latency: 0
        Region 4: I/O ports at 1860 [size=32]
00:1d.3 USB controller [0c03]: Intel Corporation NM10/ICH7 Family USB UHCI Controller #4 [8086:27cb] (rev 02) (prog-if 00 [UHCI])
        Latency: 0
        Interrupt: pin D routed to IRQ 16
        Region 4: I/O ports at 1880 [size=32]
00:1d.7 USB controller [0c03]: Intel Corporation NM10/ICH7 Family USB2 EHCI Controller [8086:27cc] (rev 02) (prog-if 20 [EHCI])
        Subsystem: Samsung Electronics Co Ltd NM10/ICH7 Family USB2 EHCI Controller [144d:c0a8]
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
        Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0
        Region 0: Memory at 80e00000 (32-bit, non-prefetchable) [size=1K]
        Kernel driver in use: ehci-pci
        Kernel modules: ehci_pci
00:1e.0 PCI bridge [0604]: Intel Corporation 82801 Mobile PCI Bridge [8086:2448] (rev e2) (prog-if 01 [Subtractive decode])
        Latency: 0
        Bus: primary=00, secondary=11, subordinate=11, sec-latency=32
        Secondary status: 66MHz- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
00:1f.0 ISA bridge [0601]: Intel Corporation NM10 Family LPC Controller [8086:27bc] (rev 02)
        Subsystem: Samsung Electronics Co Ltd NM10 Family LPC Controller [144d:c0a8]
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0
        Kernel driver in use: lpc_ich
        Kernel modules: lpc_ich
00:1f.2 SATA controller [0106]: Intel Corporation NM10/ICH7 Family SATA Controller [AHCI mode] [8086:27c1] (rev 02) (prog-if 01 [AHCI 1.0])
        Subsystem: Samsung Electronics Co Ltd NM10/ICH7 Family SATA Controller [AHCI mode] [144d:c0a8]
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
        Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0
        Interrupt: pin B routed to IRQ 24
        Region 0: I/O ports at 18e8 [size=8]
        Region 1: I/O ports at 18dc [size=4]
        Region 2: I/O ports at 18e0 [size=8]
        Region 3: I/O ports at 18d8 [size=4]
        Region 4: I/O ports at 18c0 [size=16]
        Region 5: Memory at 80e00400 (32-bit, non-prefetchable) [size=1K]
        Kernel driver in use: ahci
00:1f.3 SMBus [0c05]: Intel Corporation NM10/ICH7 Family SMBus Controller [8086:27da] (rev 02)
        Subsystem: Samsung Electronics Co Ltd NM10/ICH7 Family SMBus Controller [144d:c0a8]
        Control: I/O+ Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
        Region 4: I/O ports at 18a0 [size=32]
        Kernel driver in use: i801_smbus
        Kernel modules: i2c_i801
05:00.0 Network controller [0280]: Broadcom Limited BCM4313 802.11bgn Wireless Network Adapter [14e4:4727] (rev 01)
        Subsystem: Wistron NeWeb Corp. BCM4313 802.11bgn Wireless Network Adapter [185f:051a]
        Region 0: Memory at f0100000 (64-bit, non-prefetchable) [size=16K]
        Kernel driver in use: bcma-pci-bridge
        Kernel modules: bcma
09:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller [10ec:8136] (rev 05)
        Subsystem: Samsung Electronics Co Ltd RTL810xE PCI Express Fast Ethernet controller [144d:c0a8]
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx+
        Interrupt: pin A routed to IRQ 18
        Region 0: I/O ports at 2000 [size=256]
        Region 2: Memory at f050c000 (64-bit, prefetchable) [size=4K]
        Region 4: Memory at f0508000 (64-bit, prefetchable) [size=16K]
        Kernel driver in use: r8169
        Kernel modules: r8169
There is a new beta version out, this will bring volumio functionality up to the current level.
See opening post.
