When using Wiim ultra as a transport into Volumio Preciso via usb - experiencing static like sounds from both speakers. These do not increase with attenuation, are not audible when music is not playing.
Sonically identical to static from a newly played vinyl album.
Should I buy another cable (usb a to b) or try a usb isolator?
All cabling is routed sensibly as are the units sensibly placed.
Suggestions appreciated.
Before buying a cable or USB isolator, have you compared the WiiM’s USB output with another DAC, or tried another USB source with the Preciso, using equipment you already have? That could help narrow down whether the noise is specific to this pairing. Also, what USB output resolution is selected in the WiiM Home app? WiiM’s USB output guide documents that setting, but it does not establish a fix for the noise you describe.
Hast du einen anderen USB-Anschluss am Preciso ausprobiert oder den Wiim Ultra mit einem anderen Gerät getestet, um zu sehen, ob das Rauschen weiterhin auftritt? So ließe sich möglicherweise eingrenzen, ob das Problem am Kabel, am USB-Anschluss oder an der konkreten Kombination der beiden Geräte liegt.
Google translate:
Have you tried a different USB port on the Preciso or tested the Wiim Ultra with another device to see if the noise persists? This might help narrow down whether the problem lies with the cable, the USB port, or the specific combination of the two devices.
Please in English!
