volumio eq plugin
after a fresh install i saw the eq plugin and installed it but it doesn’t work. sliders, music and such are working but no difference in the sound. the plugin also disrupts my saved i2s association. after every reboot i have to setup the i2s again, eq still not working, and when i go into the playback options screen in the “output device” box audio jack… is stomped on top of the i2s rasbian device name??? i uninstalled and all is good again. i’m using the hifiberry dac +
Hi!
After you have enabled the plugin, DO NOT change settings in playback menu. The plugin redirect the output to the equalizer using as final output your DAC.
So, disable the plugin, check you have the right working output ( i2s, hfifberry) and other settings such as start volume. Reboot. Test with a track. If everything is fine, enable the plugin and wait about 10 sec. Play a track. But please don’t change anything in playback settings.
Balbuze,
Appreciate reply, working as it should.
Thanks!!!
