@vennesch
I haven’t tried that. How, but I’m writing after restarting Prima, everything works again for a while. Somehow I can’t help feeling that the solution you write is not quite what I would have imagined.
The problem still persists. Clearing app data has no effect. Would it help if I added a log? as I wrote, the Volumio Control alternative app always works the first time. Could there be a problem in the fact that a woman joins Primo at the same time? i.e. more users.
Is there a list of differences between Primo 1 and 2 available?
Obviously we get the externals - the box, led, powerswitch, balanced outs and micro SD slot (nice touch!), but what about inside? It’s the same DAC but I note for instance the specs state:
Amlogic Quadcore CPU running at 1.9GHz
is this the same as v1 or an upgrade? Any other diffs?
@kzboray I have the same Harmony Elite remote as you do. Did you end up getting it to work on the Primo? I am planning to buy the Rivo and will likely face the same issue.
As of now, it seems @volumio still hasn’t added Primo or Rivo to the Harmony database yet. I wonder what the hold-up is.
I ended up using a FLIRC which allows me to advance to the next song, and play / pause. It’s limited functionality, but it covers the most basic needs. There doesn’t seem to be a key mapping in Volumio for up / down / left / right, but maybe one day!
probably because it is not seen as Volumio’s responsibility to feed a Logitech Harmony Database.
Was there a promise somewhere? I don’t think so.
It is normal with the Harmony devices, that this is done by users for users.
I should get a Rivo next week and I’m also interested in getting this to work with an older Logitech Harmony 555. Luckily I have a Khadas remote here to help the Logitech learn the codes. Not a promise for next week, but it will be done soon.
Thanks very much for the fast reply. Qobuz have now finally emerged from a lengthy radio silence on this topic. Perhaps a beta version within 2 months:
I’ve been a big fan of Volumio since version 2.0! Good job!
Now… that it’s no longer a secret what’s inside Primo v2, is it possible to get an image of the Volumio 3 system prepared for VIM3L SBC? Not every fan of good sound will buy this fantastic hardware from you… I think many of us here would appreciate it!
