Volumio stops playing randomly after days of continuos play
I have recently set up my Raspberry Pi 4 with a DAC Mini Hat PCM5122 audio card, and set up the Volumio player to run the hold music of our phone lines. The issue we keep running in to is that the player just stops after a few days of playing, and someone has to log into the player and press play to get the music going again. When I log into the device, the track is at the beginning just waiting to be played. I have it set to continuous play as well. Has anyone else encountered this/have a suggestion on how to fix this?
Please send a log when the device stops playing.
Logs are the difference between troubleshooting and fortune-telling. Right now we’re dangerously close to the fortune-telling part
Steps to Generate and Post a Log
  • Open the DEV Page: Type http://volumio.local/dev or http://<your-device-ip>/dev into your browser address bar.
  • Trigger the Log: Scroll down until you see the bug report section, then click the Send Log button.
  • Copy the Link: Wait for the confirmation message containing a URL (e.g., http://logs.volumio.org/xxxxxx) and click copy.
  • Share: Paste the copied link into your forum post
Thanks for the heads up, ive enabled logs now. When the issue happens again, I will post the logs I get from that.
