Volumio and WittyPi2
Hey there from Germany,
I unsuccessfully tried to integrate a wittypi2 into Volumio OS. I followed the workaround from uugear for WittyPi2. The download worked well but the install sh was denied. I´m a noob and not familiar with raspbian yet, so i think it´s a small thing to make this work but i can´t solve it myself. Volumio is now running with a raspberry Pi 3B+,a Rasptouch and a 7" Display very well.
I think you need to give us some detail here. A link to your “workaround”, how is it “denied” (give error message? The more detail that you can give, then the easier it is to help :wink:
Problem solved! It was very simple, as there was no unzip installed in Volumio OS. After this was done, everything worked well!
