Hi all,
Dont no if i have bricked my volumio rivo but tried to update volumio 4 that was OTA with volumio app
And after 1.5 hour still 99% download wired connect
So i gave up unplugged it from power restarted rivo and a factory reset.
Then tried again to OTA update rivo same again waited 1 hour 99% download so again this just restarted rivo.
Some of you experienced an issue today while updating to Volumio 4 on Rivo and Rivo Plus, the update getting stuck (often around 99%) or the device becoming unresponsive to further update checks.
This was caused by a temporary issue on our update servers, not a device-side problem. It’s now been fixed.
If you were affected, you can safely retry:
Go to Settings > System > Check for Updates
Start the update to Volumio 4 again, it should complete normally now
Sorry for the inconvenience, and thanks for your patience while we sorted this out. Let us know here or via support if you still run into any trouble.
