Volumio no AP and wifi when ethernet connected
Hi, im struggling with connection to wifi on fresh install of newest Volumio. After first install when i connect to ethernet it gives me ip and seems ok. When i go to Web UI i choose wifi put pass, succesul restart network serives but it dont connect to it. When ethernet discconected and reboot it doesnt connect to wifi. Only way to do it is connect display with touch and without ethernet cable connect to wifi using touch display. Second question is: Is there should be an AP active after fresh install to get to webui without calbe?
Since you’re not providing any technical details about your setup, we’re mostly left guessing—and I’m not a big fan of guessing games. :smile:
Could you provide the following information?
  • What hardware are you using? (Raspberry Pi, x86 PC, Thin Client, etc.)
  • Are you using onboard Wi-Fi or a USB Wi-Fi dongle?
  • If it’s a dongle, what’s the exact make/model?
  • Does the Wi-Fi adapter support both Client Mode (CM/Managed) and Access Point (AP) mode?
    If you connect to cable run the command below and past the output of:
    sudo iw list | grep -A20 "Supported interface modes"
  • Which exact version of Volumio are you running? Please provide the version number rather than “the latest”, as “latest” can mean different things depending on when the image was downloaded.
Without that information it’s difficult to determine whether this is a Volumio configuration issue, a driver issue, or simply a Wi-Fi adapter that doesn’t fully support the required modes.
Thanks!
Im sorry for lack of info, forgive me, ofc i shlould provide more info. Im using Rpi5 4gb of ram, hat with nvme, and hifiberry dac2 pro, waveshare 7.9 dislpay. Problem persist also if i use rpi alone. Im using internal wifi of rpi. Volumio 4.119
Have you tried using just wi-fi?
Use the Volumio app on your phone (allow it to discover devices on your network).
Start the Pi 5 without an Ethernet cable connection
Wait a while (few mins), open the Volumio app and search for the new install
Connect to the offered hotspot and do your initial configuration.
With a Pi 5 and the current Volumio and companion app it seems very easy to get a new install working.
thx i will try this.
