Volumio Rivo Plus OS 3.912 -> processor to 130%
I still do have some trouble with my Volumio Rivo Plus.
It is running the software version 3.912
The basic start up is within approx 30 seconds. That is reasonable and well, I can live with that. Compared to other brands, it is still slow. But ok.
But after the general boot and startup, Volumio is doing something, that increase the CPU to 100 or even 130%.
The result is that the UI is complete death. No reaction, no visualisation, no NAS or SSD or music, nothing and nothing is the result.
This proces is taking several minutes, up to half an hour. Than “something” is finished and Volumio and the Rivo Plus are running smooth and good.
But after each rebout this is a very annoying issue that drive me a bit crazy.
Anybody know the cause and the solution.
And what about this issue, within Volumio 4?
My library is approx 75000 flac files, just for the information.
I use FusionDSP → but without installation or when OFF, I do see the same behaviour after a rebout, so that is not the cause.
I am quite interestend and looking forward to some information for the time Volumio 3 is running. And I am interested what about this kind of issue’s within Volumio 4.
edit: several factory resets do not make any difference
edit 2 from the live LOG, ChatGPT is not able to find a couse
As Rivo Plus owner you’re entitled to premium support. The community can’t give much support on Volumio HW as we don’t have their knowledge base.
Please open a support ticket here.
