Volumio Pi4 no longer accessible
I had volumio working fine on my Pi4. Then it stopped working mid song and I couldn’t connect to it via app or browser window.
I did a fresh reinstall on the SD card, I connected via the volumio hot spot and configured the wifi.
Now I still can’t connect via browser or app
The Pi4 is booting correctly, my windows 11 can see it in network (but can’t access it) and my router has it assigned a static IP.
How can I resolve this
Are you using volumio.local in the browser address bar? Maybe try the ip-address instead. Try using a dynamic IP instead.
Thanks for the reply
I’ve tried both with no success
Try re-starting your router.
Does the pi have a static ip or dhcp ip?
When it was working it was dynamic checked router couldn’t see any IP conflicts
I did another reinstall on the SD card and now it’s working again
Very odd
nice that it all is working again if you set on dhcp you ip can change then you need a tool to find it.
if you don’t have a screen on it otherwise it will show up after volumio boots.
