I have just moved into a new place and changed my installation a little bit.
Volumio is running on RPI3 with the latest version. It has a DIGI+ for the output.
My music is stored on a USB drive which is connected to a Cubox 1. The music folder is shared through NFS and CIFS by the configuration at the end of this post.
I am wondering why Volumio cannot read these folders either in CIFS or NFS. I have no errors message when adding the folder.
When I connect to Volumio in SSH, the NFS share is present in /mnt/NAS. I can navigate into all the folders and I can see all the files.
My new internet provider box is my router and is only IPV4. Can this be the issue? I do not understand why.
I hope someone can help me. I spent hours to try to tackle this issue.
NFS /etc/exports
X.X.X.X(ro,no_subtree_check,all_squash,insecure)
SMB /etc/samba/smb.conf
[MusicFolder]
comment = Hard drive in USB
path = /path/to/music
guest ok = yes
browseable = yes
create mask = 777
read only = yes
valid users = XXXX
Log file : /var/log/volumio.org
cat /var/log/volumio.log
2018-08-28T12:57:54.207Z - info: -------------------------------------------
2018-08-28T12:57:54.210Z - info: ----- Volumio2 ----
2018-08-28T12:57:54.211Z - info: -------------------------------------------
2018-08-28T12:57:54.211Z - info: ----- System startup ----
2018-08-28T12:57:54.386Z - info: Plugin folders cleanup
2018-08-28T12:57:54.387Z - info: Scanning into folder /volumio/app/plugins/
2018-08-28T12:57:54.387Z - info: Scanning category audio_interface
2018-08-28T12:57:54.388Z - info: Scanning category miscellanea
2018-08-28T12:57:54.389Z - info: Scanning category music_service
2018-08-28T12:57:54.390Z - info: Scanning category plugins.json
2018-08-28T12:57:54.391Z - info: Scanning category system_controller
2018-08-28T12:57:54.392Z - info: Scanning category user_interface
2018-08-28T12:57:54.393Z - info: Scanning into folder /data/plugins/
2018-08-28T12:57:54.393Z - info: Scanning category music_service
2018-08-28T12:57:54.394Z - info: Plugin folders cleanup completed
2018-08-28T12:57:54.396Z - info: -------------------------------------------
2018-08-28T12:57:54.396Z - info: ----- Core plugins startup ----
2018-08-28T12:57:54.398Z - info: Loading plugins from folder /volumio/app/plugins/
2018-08-28T12:57:54.404Z - info: Loading plugins from folder /data/plugins/
2018-08-28T12:57:54.407Z - info: Loading plugin "system"...
2018-08-28T12:57:54.437Z - info: Loading plugin "appearance"...
2018-08-28T12:57:55.611Z - info: Loading plugin "network"...
2018-08-28T12:57:56.091Z - info: Loading plugin "services"...
2018-08-28T12:57:56.097Z - info: Loading plugin "alsa_controller"...
2018-08-28T12:57:56.183Z - info: Loading plugin "wizard"...
2018-08-28T12:57:56.197Z - info: Loading plugin "volumio_command_line_client"...
2018-08-28T12:57:56.206Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2018-08-28T12:57:56.207Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2018-08-28T12:57:56.232Z - info: Loading plugin "upnp"...
2018-08-28T12:57:56.240Z - info: [1535461076239] Starting Upmpd Daemon
2018-08-28T12:57:56.242Z - info: CoreCommandRouter::executeOnPlugin: system , registerCallback
2018-08-28T12:57:56.245Z - info: Loading plugin "my_music"...
2018-08-28T12:57:56.256Z - info: Loading plugin "mpd"...
2018-08-28T12:57:56.604Z - info: Loading plugin "upnp_browser"...
2018-08-28T12:57:57.673Z - info: Loading plugin "networkfs"...
2018-08-28T12:57:57.724Z - info: CoreCommandRouter::executeOnPlugin: system , registerCallback
2018-08-28T12:57:57.725Z - info: Loading plugin "alarm-clock"...
