Hello Community,
since some days, i have an issue with my volumio setup. Unfortunaltey, this issue came without having changed something in the configs.
I experience a restart of Volumio all the time i play the play button, irrelevant from which source (e.g. radio, spotify, etc.). Volumio is, obviously, not reachable anymore and i need to wait for the restart.
I created a log according to the manuals and i hope someone can assist me what to improve.
http://logs.volumio.org/volumio/h8a8LMX.html
Many thanks!
please perform a factory reset.
We need the log just after the issue occurs.
We can’t see any meaningful error in the log you just sent.
Also i see you have a manually installed plugin, don’t do that. This plugins are not verified and might cause the system to be unstable
hey together,
many thanks for your tipps.
I performed a factory reset and completely deleted the sd card, reflashed it with rpi-imager and set up the system once again.
Unfortunaltey, with a freshly installed system, the reboots still exist.
I made again an upload with a new log and i hope, that someone can assist me!
Logs
What is curious to me: i did not change anything in the system or the hardware, when the reboots started. meaning, i cannot say what changed…
many thanks
Pleas use a new SD card, as I still see errors like:
Feb 07 14:48:52 wohnzimmer-radio systemd-fsck[259]: 0x25: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
When done, try first without anything connected. Just use the audio jack.
If this work, you can add your hardware one by one. So adding 1 thing and test. When success full add the next.
Also check your PSU, it might be that it’s partial failing.
Can’t see anything on the log.
Did you do that after the issue just occured? Do not reboot or restart your device
thx for the tipps… will try and report back the result
there’s an automatical reboot, when i press the play button…
meaning, when i press the play button, the system crashs and reboots automatically… the next restart, i do the log
at the end, the problem was solved by changing the PSU…
yeah, I did mention this.
Good to hear the issue is resolved.
