Volumio resetting pi
Raspberry pi4 8g. Resetting is because of sd card not being A1 or power adapter not being original pi?
Please read all your previous post and our replies.
No Log, no support.
Maybe someone will be kind to explain why it resets
Help me understand
How do you expect us to know something in front of you is failing?
We don’t do psychic debugging. No crystal ball, no tarot, no telepathic SSH, just logs.
And without those, we’re basically guessing… and guessing isn’t a great support strategy.
No logs? Then all you’ve posted is a mystery novel with the last chapter missing.
Using moode now. When i give volumio a try i will try to get the log.
Thats how volumio.local/dev behaves
And that has nothing to do with Volumio, but your Router.
Done with Moode ???
This is an mDNS issue. Try rebooting your router or use the IP address instead. This is not a Volumio issue.
(Or you didn’t call the device Volumio, but something else, then it’s: <yourdevicename>/dev)
New issue. Just hit pause on my useful usb remote… it fast forward, sorry.
Let’s hope the community will support you. I am done with the one-liners, sorry.
Sorry but if it worked as it should there wont be complains right minen freund?
Stop being obtuse.
Explain the issues you are experiencing properly.
Respond properly to requests for more information and log files.
I am not your friend, I’m a volunteer donating my free time to help people.
Unfortunately, you’ve made that nearly impossible.
You provide one-line problem descriptions, refuse to supply the requested technical details, keep opening new topics, and keep introducing new issues without ever giving feedback on the previous ones.
At this point, helping you feels a bit like diagnosing a car over the phone while the owner refuses to tell you which warning light is on.
This will be my last response to you. Good luck.
