Thanks Gvolt. Didn’t get a definitive ‘Finalize message’ and had an error on the touch display but failed to capture it. I also had an error when enabling
I’ve re-booted but no touch display function. Sorry to be a pain, any idea ?
If you did not get a finalize message, how did you know the installation process had finished?
I suggest to try to uninstall the plugin and after that reinstall it. You may follow the installation process in the terminal window.
I’m guessing it installed as it appears in the Plugin section of the UI. I’ll uninstall and try again. Thanks
don’t use the 3.080 it’s half broken use one of the older 3.xx
next week there will be a new release.
Thanks dvo. I can try both.
Finally got this working. Fresh flash of 3.080 on a 16GB card plus installed the Touch Display manually and got the ‘Finalizing Install’ message.
Also connected to my WD MyBook Live NAS drive after I created a user and password on the drive. I also had to enable DNS Server to get it connected.
Thanks to dvo and gvolt for your assistance.
