like the header says. Id like to be able to take all the music Ive ripped over the years and be able to remotely play it with a raspi. Instructions look easy enough, HUNDREDS of folks world wide get it done in like 20 minutes. Me? been beating away for 3 weeks. no go.
Just to say in the start, I have pretty much given up on picoreplayer. I don’t know TinmyCore well enough to be able to manipulate the cli well enough w/o screaming at my pc, so im focusing on VOLUMIO.
I have 2 RASPI setups, both raspis are new, as is 1 of the soundcards. Coincidentally the AudioInjector card is one of the 1st sound cards I bought and so far its been awesome!
HW 1 - RASPI 3B+ , AudioInjector Stereo card, 7" external HDMI monitor, usb kbd, usb mouse, 4TB external seagate HD, WIRED Net connection, about 6 ft from the router
HW 2 - RASPI 3B+ ,HIFIBERRY DAC + sound card (new), 7" external HDMI monitor, usb kbd, usb mouse, 4TB external seagate HD, WIRED Net connection, about 6 ft from the router
HW1
Just to make sure (I come from the era of pizza box computer building), I installed Raspbian on a clean SD card and followed the directions here:
flatmax.org/phpbb/viewtopic.php?f=5&t=3
and everything seemed to be ok.
Pulled the SD card formatted it loaded the latest volumio image on it, and realized that the drivers were going to have to be installed (ok the .deb that says scripts) SO after MUCH late night wrangling I finally got them loaded, and when I went into volumio setup, found that in the first selection, I had the audio injector card as a selection. Mater of fact it almost seemd like it was the ONLY selection. Everytim I hit the drop down it would go to that selection immediately and populate the section box.
THEN when I hit SAVE it reverted back to GENERIC OUTPUT MODEL. after several attempts I finally got it to SAVE with AI card in both the output AND the DAC boxes.
Go out to the play screen and NO SOUND. I have my RCA plugged into a YAMAHA VSX816 w/ some nice floor speaker…nada
headphone jack on the raspi, nada (THAT I found very weird)
Ill include 2 pix if I can.
But everything looks good no errors nothing
I did find that I had to add in this page in order to get the card to appear as a selection:
flatmax.org/phpbb/viewtopic. … umio#p5054
but NO SOUND
Now for #2, this SEEMED to be good from the get go, just NO SOUND.
Difference was: I was able to go straight in and select the card from the initial drop down, but again, everything says green no sound.
No errors but no sound
I even went so far as to plug this one into a different receiver, no go
anyone have ANY ideas they would be greatly appreciated
thanks
J\