2020-12-11, version 2.857
http://updates.volumio.org/x86/volumiobuster/2.857/volumiobuster-2.857-2020-12-11-x86.img.zip
Over the next couple of weeks we are going to push the buster ports for arm (rPI) and x86 (x86-amd64) in parallel.
We hope to get most of it done by the start of the new year (finally).
@dvo: I think you hit the wrong thread, this is about x86 :wink:
Thanks very much ! gkkpch. I’probe the last version x 86 (version 2857) in my netbook Samsung NC210, but still the same problem : not web ui in the netbook , but i can acces to volumio from another PC or smartphone without problem. only show:
Yes, there appears to be a graphics device issue which others have reported.
There is not much I can do at the moment, except asking for more details using the info in the opening post of this thread.
There is no promise to solve this, we are aware that there are soooooo many different x86 configurations out there, it is very difficult to cover them all with the resources we have.
We’re not Debian or Ubuntu, just a very small number of developers :innocent:
But, as you have access, could you produce a log from the http://your-ip/dev page?
That would also help.
Note for me: Samsung NC210 has Intel GMA 3150
Log Live.txt (35.3 KB)
live log doesn’t help.
please use the log function from the dev page, it will return a url which i can use to look at the complete log starting with boot.
Thank you gkkpch!
http://logs.volumio.org/volumiobuster/7VW3Dv3.html
That helped, it seems the X system (needed for displaying the UI) fails to start.
I need to investigate, this will take a while though.
Depends on guesswork because I do not have such hardware.
Thank you very very much!!
Just commenting that the standard volumio x86 version 2853 boot ok on this hardware, show correctly web UI at startup, but obviously dont recognize very well the Dac Topping D50s (DSD work fine only in dop , not DSD direct. (https://volumio.org/get-started/)
good to know, perhaps there is a graphics component or some firmware missing.
Problem with D50 is a known one, like a few other usb dacs.
Can’t be solved as it would need a kernel update and I can’t do that, kernel is too old.
Best Regards gkkpch, Thank you very much :grinning: :grinning:
Hi gkkpch . i have a question : thereś any way to add or incorporate the Spotify complement in the last version or any other of Volumio debian buster x86 , I Know that your work exclude de plug-ins but , in this moment .i have the two versions: the official with very old kernel , not functionality DSD for mi dac and stil work with Spotify , and the last one Debian Buster with all functionalities but without Spotify plug -in.
Thank you very much
Mario
Yes, that is an open issue for the pre-release.
Working on it, will let you know when ready.
:+1: :+1:
I installed the 2.857 on my Minix Z64. Its working fine and connected via eth0. I only found these issues so far.
  1. Volumio not shown as device under Airplay in IPhone.
    ---- The shairport-sync is enabled under the sources settings. But when i check the status of the
    shairport-sync.service it gives the below error details
            volumio@volumio:/tmp$ systemctl status shairport-sync.service
ā— shairport-sync.service - Shairport Sync - AirPlay Audio Receiver
Loaded: loaded (/lib/systemd/system/shairport-sync.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sun 2020-12-27 14:20:27 UTC; 3h 21min ago
Process: 1425 ExecStart=/usr/local/bin/shairport-sync --configfile=/tmp/shairport-sync.conf (code=exited, status=203/EXEC)
Main PID: 1425 (code=exited, status=203/EXEC)
When i enabled the verbose mode 1 and restarted the service, i get the message below
shairport-sync.service: Failed at step EXEC spawning /usr/local/bin/shairport-sync: No such file or directory
  1. Plugins are missing under the search plugins service even though i am able to access internet.
    ---- I ran the below and got the results successfully but not shown under search plugins.
    arch=$(dpkg --print-architecture)
    curl -L http://plugins.volumio.org/plugins/volumio/${arch}/plugins.json
  2. When i try to install plugins (tried ) manually using ā€œvolumio plugin installā€, the process does not progress beyond status ā€œPlugin succesfully compressedā€
