I’ve noticed that when adding a .cue file, from browse to play queue, volumio adds all the tracks correctly to the queue but after playing the first track it goes on playing the whole album WITHOUT going to the next queue entry. So when the album is fully played it gets into the second track and plays the whole alnum again starting from the second track. An so on for the third track…
It’s quite annoying and the only workaround seems to add each track individually. Anyone else notice that behaviour? It seems like a bug to me.
Hello everybody. Problems also with .cue. I listen to music from Ogg vorbis files with a .cue file. Volumio reads the first track then reread 8,10 … 30 seconds before moving on to the next. Same if I use the Next button. Bug with INDEX cue file?
hi, there, i have the same problems, also played until halfway of a playlist, such as track 5, and then remove that playlist and load another playlist, start playing, it on track 5 not on 1st track of the new playlist.
I also find a problem that Volumio does not translate the .cue file when browsing a Media Servers folder. Which is does if the folder is on the local drive.
