Volumio does not find rapsberry
Hi! I got the volumio API installed on 2 android devices, streaming qobuz on a rapsberry Pi with no problems during a couple of years.
Now, the connection RapPi<>volumio suddenly does not work. Any advice to tackle the problem ??
Thanks et merci in my language
First obvious question is, how are you connecting to your Pi, by name or address? If connecting by name, did you perhaps recently get a new router, etc.? If you are connecting by address, is it possible that the IP address of your Pi device has changed? What I generally do in these cases is to create an address reservation on my router for my Pi device. This will cause your Pi device to always receive the same IP address from your router’s DHCP server. After you have done that, you can try to connect to the Pi device using the address that you assigned in the address reservation. Good luck.
