Volumio wifi connection
I set up a Wi-Fi hotspot using a USB WLAN adapter. It was working but sometimes the connection would be choppy due to the distance of the host PC. There is a different PC that is closer to where I normally listen to so I moved the adapter and set up shop. However, I can no longer connect to Volumio through WIFI??? All other devices connect fine, smart watch, cell phone, tablet, and even the same RPI3 if I’m using Rasbian or PINN to connect. I can still connect Volumio to WIFI on my home network. Not sure what changed but something did.
I was able to fix this issue by reinstall, more on that in new thread. Don’t know the root cause but guessing that volumio saves the authentication parameters with ssid, obvious through “auto” connect after creating a network association and they didn’t match, new pc = new ip & mask. I’m sure you can ALT F1 and manually change this if you know the path. I could have just as easily changed the ssid but my setup is running in a secure itar location where all wireless connections have to be registered with a 2 week processing time after application and i didn’t want to wait.
