Volumio device stops playing but status shows playing
I have several (20+) raspberry Pi 4’s setup with the current version of volumio.
where I have these plugged in some times the network goes down and the device
will stop playing. I wrote a script to look at the output of the volumio status command
that will run the command volumio play when the status shows anything other than
play. the only problem is that many of the times the status still shows play when
I run the command so the script does not fix it. 2 or 3 devices have this issue each
week.
thanks for the help.
CJ
