Why does Volumio have trouble with foreign characters? I mean, we are not living in the nineties anymore. I see myself then looking up in ascii tables and using alt-keys. I hope there is some solution.
This screenshot is from a radio broadcast.
Not sure if this is Volumio related or caused by the character set from the webradio?
If I lookup this track via Qobuz, it’s displayed as expected.
Do you experience this with multiple streams, or only this one?
If only we were.
Depends to whom you ask, if I have to believe my daughter I still live there, or stuck there. I don’t know, can’t remember
I saw a Swiss and a German broadcast company with the right characters. So then it depends on which company, I can conclude.
Thanks for reporting back.
I think it has to do with format of the file utf-8 should give the wright characters
