Volumio crashes after update
I installed the Volumio update on Sunday, since then my Volumio has the following errors.
You updated to a beta version with all the risks that come with it.
In case you want to avoid future issues, do not enable test mode.
it looks like a problem with a faulty/currupted sd-card
please get a new one and flash the latest stable image
Thanks for your answers.
Will disable test mode and get a new sd card.
quick questions:
  • Do you remember from which version you updated from?
  • Which plugins did you have installed?
t was the last update, unfortunately I don’t know the version number anymore.
Thanks again for your help,
Problem solved, the SD card was defective.