2018-08-28T12:57:57.973Z - info: Loading plugin "airplay_emulation"...
2018-08-28T12:57:58.003Z - info: [1535461078003] Starting Shairport Sync
2018-08-28T12:57:58.005Z - info: Loading plugin "last_100"...
2018-08-28T12:57:58.014Z - info: Loading plugin "webradio"...
2018-08-28T12:57:58.035Z - info: Loading plugin "i2s_dacs"...
2018-08-28T12:57:58.049Z - info: I2S DAC not set, start Auto-detection
2018-08-28T12:57:58.065Z - info: Loading plugin "volumiodiscovery"...
2018-08-28T12:57:58.148Z - info: Applying required configuration parameters for plugin volumiodiscovery
2018-08-28T12:57:58.187Z - info: CoreCommandRouter::executeOnPlugin: system , registerCallback
2018-08-28T12:57:58.188Z - info: Loading plugin "youtube"...
2018-08-28T12:58:00.129Z - info: Loading plugin "albumart"...
2018-08-28T12:58:00.157Z - info: Plugin example_plugin is not enabled
2018-08-28T12:58:00.158Z - info: Loading plugin "updater_comm"...
2018-08-28T12:58:00.295Z - info: Plugin mpdemulation is not enabled
2018-08-28T12:58:00.296Z - info: Loading plugin "rest_api"...
2018-08-28T12:58:00.309Z - info: Loading plugin "websocket"...
2018-08-28T12:58:00.337Z - info: Plugin spop is not enabled
2018-08-28T12:58:00.340Z - info: ___________ START PLUGINS ___________
2018-08-28T12:58:00.345Z - info: CoreCommandRouter::executeOnPlugin: mpd , getConfigParam
2018-08-28T12:58:00.346Z - info: CoreCommandRouter::volumioAddToBrowseSources[object Object]
2018-08-28T12:58:00.347Z - info: [1535461080347] CoreMusicLibrary::Adding element Media Servers
2018-08-28T12:58:00.363Z - info: CoreCommandRouter::volumioAddToBrowseSources[object Object]
2018-08-28T12:58:00.363Z - info: [1535461080363] CoreMusicLibrary::Adding element Last_100
2018-08-28T12:58:00.366Z - info: CoreCommandRouter::volumioAddToBrowseSources[object Object]
2018-08-28T12:58:00.366Z - info: [1535461080366] CoreMusicLibrary::Adding element Webradio
2018-08-28T12:58:00.368Z - info: CoreCommandRouter::executeOnPlugin: system , getSystemVersion
2018-08-28T12:58:00.370Z - info: Youtube::onStart Adding to browse sources
2018-08-28T12:58:00.371Z - info: CoreCommandRouter::volumioAddToBrowseSources[object Object]
2018-08-28T12:58:00.372Z - info: [1535461080371] CoreMusicLibrary::Adding element Youtube
2018-08-28T12:58:00.375Z - info: -------------------------------------------
2018-08-28T12:58:00.376Z - info: ----- MyVolumio plugins startup ----
2018-08-28T12:58:00.376Z - info: -------------------------------------------
2018-08-28T12:58:00.377Z - info: Loading plugins from folder /myvolumio/plugins
2018-08-28T12:58:00.378Z - info: Loading plugins from folder /data/myvolumio/plugins
2018-08-28T12:58:00.380Z - info: Loading i18n strings for locale fr
2018-08-28T12:58:00.428Z - info: CoreCommandRouter::executeOnPlugin: mpd , getConfigParam
2018-08-28T12:58:00.430Z - info: CoreCommandRouter::initPlayerControls
2018-08-28T12:58:00.439Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2018-08-28T12:58:00.439Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getAlsaCards
2018-08-28T12:58:00.485Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2018-08-28T12:58:00.486Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2018-08-28T12:58:00.487Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2018-08-28T12:58:00.488Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2018-08-28T12:58:00.499Z - info: CoreCommandRouter::executeOnPlugin: mpd , getConfigParam
2018-08-28T12:58:00.502Z - info: BOOT COMPLETED
2018-08-28T12:58:00.503Z - info: CoreCommandRouter::executeOnPlugin: system , getConfigParam
2018-08-28T12:58:23.928Z - info: CoreCommandRouter::Close All Modals sent
2018-08-28T12:58:23.929Z - info: CoreCommandRouter::Close All Modals sent
2018-08-28T12:58:24.017Z - info: CoreStateMachine::resetVolumioState
2018-08-28T12:58:24.018Z - info: CoreStateMachine::getcurrentVolume
2018-08-28T12:58:24.019Z - info: CoreCommandRouter::volumioRetrievevolume
