Hi there
Ive recently purchased the Rivo+ with lineo5. As part of rivo+ purchase you receive Volumio 4 premium lifetime yet unfortunately having difficulty with this. On free version currently which is suggesting I sign and pay for premium. Any body had similar experience and found a fix.
Cheers
Simon
The premium (license) functions is included with the hardware, you have access to premium support from Volumio - if you go to Help Center | Volumio and then click on the chat icon you should be able to create a ticket with the support team.
Hi @SimonGM1, thanks for reaching out!
The Premium license included with your Rivo+ is tied to the device itself, not to your MyVolumio account. To help us check, could you tell us:
1.Where do you see the Free plan: in the new Volumio app (Nova) or in the classic interface (Manifest, from the browser)?
2.Are the Premium features working on your Rivo+, for example TIDAL, Qobuz or Qobuz Connect?
Hi Marco and Stefan
I had been using the Volumio app on my Mac with contemporary interface up until recent iOS update to 27.2. Since that time the app is no longer able to find the rivoplus? Prior to this new issue, the MyVolumio tab in device settings identified that I was on the free plan and suggested I purchase premium. After the Mac app stopped working I rebooted from scratch on my iPhone. I changed from Contemporary to the new Nova interface. Re attempt with Mac app without success so began using the Browser. In Nova interface settings it identified that I was on the premium device so that’s sorted thanks. As far as premium features go I was initially getting meta data yet after IOS update no longer had access to this. I have access currently with Nova interface which is great. I was able to run Tidal from the outset via roon server so had that premium function. Then I closed roon account as Volumio was great platform for tidal without roon in my system. No new issues after removing roon from the equation. An additional glitch which I brought up in my first topic is tidal res quality issue still remains yet not isolated to my experience. So other than Mac Volumio app not working currently all seems to be functioning well with device premium.
To that end the Rivo+ with lineo5 is bring out the best of my New Zealand made perreaux 200ix and Image 414 speakers (elderly). Both smaller companies and very passionate which I saw a parallel with your company which led to my choice to buy the Rivo+ over other transports on offer.
Thanks for the support.
Thanks @SimonGM1, great to hear the Premium features are now working with Nova, and thank you for the kind words! Two things for what’s still open: for the Mac app, please make sure it’s updated to the latest version, then remove it and reinstall it, and check that your Mac is on the same network as the Rivo+. For the TIDAL quality issue, let’s continue in your other topic so we can look at it properly. Enjoy your music!
