Volumio gets hung/stuck with 1 TB HDD connected
I am on Volumio 4.119. Pi 3B+ and IQ Audio Pro DAC HAT.
Recently I filled up a 1 TB HDD with FLAC music and connected that to my streamer. It worked fine for some days. But recently I am noticing lot of hung/stuck issues while browsing through the files on this HDD. Most of the time I end up restarting it. Spotify cast seems OK. But otherwise it is very slow and practically non-usable.
Any help appreciated.
Please post a log when this happens, so we can see what the culprit is.
Normally a rPi3B+ should be capable of handling 10-100k libraries, not the smoothest experience but workable.
It might even be that you disk has damaged files.
But without a log, we can’t support you.
It was working perefct last week without any delays. PFB the log (not sure if there is any other method to share logs)
Starting Live Log...
upmpdcli.service: Main process exited, code=exited, status=1/FAILURE
upmpdcli.service: Failed with result 'exit-code'.
info: CorePlayQueue::getQueue
time="2026-05-18T21:39:21+05:30" level=trace msg="sent dealer ping"
time="2026-05-18T21:39:21+05:30" level=trace msg="received dealer pong"
upmpdcli.service: Scheduled restart job, restart counter is at 20.
Stopped upmpdcli.service - UPnP Renderer front-end to MPD.
Started upmpdcli.service - UPnP Renderer front-end to MPD.
Could not open config: /tmp/upmpdcli.conf
info: CoreCommandRouter::executeOnPlugin: mpd , handleBrowseUri
info: CURURI: music-library
info: Preload queue cleared
info: CURURI: music-library/USB
info: CURURI: music-library/USB/3A0028380027FA11
info: CURURI: music-library/USB/3A0028380027FA11/FLAC
info: CURURI: music-library/USB/3A0028380027FA11/FLAC/MALAYALAM
upmpdcli.service: Scheduled restart job, restart counter is at 21.
info: CURURI: music-library/USB/3A0028380027FA11/FLAC/MALAYALAM/Aadujeevitham [2024]
info: Preloading song: music-library/USB/3A0028380027FA11/FLAC/MALAYALAM/Aadujeevitham [2024]/01. Omane.flac
info: Preloading song: music-library/USB/3A0028380027FA11/FLAC/MALAYALAM/Aadujeevitham [2024]/02. Periyone.flac
info: Preloading song: music-library/USB/3A0028380027FA11/FLAC/MALAYALAM/Aadujeevitham [2024]/03. Benevolent Breeze.flac
info: Preloading song: music-library/USB/3A0028380027FA11/FLAC/MALAYALAM/Aadujeevitham [2024]/04. Badaweih (Palestinian Folk Song).flac
info: Preloading song: music-library/USB/3A0028380027FA11/FLAC/MALAYALAM/Aadujeevitham [2024]/05. Istigfar.flac
info: Exploding uri music-library/USB/3A0028380027FA11/FLAC/MALAYALAM/Aadujeevitham [2024]/01. Omane.flac in service mpd
error: scanFolder - failure to stat '/mnt/USB/3A0028380027FA11/FLAC/MALAYALAM/Aadujeevitham [2024]/01. Omane.flac'
info: Exploding uri music-library/USB/3A0028380027FA11/FLAC/MALAYALAM/Aadujeevitham [2024]/02. Periyone.flac in service mpd
error: scanFolder - failure to stat '/mnt/USB/3A0028380027FA11/FLAC/MALAYALAM/Aadujeevitham [2024]/02. Periyone.flac'
info: Exploding uri music-library/USB/3A0028380027FA11/FLAC/MALAYALAM/Aadujeevitham [2024]/03. Benevolent Breeze.flac in service mpd
error: scanFolder - failure to stat '/mnt/USB/3A0028380027FA11/FLAC/MALAYALAM/Aadujeevitham [2024]/03. Benevolent Breeze.flac'
