I did a factory reset in settings, and now when I type in volumio.local in my web browser, it will no longer connect. I have tried turning off the wi-fi and restarting the device to see if Volumio creates a local hotspot like it did the first time, but it still doesn’t work. I have also tried using a ethernet cable. What do I do? Please help!
I had a similar issue with renaming my volumio. For me the information was cached at the PC level and it wouldn’t recognize the device after I removed the old one. On Windows 10 i did a network reset and that cleared up the issue.
I was able to connect to the device by using its IP address but I can now access it using the device name.
