Dear Volumio team,
I have an issue when play .dsf file on both of Native DSD and DoP method if I set the mixer as hardware mode(FXAUDIO).
If I change the mixer to software mode, it can play the .dsf file with hearable sound
Please help to check my setup if I can do something to fix the issue
If need to add FXAUDIO (FX7) to the kernel to signal alsa that this device can play DSD files natively => Please help me.
Please find my setup as below:
- System information
OS info
Version of Volumio: 2.779
Hostname: volumio
Kernel: 4.19.86-v7+
Governor: performance
Uptime: 0 days, 0 Hrs, 16 Minutes, 46 Seconds
Audio info
Hw audio configured: FX-AUDIO
Mixer type: Hardware
Number of channels: 2
Board info
Model: BCM2835 - Pi 3 Model B
Version: a02082 - Rev. 1.2
Firmware Version: Nov 29 2019 18:46:15 - 7d5bdbd77968098c981dadefae06aaec79354c69
CPU info
Brand: Processor rev 4 (v7l)
Speed: 1.20Mhz
Number of cores: 4
Physical cores: 4
Average load: 25%
Temperature: 64°C
Memory info
Memory: 992956 Ko
Free: 153748 Ko
Used: 839208 Ko
Storage info
INTERNAL storage - Size: 12492Mo Used: 229Mo Available: 11607Mo (93%)
volumio@volumio:~$ aplay -l
card 0: b1 [bcm2835 HDMI 1], device 0: bcm2835 HDMI 1 [bcm2835 HDMI 1]
Subdevices: 4/4
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
card 1: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
Subdevices: 4/4
card 2: sndrpihifiberry [snd_rpi_hifiberry_dac], device 0: HifiBerry DAC HiFi pcm5102a-hifi-0 [HifiBerry DAC HiFi pcm5102a-hifi-0]
Subdevices: 1/1
card 5: FXAUDIO [FX-AUDIO], device 0: USB Audio [USB Audio]
Subdevices: 1/1
volumio@volumio:~$
3/
volumio@volumio:~$ lsusb -d 20b1:
Bus 001 Device 005: ID 20b1:0002 XMOS Ltd
Bus 001 Device 004: ID 090c:1000 Silicon Motion, Inc. - Taiwan (formerly Feiya Technology Corp.) Flash Drive
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
volumio@volumio:~$
volumio@volumio:~$ cat /proc/asound/card*/stream0
FX-AUDIO FX-AUDIO at usb-3f980000.usb-1.4, high speed : USB Audio
Playback:
Status: Stop
Interface 1
Altset 1
Format: S32_LE
Channels: 2
Endpoint: 1 OUT (ASYNC)
Rates: 44100, 48000, 88200, 96000, 176400, 192000, 352800, 384000
Data packet interval: 125 us
Interface 1
Altset 2
Format: S16_LE
Channels: 2
Interface 1
Altset 3
Format: SPECIAL DSD_U32_BE
Channels: 2
volumio@volumio:~$
Thank you very much !!!
when it try to play an DSD64 file i get 192kHz and 24bit PCM in the display of the dac8 pro
