Think I posted this in the wrong area so moved to here:
Booted Sparky (with or without USBridge) on latest Volumio, Came up first boot fine and went through usual startup sequence. Once all was looking fine I rebooted but all subsequent boots fail in that IP for Volumio is visible to my router (wired connection) but unable to access Volumio via Chrome using its IP address.
Tried this on an RPi and all was fine, accessed multiple times after reboots.
I have the same issue with the same device.
It happens since the latest version was installed (2.699)
The webserver can’t be found anymore via the android app or the webbrowser (volumio.local).
log says:
Jan 30 09:35:26 volumio volumio[10154]: info: -------------------------------------------
Jan 30 09:35:26 volumio volumio[10154]: info: ----- Volumio2 ----
Jan 30 09:35:26 volumio volumio[10154]: info: ----- System startup ----
Jan 30 09:35:26 volumio volumio[10154]: info: MYVOLUMIO Environment detected
Jan 30 09:35:26 volumio snapclient[10093]: Exception in Controller::worker(): connect: Connection refused
Jan 30 09:35:26 volumio snapclient[10093]: Error in socket shutdown: Transport endpoint is not connected
Jan 30 08:15 : zeroconf: No global port, disabling zeroconf
Jan 30 08:15 : client: [0] opened from local
Jan 30 08:15 : client: [1] opened from local
Jan 30 08:15 : client: [1] closed
Jan 30 08:15 : client: [0] closed
Jan 30 08:16 : client: [0] opened from local
Jan 30 08:16 : client: [1] opened from local
Jan 30 08:16 : client: [1] closed
Jan 30 08:16 : client: [0] closed
Jan 30 08:16 : zeroconf: No global port, disabling zeroconf
trying to do (what i found on the interwebs)
volumio@volumio:~$ mpd --verbose --stdout --no-daemon
config_file: loading file /etc/mpd.conf
exception: Failed to bind to ‘[::]:6600’
exception: nested: Failed to bind socket: Address already in use
So now i am stuck.
Since the sparky board has EMCC and not a SD card and it is a real pain to open the the case and rebuild it , i cannot flash it.
Sometimes after a lot of reboots it suddenly works again.
But i cant find the issue.
