Hi there,
I have purchased a Sparky Usbridge, but unfortunately Volumio doesn’t recognize the DAC, so no sound…
I’ve used:
volumio-2.203-2017-06-19-sparky.img.zip
Audiolab 8200CDQ DAC
A solution is appreciated!
thnx
Hi there,
I’ve used:
thnx
have you tried to change uenv.txt?
https://volumio.org/forum/solution-usbridge-and-some-dacs-dragonfly-and-usb-dacs-t8544.html
Also, try to connect the DAC after Volumio has started, and then select it from playback options.
I would like to buy this Allo usbridge, I have a Audiolab 8300cd with inside the DAC, any news if the two devices are compatible?
Please let me know!
If not I have to buy the digione with SPDIF.
Thanks a lot.
