# Volumio set up USB audio with R Pi B+
**URL:** <https://community.volumio.com/t/volumio-set-up-usb-audio-with-r-pi-b/4349>\
**Category:** Help\
**Created:** [September 27, 2016, 10:56am UTC](https://community.volumio.com/t/volumio-set-up-usb-audio-with-r-pi-b/4349 "2016-09-27T10:56:13Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![Builder\_Brad](https://community.volumio.com/letter_avatar_proxy/v4/letter/b/c89c15/32.png) [@Builder\_Brad](https://community.volumio.com/u/Builder_Brad)\
**Post date:** [September 27, 2016, 10:56am UTC](https://community.volumio.com/t/volumio-set-up-usb-audio-with-r-pi-b/4349/1 "2016-09-27T10:56:13Z")
</div>
Hi everyone,
I want to get my Raspberry pi B+ that is running Volumio to output Audio on the USB port. I have one port with a WiFi dongle and now want to see if I can get a DIYINHK usb to i2s module working.
What do I need to do for this to work? There does not appear to be an option in Volumio settings for USB Audio.
Thankyou
Brad
**Author:** ![volumio](https://community.volumio.com/user_avatar/community.volumio.com/volumio/32/3_2.png) [@volumio](https://community.volumio.com/u/volumio)\
**Post date:** [September 27, 2016, 11:13am UTC](https://community.volumio.com/t/volumio-set-up-usb-audio-with-r-pi-b/4349/2 "2016-09-27T11:13:17Z")
</div>
Yes there is, connect your DAC to USB, then go to playback options and select the output device accordingly
**Post date:** [September 27, 2016, 5:56pm UTC](https://community.volumio.com/t/volumio-set-up-usb-audio-with-r-pi-b/4349/3 "2016-09-27T17:56:20Z")
</div>
Cheers Michelangelo,
Will do, although I’m not actually using a DAC I’m using a USB to i2s converter that is going to be connected to a Minisharc.
**Post date:** [September 28, 2016, 9:41am UTC](https://community.volumio.com/t/volumio-set-up-usb-audio-with-r-pi-b/4349/4 "2016-09-28T09:41:43Z")
</div>
Ah ok.
Under output devices, I only have the option for hdmi output and headphone output.
I can also enable i2s output, but there is no reference to USB audio
**Author:** ![seveneleven](https://community.volumio.com/letter_avatar_proxy/v4/letter/s/5e9695/32.png) [@seveneleven](https://community.volumio.com/u/seveneleven)\
**Post date:** [February 27, 2021, 4:39pm UTC](https://community.volumio.com/t/volumio-set-up-usb-audio-with-r-pi-b/4349/5 "2021-02-27T16:39:12Z")
</div>
I‘m with the same problem. How did you solved it?
thanks