info: Exploding uri music-library/USB/3A0028380027FA11/FLAC/MALAYALAM/Aadujeevitham [2024]/04. Badaweih (Palestinian Folk Song).flac in service mpd
error: scanFolder - failure to stat '/mnt/USB/3A0028380027FA11/FLAC/MALAYALAM/Aadujeevitham [2024]/04. Badaweih (Palestinian Folk Song).flac'
info: Exploding uri music-library/USB/3A0028380027FA11/FLAC/MALAYALAM/Aadujeevitham [2024]/05. Istigfar.flac in service mpd
error: scanFolder - failure to stat '/mnt/USB/3A0028380027FA11/FLAC/MALAYALAM/Aadujeevitham [2024]/05. Istigfar.flac'
time="2026-05-18T21:39:50+05:30" level=trace msg="received accesspoint ping"
time="2026-05-18T21:39:50+05:30" level=trace msg="received accesspoint pong ack"
info: CoreCommandRouter::volumioReplaceandPlayItems
info: CoreStateMachine::ClearQueue
info: CoreStateMachine::stop
info: CorePlayQueue::clearPlayQueue
info: CorePlayQueue::saveQueue
info: CoreCommandRouter::volumioPushQueue
info: CoreStateMachine::addQueueItems
info: CorePlayQueue::addQueueItems
info: Adding Item to queue: music-library/USB/3A0028380027FA11/FLAC/MALAYALAM/Aadujeevitham [2024]/01. Omane.flac
info: Using cached record of: music-library/USB/3A0028380027FA11/FLAC/MALAYALAM/Aadujeevitham [2024]/01. Omane.flac
info: Adding Item to queue: music-library/USB/3A0028380027FA11/FLAC/MALAYALAM/Aadujeevitham [2024]/02. Periyone.flac
info: Using cached record of: music-library/USB/3A0028380027FA11/FLAC/MALAYALAM/Aadujeevitham [2024]/02. Periyone.flac
info: Adding Item to queue: music-library/USB/3A0028380027FA11/FLAC/MALAYALAM/Aadujeevitham [2024]/03. Benevolent Breeze.flac
info: Using cached record of: music-library/USB/3A0028380027FA11/FLAC/MALAYALAM/Aadujeevitham [2024]/03. Benevolent Breeze.flac
info: CoreStateMachine::updateTrackBlock
info: CorePlayQueue::getTrackBlock
info: CoreCommandRouter::volumioPlay
info: CoreStateMachine::play index 2
info: Adding Item to queue: music-library/USB/3A0028380027FA11/FLAC/MALAYALAM/Aadujeevitham [2024]/04. Badaweih (Palestinian Folk Song).flac
info: Using cached record of: music-library/USB/3A0028380027FA11/FLAC/MALAYALAM/Aadujeevitham [2024]/04. Badaweih (Palestinian Folk Song).flac
info: Adding Item to queue: music-library/USB/3A0028380027FA11/FLAC/MALAYALAM/Aadujeevitham [2024]/05. Istigfar.flac
info: Using cached record of: music-library/USB/3A0028380027FA11/FLAC/MALAYALAM/Aadujeevitham [2024]/05. Istigfar.flac
info: CoreStateMachine::play index undefined
info: CorePlayQueue::getTrack 2
time="2026-05-18T21:39:51+05:30" level=trace msg="sent dealer ping"
time="2026-05-18T21:39:51+05:30" level=trace msg="received dealer pong"
upmpdcli.service: Scheduled restart job, restart counter is at 22.
upmpdcli.service: Scheduled restart job, restart counter is at 23.
time="2026-05-18T21:40:21+05:30" level=trace msg="sent dealer ping"
time="2026-05-18T21:40:21+05:30" level=trace msg="received dealer pong"
upmpdcli.service: Scheduled restart job, restart counter is at 24.
upmpdcli.service: Scheduled restart job, restart counter is at 25.
time="2026-05-18T21:40:51+05:30" level=trace msg="sent dealer ping"
time="2026-05-18T21:40:51+05:30" level=trace msg="received dealer pong"
upmpdcli.service: Scheduled restart job, restart counter is at 26.
