Would be cool to be able to use Flirc (usb IR receiver) with my Volumio Rivo (still on v3) and controll just the basic functions (Play/pause, Stop, next song, previous song) with a simple 4-button remote. Anyone who can help me set this up?
Thanks.
Thanks.
… tried it, but at least with my setup the sound quality degrades badly when the Flirc is plugged into the Rivo(+).
I know, not the info you’re looking for, just saying.
YMMV
I’ve just plugged in the dongle that comes with the G60S, S Pro Air Remote.
Mouse navigation works fine.
That’s all I’ve tried so far but looks promising.
@Goran08 I use the flirc with RIVO and its awesome. You plug the FLIRC USB into your PC, download the software, and then select media center or whatever the most basic is and then use your remote to program Play FF Back Pause etc. It works great. I actually used the Volumio Remoto remote to do it and it works great. I did a review of this on the REMOTO remote site but in short I can work the Preciso and the Rivo simultaneously using the one remote.
