Volumio disconnect problems
Hi got volumio working and Spotify working no problem.the problem is it show up in the Devices available but it does not connect 80 percent of the time .It’s connect with cable to the modem…
Any help thanks
Sent from my SM-G920F using Tapatalk
Do you mean that you are unable to see the UI in a browser? Try setting a static address for the device on your router/modem.
No not disconnecting for network hard to get it to devices .when I run Spotify on iPhone hard to connect to volumio .sometimes it connects and sometimes I will not
Still not clear on the details. You can’t connect from your iphone when running Spotify … how are you trying to connect? Using airplay or Spotify connect plugin? Please give as full details as possible; we can’t second-guess what you are doing/trying to do.
