I’ve just started using Volumio as a dlna-renderer for Audirvana and everything works fine, but the displayed bitdapth in incorrect.
Volumio shows 32-bit, when the file is in fact 24-bit. Audirvana and my dac both show the correct 24/96.
Playing the same file directly on Volumio shows the correct 24/96.
I have the same issue with my Hifiberry Amp2 and the Digi2 Pro and don’t have any type of resampling or volume levelling active.
{“status”:“play”,“position”:0,“title”:“Inclination”,“artist”:“Steven Wilson”,“album”:“The Harmony Codex”,“albumart”:“/albumart?cacheid=909&web=Steven%20Wilson/The%20Harmony%20Codex/extralarge”,“uri”:“http://192.168.30.85:49152/audirvana/audio_f_12.wav",“trackType”:“wav”,“seek”:10002,“duration”:436,“samplerate”:"96 kHz”,“bitdepth”:“32 bit”,“channels”:2,“bitrate”:null,“random”:null,“repeat”:null,“repeatSingle”:false,“consume”:true,“volume”:100,“dbVolume”:null,“mute”:false,“disableVolumeControl”:true,“stream”:false,“updatedb”:false,“volatile”:false,“service”:“mpd”}