2018-08-28T12:58:24.033Z - info: CoreStateMachine::updateTrackBlock
2018-08-28T12:58:24.035Z - info: CorePlayQueue::getTrackBlock
2018-08-28T12:58:24.351Z - info: Setting Device type: Raspberry PI
2018-08-28T12:58:24.370Z - info: Cannot initialize MPD Connection: MPD is not running
2018-08-28T12:58:24.497Z - info: VolumeController:: Volume=undefined Mute =undefined
2018-08-28T12:58:24.499Z - info: CoreStateMachine::pushState
2018-08-28T12:58:24.501Z - info: CoreStateMachine::getState
2018-08-28T12:58:24.502Z - info: CorePlayQueue::getTrack 0
2018-08-28T12:58:24.503Z - info: CoreCommandRouter::volumioPushState
2018-08-28T12:58:24.504Z - info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
2018-08-28T12:58:24.513Z - info: Volumio called home
2018-08-28T12:58:24.577Z - info: CoreCommandRouter::executeOnPlugin: system , getConfigParam
2018-08-28T12:58:24.582Z - info: Reloading queue from file
2018-08-28T12:58:24.648Z - info: CoreStateMachine::setRepeat null single undefined
2018-08-28T12:58:24.649Z - info: CoreStateMachine::pushState
2018-08-28T12:58:24.649Z - info: CoreStateMachine::getState
2018-08-28T12:58:24.650Z - info: CorePlayQueue::getTrack 0
2018-08-28T12:58:24.650Z - info: CoreCommandRouter::volumioPushState
2018-08-28T12:58:24.651Z - info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
2018-08-28T12:58:24.655Z - info: CoreStateMachine::setRandom null
2018-08-28T12:58:24.655Z - info: CoreStateMachine::pushState
2018-08-28T12:58:24.655Z - info: CoreStateMachine::getState
2018-08-28T12:58:24.656Z - info: CorePlayQueue::getTrack 0
2018-08-28T12:58:24.656Z - info: CoreCommandRouter::volumioPushState
2018-08-28T12:58:24.657Z - info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
2018-08-28T12:58:24.750Z - info: mDNS: Found device Volumiopi3
2018-08-28T12:58:24.892Z - info: [1535461104891] Shairport-Sync Started
2018-08-28T12:58:24.943Z - info: CoreCommandRouter::volumioGetState
2018-08-28T12:58:24.945Z - info: CoreStateMachine::getState
2018-08-28T12:58:24.947Z - info: CorePlayQueue::getTrack 0
2018-08-28T12:58:24.976Z - info: Upmpdcli Daemon Started
2018-08-28T12:58:24.979Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , checkAudioDeviceAvailable
2018-08-28T12:58:25.003Z - info: CoreCommandRouter::executeOnPlugin: system , versionChangeDetect
2018-08-28T12:58:26.159Z - info: CoreCommandRouter::volumioGetState
2018-08-28T12:58:26.160Z - info: CoreStateMachine::getState
2018-08-28T12:58:26.160Z - info: CorePlayQueue::getTrack 0
2018-08-28T12:58:27.058Z - error: Upnp client error: Error: read ECONNRESET
2018-08-28T12:58:27.079Z - info: CoreCommandRouter::volumioGetBrowseSources
2018-08-28T12:58:27.113Z - info: CoreCommandRouter::executeOnPlugin: multiroom , getMultiroom
2018-08-28T12:58:27.121Z - info: Listing playlists
2018-08-28T12:58:27.124Z - info: CoreCommandRouter::volumioGetQueue
2018-08-28T12:58:27.125Z - info: CoreStateMachine::getQueue
2018-08-28T12:58:27.125Z - info: CorePlayQueue::getQueue
2018-08-28T12:58:39.193Z - info: CoreCommandRouter::volumioGetState
2018-08-28T12:58:39.194Z - info: CoreStateMachine::getState
2018-08-28T12:58:39.194Z - info: CorePlayQueue::getTrack 0
2018-08-28T12:58:39.270Z - info: CoreCommandRouter::volumioGetBrowseSources
2018-08-28T12:58:39.277Z - info: CoreCommandRouter::executeOnPlugin: appearance , getUiSettings
2018-08-28T12:58:39.287Z - info: CoreCommandRouter::executeOnPlugin: wizard , getShowWizard
2018-08-28T12:58:39.288Z - info: CoreCommandRouter::executeOnPlugin: system , getShowWizard
2018-08-28T12:58:39.308Z - info: CoreCommandRouter::executeOnPlugin: multiroom , getMultiroom
2018-08-28T12:58:39.312Z - info: Listing playlists
2018-08-28T12:58:48.530Z - info: CoreCommandRouter::executeOnPlugin: system , getSystemVersion
2018-08-28T12:58:48.532Z - info: CoreCommandRouter::executeOnPlugin: system , getConfigParam
2018-08-28T12:58:56.959Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T12:59:06.166Z - info: mDNS: A device disapperared from network
