Volumio reading Music library but no track info being listed
I have A Qnap TS 251(2bay) I have Volumio 2018 and I have mounted the music folder on the NAS. Its reading Everything on there but only listing the Artist folders name & in that folder the album name but when you open any of them all the tracks are there but no info not even a track number.
I have tried several remounts & it does the same I even tried altering the command for the metadata compilation field with this: (Track Number, Track Title, - , Artist, .file type.,) As I would like to have for example (01 So Far Away - Dire Straits.Flac) not really bothered if file type not in it but thats the format I am used to with previous Volumio listings.
I have also noticed that one or two do have their data written in so I compared them in foobar. It shows that I used EAC (Exact Audio Copy) to rip all my music) Which Refers to the file labelling for its data but does not write any metadata where as a few has it which I am quite miffed about. I proved this by using foobar to set some metadata & then asked Volumio to update drive & the data appeared but to do this to over a 2TB drive will take weeks so here’s hoping you can remedy this for me. As I say its worked ok on previous Volumio versions so its something i’m missing.
