I would like to be a new Volumio user but I failed.
I’ve used several OS’s since now (Ropieee, Moode, PiCorePlayer), but I can’t boot the new Volumio.
I downloaded from the offical site and I made my SD Card as I used to with the officially PiManager and I have only problems.
Please help me, thanks.
Adam
Seems something went fully wrong while you wrote the image, or SD cards is faulty.
Just to be sure.
- Download image form volumio.com
- Unzip the file
- Flash the *.img file to your SD only using Raspberry Pi Imager.
Thanks, now works fine.
It was a new experience for me that the Pi Manager sees the .zip file and it works with it but the result is so bad, until now I didn’t pack it, thnka for the advice!
I use a DIY HAT I2S board, the Ropieee can use it as a generic DAC board but with this one the Volumio doesn’t makr any sound.
The Volumio has 30-40 HAT DAC’s in its list I’ve started to try it out everyone but so far no result.
Do you have any idea how should I set up?
Thanks.