2018-08-28T12:59:06.167Z - info: mDNS: Device volumiopi3 disapperared from network
2018-08-28T12:59:14.859Z - info: mDNS: Found device Volumiopi3
2018-08-28T12:59:30.989Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T13:00:09.019Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T13:00:55.050Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T13:01:57.056Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T13:03:31.086Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T13:06:01.117Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T13:08:31.149Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T13:11:01.180Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T13:13:31.209Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T13:16:01.239Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T13:18:31.270Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T13:21:01.295Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T13:23:31.326Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T13:26:01.357Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T13:28:31.388Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T13:31:01.416Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T13:33:31.447Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T13:36:01.478Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T13:38:31.506Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T13:41:01.537Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T13:43:31.568Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T13:46:01.599Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T13:48:31.630Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T13:51:01.660Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T13:53:31.690Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T13:56:01.721Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T13:58:31.752Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T14:01:01.783Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T14:03:31.813Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T14:06:01.836Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T14:08:31.866Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T14:11:01.897Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T14:13:31.928Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T14:16:01.955Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T14:18:31.986Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T14:21:02.017Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T14:23:32.048Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T14:26:02.079Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T14:28:32.109Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T14:29:52.254Z - info: CoreCommandRouter::volumioGetState
2018-08-28T14:29:52.255Z - info: CoreStateMachine::getState
2018-08-28T14:29:52.255Z - info: CorePlayQueue::getTrack 0
2018-08-28T14:29:52.367Z - info: CoreCommandRouter::volumioGetBrowseSources
2018-08-28T14:29:52.373Z - info: CoreCommandRouter::executeOnPlugin: appearance , getUiSettings
2018-08-28T14:29:52.381Z - info: CoreCommandRouter::executeOnPlugin: wizard , getShowWizard
2018-08-28T14:29:52.381Z - info: CoreCommandRouter::executeOnPlugin: system , getShowWizard
2018-08-28T14:29:52.537Z - info: CoreCommandRouter::executeOnPlugin: multiroom , getMultiroom
2018-08-28T14:29:52.555Z - info: Listing playlists
2018-08-28T14:31:02.141Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T14:33:32.172Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T14:36:02.202Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T14:38:32.233Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T14:41:02.263Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
2018-08-28T14:43:32.294Z - error: Upnp client error: Error: connect ECONNREFUSED 127.0.0.1:6600
Thanks in advance,
yanndan
