Volumio stopped playing
Hello
Suddenly I can’t get the volumio player playing music anymore. I push the play button and the response is green and ok but nothing happens. I also use Roon to connect the allo server and this works good.
Probably the roon installation you’ve made keeps the audio device busy
Thanks but is there an solution for this? The past week they worked fine together.
