@DED I think some help is required
Hi Shumer, Iāve had the Volumio Primo for 2 years and use it purely as a streamer to the Lyngdorf. Whenever minor problems occur, which is very rare, it is ABSOLUTELY ADVISABLE to connect the Primo to the router via cable in order to restore the Internet connection - your home network. After that WiFi worked fine again.
will reach out to you to help you out.
The questions you are making are out of the scope of this thread and IMO a very rare usecase.
Hooray it turned out, thatās just it turned out on a tablet on the HarmonyOS operating system, downloaded the application via aptoid.The Volumio app does not launch on the oneplus 8T smartphone.another question, there are files with music on the tablet, but the volumio application does not see them, what should I do?
Good evening, what is the type c port for?
the TYPE-C port is for service maintenance, it canāt be used at the moment
Hello @Shumer !
Please reach me HERE
I will be happy to help you finding a way out
Davide
VOLUMIO TECH SUPPORT
Why volumio reproduces dsd 128 with a stuttering interrupt,then the device freezes. I rebooted it and it doesnāt see the hard drive.
You canāt help me with anything, since Iām running the volumio app on huawei mediapad pro.why does Rivo play dsd 128 with a stutter?How or with what program can I play movies on rivo?also, after disconnecting the power from the mains, riva does not see the flash drive that is connected to the USB input.
Iām still waiting for my Volumio Rivo to arrive at my dealer. I plan to place all my local files on a 1TB micro SD card inserted in the Rivo. This will work, right?
Apparently, I need to rename the card in order for that to work. Could you please tell me how I rename it?
Thank you
1TB will work fine, please use a good-brand one
the SD must be labeled āissdā for being recognized properly by Rivo.
to do so, if you have a Windows PC just connect it with a card-reader, after being recognized right-click on it and select āPropertiesā
in the āGeneralā tab, you can type the label, then press āOKā to save
please contact @DED for support
Brilliant. Thank you very much. I hadnāt figured out I had to rename it on my PC.
Why is my tariff plan free when it should be premium?
Create a support ticket as earlier informed, then the support people can answer all your questions in a structured way and this thread can go back to its original purpose.