info: CURURI: music-library/USB/3A0028380027FA11/FLAC/ENGLISH
info: CURURI: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]
info: CURURI: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums
info: CURURI: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}
error: Cue Parser - Cannot parse USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/Thriller.cue
info: Preloading song: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/01. Wanna Be Startin' Somethin'.flac
info: Preloading song: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/02. Baby Be Mine.flac
info: Preloading song: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/03. The Girl Is Mine.flac
info: Preloading song: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/04. Thriller.flac
info: Preloading song: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/05. Beat It.flac
info: Preloading song: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/06. Billie Jean.flac
info: Preloading song: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/07. Human Nature.flac
info: Preloading song: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/08. P. Y. T. (Pretty Young Thing).flac
info: Preloading song: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/09. The Lady in My Life.flac
info: Preloading song: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/Michael Jackson - Thriller.m3u
info: Exploding uri music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/01. Wanna Be Startin' Somethin'.flac in service mpd
error: scanFolder - failure to stat '/mnt/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/01. Wanna Be Startin' Somethin'.flac'
info: Exploding uri music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/02. Baby Be Mine.flac in service mpd
error: scanFolder - failure to stat '/mnt/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/02. Baby Be Mine.flac'
info: Exploding uri music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/03. The Girl Is Mine.flac in service mpd
error: scanFolder - failure to stat '/mnt/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/03. The Girl Is Mine.flac'
info: Exploding uri music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/04. Thriller.flac in service mpd
error: scanFolder - failure to stat '/mnt/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/04. Thriller.flac'
info: Exploding uri music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/05. Beat It.flac in service mpd
error: scanFolder - failure to stat '/mnt/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/05. Beat It.flac'
info: Exploding uri music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/06. Billie Jean.flac in service mpd
error: scanFolder - failure to stat '/mnt/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/06. Billie Jean.flac'
info: Exploding uri music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/07. Human Nature.flac in service mpd
error: scanFolder - failure to stat '/mnt/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/07. Human Nature.flac'
info: Exploding uri music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/08. P. Y. T. (Pretty Young Thing).flac in service mpd
error: scanFolder - failure to stat '/mnt/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/08. P. Y. T. (Pretty Young Thing).flac'
info: Exploding uri music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/09. The Lady in My Life.flac in service mpd
error: scanFolder - failure to stat '/mnt/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/09. The Lady in My Life.flac'
info: Exploding uri music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/Michael Jackson - Thriller.m3u in service mpd
error: scanFolder - failure to stat '/mnt/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/Michael Jackson - Thriller.m3u'
info: Adding Item to queue: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/01. Wanna Be Startin' Somethin'.flac
info: Using cached record of: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/01. Wanna Be Startin' Somethin'.flac
info: CoreStateMachine::play index 0
info: Adding Item to queue: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/02. Baby Be Mine.flac
info: Using cached record of: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/02. Baby Be Mine.flac
info: Adding Item to queue: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/03. The Girl Is Mine.flac
info: Using cached record of: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/03. The Girl Is Mine.flac
info: Adding Item to queue: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/04. Thriller.flac
info: Using cached record of: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/04. Thriller.flac
info: Adding Item to queue: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/05. Beat It.flac
info: Using cached record of: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/05. Beat It.flac
info: Adding Item to queue: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/06. Billie Jean.flac
info: Using cached record of: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/06. Billie Jean.flac
info: Adding Item to queue: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/07. Human Nature.flac
info: Using cached record of: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/07. Human Nature.flac
info: Adding Item to queue: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/08. P. Y. T. (Pretty Young Thing).flac
info: Using cached record of: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/08. P. Y. T. (Pretty Young Thing).flac
info: Adding Item to queue: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/09. The Lady in My Life.flac
info: Using cached record of: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/09. The Lady in My Life.flac
info: Adding Item to queue: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/Michael Jackson - Thriller.m3u
info: Using cached record of: music-library/USB/3A0028380027FA11/FLAC/ENGLISH/Michael Jackson - Discography (1967-2009) [FLAC]/Albums/1982 - Thriller (Japanese 1st Pressing) {EPC Sony 35 8P-11}/Michael Jackson - Thriller.m3u
upmpdcli.service: Scheduled restart job, restart counter is at 27.
time="2026-05-18T21:41:21+05:30" level=trace msg="sent dealer ping"
time="2026-05-18T21:41:21+05:30" level=trace msg="received dealer pong"
upmpdcli.service: Scheduled restart job, restart counter is at 28.
upmpdcli.service: Scheduled restart job, restart counter is at 29.
time="2026-05-18T21:41:50+05:30" level=trace msg="received accesspoint ping"
time="2026-05-18T21:41:50+05:30" level=trace msg="received accesspoint pong ack"
time="2026-05-18T21:41:51+05:30" level=trace msg="sent dealer ping"
time="2026-05-18T21:41:51+05:30" level=trace msg="received dealer pong"
to share your full log, use:
and copy the link before pasting it here :wink:
I reconnected the hard disk and now it seems fine. Thank you for the response @balbuze and @Wheaten . I will report back with logs if I face the issue again.
