Volumio forgets the sources of music
Hi!
The musics are on the internal folder and a NAS sharing is attached. It forget the musics often. I’m trying to play, but I fail. I look at the sources and nothing there. After restarting, you have all the music, but then it forget them again. Did anyone experience similar?
Tamás
Let me guess, you’re running a rPi?
  • How do you power down the rPi?
  • What power supply are you using?
I use RPi4 with IQaudio DigiAMP+ and I use the IQ power supply.
I turn it off inside the Volumio and then pull it out when it stoped. But what I wrote is stories during playback.
Missed that part. Most of these occurrences happens when the network is not stable, like using WiFi.
The connection with the NAS got interrupted, so Volumio closes the connection.
You can run this command from a ssh session, to reload MPD. But if the connection is lost only a reboot will restore it.
sudo systemctl restart mpd
It connect to the network via cable not via wifi. It forgets the music on the SD (INTERNAL) card too.
Then I think something is wrong with your SD, as this is not a normal behavior.
When this happens again, please post a log
I’ve changed the SD card but didn’t help.
All right, as soon as it occurs, I send the log. Thanks!
Now it has happened again. I play a song, and when I want to switch to the next or another, there is silence and this is in log. It is the INTERNAL folder on SD.
Oct 02 12:14 : player: played “INTERNAL/2000 - sts test demo cd vol. 1/01 Pink Panther theme.flac”
Oct 02 12:14 : exception: No such directory
Can you please provide a full log?
Please paste the log link here
thanks
http://logs.volumio.org/volumio/jqezadN.html
Thanks, we need the log JUST AFTER you experience the symptoms.
My theory is that there is an issue with Fusion DSP which crashes MPD (this is an issue that we’ve been chasing for some time)
@balbuze any idea on what can go wrong here?
How it behaves with FusionDsp disabled? (Go in installed plugin to disable it)
Can you check it please?
Thanks!
I will turn off the DSP and test it like that. If the error does not come up, I will turn it back and if it collapses, I will send the log
why do you use software volume control?
Your DAC handles HW mixer…
How? How? If I choose the hardwer mixing, I can’t change the volume.
If you select ‘digital’ In mixer name?
Thanks! It works!
I used it without DSP a few hours, there was no problem. I turned on the DSP and collapsed again when I would like to jump the 4. song.
The log:
http://logs.volumio.org/volumio/jzZSKqy.html
